Project Videos
  • Project Videos
Project Videos
Documents Repairing a Neewer 660 Studio light - How Hard Can It Be? -- Episode 594
  • Date Created: 9 Mar 2023 2:01 AM Date Created
  • Last Updated Last Updated: 17 Mar 2023 8:24 AM
  • Views 25015 views
  • Likes 10 likes
  • Comments 46 comments
I’ve got a studio light which has suddenly become faulty, how hard could it be to fix it rather than replace? In today’s episode I try and fault find the PCB to see if its a fault I can fix.
Watch the Video:
Bill of Material:
8 bit MCU, STM8S003F3P6TR STMICROELECTRONICS 1 Buy Now
Fixed LDO Voltage Regulator HOLTEK 1 Buy Now
Pluggable Terminal Block WAGO 3 Buy Now
Additional Parts:
Fault studio light
element14 presents
element14 presents  |  About Katie Dumont |  Project Videos
  • fault finding
  • e14p_KD
  • neewar
  • Pluggable Voltage Regulator
  • 8 bit mcu
  • Fixed LDO Voltage Regulator
  • Studio Light
  • st
  • friday_release
  • led panel repair
  • hifromkatie
    hifromkatie over 3 years ago in reply to RichG +3
    I'm quite tempted to go completely away from the original design and do a 555 based controller, the main operation of the micro was to take the potentiometer input and turn it in to a PWM to the LED driver…
  • RichG
    RichG over 3 years ago +1
    Yes a new project with a microcontroller.
    beacon_dave over 3 years ago
    Since you have the second working unit, you could perhaps look at downloading the code from that working one to reprogram a new replacement microcontroller with. Or at least use it to work out what the microcontroller does and then write new code to duplicate the functionality.
  • hifromkatie
    hifromkatie over 3 years ago in reply to beacon_dave
    For some reason I honestly hadn't thought back to the fact I've got an identical unit, by that point it was mounted back above my desk!
    But trying to obtain the code off it is an interesting solution, although I suspect it might be read protected (I know all the products I've worked on in the past we have protected the microcontroller code).
    As far as I can tell the micro takes the potentiometer inputs and outputs a PWM for each pot, I haven't seem any other fuctionality, so I think it'd be interesting to replace it with a 555 based control circuit to either the original LED drivers, or just redo the drivers as well.
  • hifromkatie
