Project Videos
  • Project Videos
Project Videos
Documents Repairing a Neewer 660 Studio light - How Hard Can It Be? -- Episode 594
  • Date Created: 9 Mar 2023 2:01 AM Date Created
  • Last Updated Last Updated: 17 Mar 2023 8:24 AM
  • Views 24998 views
  • Likes 10 likes
  • Comments 46 comments
I’ve got a studio light which has suddenly become faulty, how hard could it be to fix it rather than replace? In today’s episode I try and fault find the PCB to see if its a fault I can fix.
Watch the Video:
Bill of Material:
8 bit MCU, STM8S003F3P6TR STMICROELECTRONICS 1 Buy Now
Fixed LDO Voltage Regulator HOLTEK 1 Buy Now
Pluggable Terminal Block WAGO 3 Buy Now
Additional Parts:
Fault studio light
element14 presents
element14 presents  |  About Katie Dumont |  Project Videos
  • fault finding
  • e14p_KD
  • neewar
  • Pluggable Voltage Regulator
  • 8 bit mcu
  • Fixed LDO Voltage Regulator
  • Studio Light
  • st
  • friday_release
  • led panel repair
  • hifromkatie
    hifromkatie over 3 years ago in reply to RichG +3
    I'm quite tempted to go completely away from the original design and do a 555 based controller, the main operation of the micro was to take the potentiometer input and turn it in to a PWM to the LED driver…
  • RichG
    RichG over 3 years ago +1
    Yes a new project with a microcontroller.
  • scottiebabe
    scottiebabe over 3 years ago
    Shame your little MCU gave up the ghost :( As always loved the video!
    I would measure I/V characteristics of your Led strings to double check they still work and what specifications you would need to design to.
    Presumably the panel strings are being driven with a constant current floating buck. Not sure if the regulation is done by the MCU or a dedicated control chip...
  • scottiebabe
  • hifromkatie
    hifromkatie over 3 years ago in reply to scottiebabe
    It seems to MCU was providing a PWM to the LED drivers circuit, so think it'd be fairly easy to use a 555 to replace this PWM control. A quick power up directly on the LED panel and it seems that is still working correctly, so I think it's just a case of build a new control circuit and new LED constant currant driver on a PCB that can be dropped into the case.
