Project Videos
  • Project Videos
Project Videos
Documents Repairing a Neewer 660 Studio light - How Hard Can It Be? -- Episode 594
  • Date Created: 9 Mar 2023 2:01 AM Date Created
  • Last Updated Last Updated: 17 Mar 2023 8:24 AM
  • Views 25015 views
  • Likes 10 likes
  • Comments 46 comments
I’ve got a studio light which has suddenly become faulty, how hard could it be to fix it rather than replace? In today’s episode I try and fault find the PCB to see if its a fault I can fix.
Watch the Video:
Bill of Material:
8 bit MCU, STM8S003F3P6TR STMICROELECTRONICS 1 Buy Now
Fixed LDO Voltage Regulator HOLTEK 1 Buy Now
Pluggable Terminal Block WAGO 3 Buy Now
Additional Parts:
Fault studio light
element14 presents
element14 presents  |  About Katie Dumont |  Project Videos
  • fault finding
  • e14p_KD
  • neewar
  • Pluggable Voltage Regulator
  • 8 bit mcu
  • Fixed LDO Voltage Regulator
  • Studio Light
  • st
  • friday_release
  • led panel repair
  • hifromkatie
    hifromkatie over 3 years ago in reply to RichG +3
    I'm quite tempted to go completely away from the original design and do a 555 based controller, the main operation of the micro was to take the potentiometer input and turn it in to a PWM to the LED driver…
  • RichG
    RichG over 3 years ago +1
    Yes a new project with a microcontroller.
    dougw over 3 years ago
    Presumably the MCU is controlling the power to each color using PWM. You could look at the working light to see what the MCU outputs look like. I expect you can see if the lights work just by connecting the output pad to 5V. If you only need one color at one brightness, you might get away with just using a short or a switch in place of the MCU.
  • hifromkatie
    hifromkatie over 3 years ago in reply to dougw
    Yes, PWM to the LED driver circuits for each colour of LEDs. I had checked the lights independently and they are working fine, it's just the control that's dead, I think I may have ended up cutting that section of testing from the video, at one point it was an hour long fault finding episode!
    I tend to have both colours set to approx 50%, so wouldn't be that hard to wire up as fixed. Great suggestion, as I hadn't thought about that as a possibility, but it very rare that I change them.
