Project Videos
  • Project Videos
Project Videos
Documents From Strava to Motion: Creating an Arduino-Powered Arcade Game with Running Data -- Episode 607
  • Date Created: 13 Jun 2023 1:11 PM Date Created
  • Last Updated Last Updated: 16 Jun 2023 7:24 AM
  • Views 25111 views
  • Likes 9 likes
  • Comments 25 comments
Following on from building an air hockey table, Lorraine is recreating another classic arcade game: the Derby. Instead of horses racing along a track, it will be runners! Find out how to download your running data from strava and move a runner along a track in competition with your family and friends. This project involves a bit of everything: 3d printing, laser cutting, coding in C and using motors with the Arduino Wifi board.
Watch the Video:
Bonus Content:
  • Registration Required:  Download Code  (Register to become a Member!)
  • Registration Required:  Download CAD Files   (Register to become a Member!)
Bill of Materials
DFROBOT Micro DC Motor, TT Geared, Encoder, 6V, 160RPM, 120:1, L Shape, Arduino Board DFRobot 4 Buy Now
Expansion Board, Quad DC Motor Driver Shield, Arduino Development Board DFRobot 1 Buy Now
Microswitch, Miniature, Long Hinge Lever, SPST-NO, Quick Connect, 16 A, 8 V Omron 4 Buy Now
Single Board Computer, Arduino Uno WiFi, ATmega328P, 14 I/O, 48KB Flash, 6144Bytes SRAM, 256Bytes Arduino 1 Buy Now
Rocker Switch, On-Off, SPST, Non Illuminated, Panel Mount, Black, PRA TE Connectivity 1 Buy Now
DC Power Connector, Socket, 2.1 mm, Chassis Mount, Solder Pro Signal 1 Buy Now
AC/DC Power Supply, Level VI, 1 Output, 15 W, 5 VDC, 3 A Multicomp 1 Buy Now
Pin Header, Right Angle, Board-to-Board, 2.54 mm, 1 Rows, 6 Contacts, Through Hole Right Angle AMP - TE CONNECTIVITY 1 Buy Now
Jumper Wire Kit, Male to Female, Multi-Coloured, 200 mm, 0.1" Dupont Connector, 0.2 mm² Multicomp 1 Buy Now
Additional Parts:
3mm laser acrylic for box, supports and runners
3d printed pulleys
3d printed supports for motors and runners
Timing belt 6mm, 640mm long x 4
element14 presents
element14 presents  |  About Lorraine |  Project Videos
  • e14p_LU
  • arduino uno
  • 3dprinter
  • strava
  • the derby
  • arcade
  • laser cutter
  • childhood games
  • arcade games
  • 3dprinting
  • strava API
  • DF Robot
  • electronics
  • friday_release
  • laser cutting
  • running
  • RoRo87
    RoRo87 over 2 years ago +1
    Why are the Download Elements not available?
    beacon_dave over 2 years ago in reply to RoRo87 +1
    Code: /challenges-projects/element14-presents/m/files/147743 CAD: /challenges-projects/element14-presents/m/files/147744
  • RoRo87
    RoRo87 over 2 years ago in reply to tmazer +1
    I can't give you a answer because i didn't tried it out.But i wouldn't do it with strava.I prefer to build it with roll-a-ball like the original horse race but a little bit smaller.
  • colporteur
    colporteur over 1 year ago
    Great share!
  • Mikeatencio
    Mikeatencio over 2 years ago in reply to RoRo87
    Where is the original horse racing game located at? That's what I want.
  • RoRo87
  • tmazer
    tmazer over 2 years ago
    Is it possible the API has changed since then? I tried replicating on my arduino nano 33 iot, and sadly when running the getAccessCodes.ino program, I always get the following printout:
    Status code: -2
    Response:
    Runner 1's refresh code: null
    I followed the process of getting the runner code from "Bonus Content" video. Status code -2 seems to suggest that the server timed out.
    Code:
    CAD:
  • RoRo87
  • Mikeatencio
    I want it like the original game with horses. However, I'd love to add a simple pinball machine to it. Every time the ball is shot, it comes back down through one of three slots, 1, 2, or 3 points depending which slot it came down through. No draining, Ya just keep shooting until there's a winner then the game turns off. I'd like to make it bigger and longer if that's possible. Last thing, I tried to print the parts but they break easily when I'm trimming the flash away. I've reprinted them once. How many do I need of the printed parts to make it work? Please do a revamp of this with a simple pinball game and maybe metal tape to act like sensors to count the ball as it goes through the chute. That acts as a counter. Thanks
    Mike
    beacon_dave over 3 years ago in reply to lorrainbow
    Just need an automatic system to get the parents into their running shoes and out of the door now Slight smile
    Yeh, that was my first thought when I saw it. Anyone trying to modify the code is likely to over run the track at some point due to reliance on software. A bit like when people build their own H bridges on the cheap, eventually they will short circuit the transistors. Hence using limit switches with hardware control would protect the mechanism from programming errors.
    Some of the systems I've worked on in the past had three separate levels of safety. There were limit switches under software control for normal operation. There were limit switches under hardware control that would prevent further software control in one direction but would still allow reversing. Then there was a third layer that killed all power to the motor controllers should the motor still continue to run past the defined limit.
    There is more tactile involvement with rolling a ball I think. Also a bit more uncertainty in getting the ball into the best pocket. However there is a tendency to lose things if they aren't physically attached.
    I guess you could revisit your coloured ball through a basketball hoop project so that you have to match the ball colour to a hole colour to score higher.
    Any project using balls up a slope will likely be bulky though and require some element of levelling before use, which is why I suggested a virtual ball roll instead. Also if doing a networked game then a free ball setup would be too easy to cheat with unless you had machine vision to detect cheating.
