Project Videos
  • Project Videos
Project Videos
Documents Create Your Own Air Hockey Table with Arduino Scoring -- Episode 603
  • Date Created: 10 May 2023 4:57 PM Date Created
  • Last Updated Last Updated: 19 May 2023 7:24 AM
  • Views 38257 views
  • Likes 10 likes
  • Comments 13 comments
Follow along as Lorraine builds a project straight from her childhood: an air hockey table! Using her 3d printing, laser cutting, and electronics skills, Lorraine recreates the game to play air hockey with her family.
Watch the Video:
Bonus Content:
  • Download Schematics, 3D Printer Files, Laser Cut Files, and Code!
Bill of Material:
Arduino Uno ARDUINO 1 Buy Now
20mm machine screw m3 TR FASTENINGS 12 Buy Now
10mm machine screw m3 TR FASTENINGS 16 Buy Now
m3 nuts TR FASTENINGS 28 Buy Now
7 segment display MULTICOMP PRO 1 Buy Now
CNY70 phototransistor VISHAY 2 Buy Now
Male to female jumper wires MULTICOMP PRO 26 Buy Now
Male to male jumper wires MULTICOMP PRO 6 Buy Now
Additional Parts:
3mm laser plywood
3mm laser acrylic
3D printed puc and paddles
element14 presents
element14 presents  |  About Lorraine |  Project Videos
  • e14p_LU
  • 3dprinter
  • Air hockey
  • arcade
  • laser cutter
  • childhood games
  • arcade games
  • 3dprinting
  • electronics
  • friday_release
  • laser cutting
    beacon_dave over 3 years ago in reply to lorrainbow
    Tim's already made a machine on zombies so that perhaps leaves you with cookie monsters, or perhaps something to do with rainbows ? Could incorporate a prism and some movable mirrors in there perhaps. Although vending a mini cookie as a prize might be more popular (vending pots of gold would also be popular I suspect but could get rather expensive...)
    There is a second arcade in London so that's two you need to get to Slight smile
  • lorrainbow
    lorrainbow over 3 years ago in reply to beacon_dave
    Yeah, I had a few ideas for the blower... hairdryer, hoover, the blower that blows up an air mattress.... but for unknown reasons I was in a rush to finish this project! Probably cause it was sat on my desk for so long. The laser cutter air pump was nearby, and it worked so that's what I went with.
  • lorrainbow
    Love that series. I really need to get to that arcade!
  • lorrainbow
    lorrainbow over 3 years ago in reply to kmikemoo
    Part of the workout surely!
  • rmd6502
    rmd6502 over 3 years ago
    I'd guess that a hand in front of the goal and other light changes would be more gradual than the puck passing through the goal, so some sort of high pass filter algo would probably improve accuracy
    DAB over 3 years ago
    Fun build.
    You could probably improve the airflow in the box by simply running a bead of caulk between the inside of the base and the walls and by using some tape over the joins between the curved corners and the walls. As all this is inside the box, it won't be visible from the outside. The top could sit on some sort of a soft gasket if you want it to be removable to access the electronics inside.
    By doing so it should allow you to scale down the size of the blower a bit.
    Some of the arcade machines along the lines of those made by Tim Hunkin at the 'Under the Pier Show' could be a fun project.
    https://www.underthepier.com/
    Whilst we are on the subject, series three of the 'Secret Life of Components' is out
    https://www.youtube.com/watch?v=Za-GyTt729M
    • Pneumatics
    • Hole Cutting
    • Solenoids and Relays
    • PLCs
    For the goal sensor you could perhaps use a vertical piece of laser cut Perspex. Have it tapered from top to bottom so that at the top it starts off at the same width as the goal line and at the bottom it ends up the width of your photosensor.
    Additionally if you light the goal line from the underside of the goal arch you may be able to get more consistent light readings irrespective of changes in ambient.
    This could be added as a part of a goal backstop to catch the puck.
    Could you put some graphics under the top and under-light so it looks like they are below the 'ice' ?
