Project Videos
  • Project Videos
Project Videos
Documents Repairing a Neewer 660 Studio light - How Hard Can It Be? -- Episode 594
  • Date Created: 9 Mar 2023 2:01 AM Date Created
  • Last Updated Last Updated: 17 Mar 2023 8:24 AM
  • Views 24998 views
  • Likes 10 likes
  • Comments 46 comments
I’ve got a studio light which has suddenly become faulty, how hard could it be to fix it rather than replace? In today’s episode I try and fault find the PCB to see if its a fault I can fix.
Watch the Video:
Bill of Material:
8 bit MCU, STM8S003F3P6TR STMICROELECTRONICS 1 Buy Now
Fixed LDO Voltage Regulator HOLTEK 1 Buy Now
Pluggable Terminal Block WAGO 3 Buy Now
Additional Parts:
Fault studio light
element14 presents
element14 presents  |  About Katie Dumont |  Project Videos
  • fault finding
  • e14p_KD
  • neewar
  • Pluggable Voltage Regulator
  • 8 bit mcu
  • Fixed LDO Voltage Regulator
  • Studio Light
  • st
  • friday_release
  • led panel repair
  • hifromkatie
    hifromkatie over 3 years ago in reply to RichG +3
    I'm quite tempted to go completely away from the original design and do a 555 based controller, the main operation of the micro was to take the potentiometer input and turn it in to a PWM to the LED driver…
  • RichG
    RichG over 3 years ago +1
    Yes a new project with a microcontroller.
  • phoenixcomm
    phoenixcomm over 3 years ago
    First, your troubleshooting technique needs work. You did a lot of guessing. to short-circuit the debug. it would help if you wired your ps to the output rail of the regulator. to do an unpowered test of the CPU all you needed was your fluke on ohms and measured across its power lands. This would have told you you had a short on the power rail, then unsolder the regulator, the meter still says SHORT, and no burnt or blown disks would say CPU. To build a new driver, well you have half of it there. Use what you have and just build a new controller. fins. Oh, btw you can always start at both ends and work to the middle.
  • hifromkatie
    hifromkatie over 3 years ago in reply to phoenixcomm
    I sort of found the regulator and jumped straight in to that being the problem, I should have checked further along before assuming that was the problem. There was quite a bit of troubleshooting that got cut, as we almost had a 1 hour video of the highlights, unfortunately because I spent a while poking at it, there was also times I just wasn't recording.
    My plan is to build a replacement controller, but will probably skip the micro and use a 555 to produce the PWM control for the LED drivers.
  • hifromkatie
