Project Videos
  • Project Videos
Project Videos
Documents DIY AC Dimmer Circuit: Control Your Lights with a Raspberry Pi Pico -- Episode 602
  • Date Created: 3 May 2023 6:50 PM Date Created
  • Last Updated Last Updated: 12 May 2023 7:24 AM
  • Views 30011 views
  • Likes 9 likes
  • Comments 11 comments
Dimmer circuits consisting of Phase Angle Control are used to efficiently adjust the AC power delivered to the AC loads by controlling the conduction angle. In this episode, Surbhika developed such a circuit to enable dimming of commonly used AC lights bulbs at home. This was an interesting DIY project as it meant realizing one of the fundamental concepts in power electronics and control theory to generally usable hardware.
Watch the Video:
Bonus Content:
  • Download Code!
image image
Bill of Materials
RASPBERRY-PI Raspberry Pi Pico Board, RP2040, 32 bit, ARM Cortex-M0+ RASPBERRY-PI 2 Buy Now
MULTICOMP PRO TERMINAL BLOCK EUROSTYLE, 2 POSITION, 26-16AWG MULTICOMP PRO 5 Buy Now
ONSEMI Optocoupler, Triac Output, DIP, 6 Pins, 5.3 kV, Non Zero Crossing, 400 V ONSEMI 1 Buy Now
VISHAY Optocoupler, Transistor Output, 1 Channel, DIP, 4 Pins, 50 mA, 5.3 kV, 160 % VISHAY 1 Buy Now
WEEN SEMICONDUCTORS Triac, 800 V, 16 A, TO-220AB, 1.5 V, 170 A, 45 mA WEEN SEMICONDUCTORS 1 Buy Now
BOURNS LINEAR POTENTIOMETER, 10KOHM, 20%, 50mW BOURNS 1 Buy Now
PHILIPS LIGHTING LED Light Bulb, Reflector, GU10, Warm White, 3000 K, Dimmable, 36° PHILIPS LIGHTING 1 Buy Now
ETERNA GU10 Lampholder with Flying Leads ETERNA 1 Buy Now
LEDVANCE LED Light Bulb, Reflector, GU10, Daylight White, 6500 K, Not Dimmable, 36° LEDVANCE 1 Buy Now
element14 presents  |  About Surbhika |  Project Videos
  • AC power control
  • ac dimmer
  • home automation
  • raspberry pi pico
  • Dimmer switch
  • power control
  • triac
  • optocoupler
  • Light dimming
  • raspberry pi
  • circuit design
  • Phase angle control
  • electrical engineering
  • energy efficiency
  • e14p_SR
  • diy electronics
  • friday_release
  • pi pico
  • michaelkellett
    michaelkellett over 3 years ago +3
    The subject is interesting (although some discussion of EMC issues would be helpful) but the bench practice is life threateningly dangerous. Main voltages should never be applied to a breadboard operated…
  • surbhika
    surbhika over 3 years ago in reply to Workshopshed +1
    No the optocoupler IC does the isolation. I see the confusion arises due to the improper symbol of SFH628A. Thanks for pointing that out! It should be like this (as given in the datasheet):
  • Jaganhalo
    Jaganhalo over 3 years ago
    Once I probed an AC test point with Oscilloscope and let's just the MCB saved the day, I see you are using some tool. Is it a differential Probe?
    It would be nice if you highlighted this, not a lot of people know that the Oscilloscope Neutral and earth are shorted internally.
  • Jaganhalo
  • surbhika
    surbhika over 3 years ago in reply to Jaganhalo
    We have all been there when MCB saved the day. Yeah now that you have said it, I 'm realizing I should have mentioned this. But there were not many components in the circuit and i was doing all the measurements with respect to neutral terminal only. So it didn't make any difference even if I used differential probe.
