Project Videos
  • Project Videos
Project Videos
Documents From Strava to Motion: Creating an Arduino-Powered Arcade Game with Running Data -- Episode 607
  • Date Created: 13 Jun 2023 1:11 PM Date Created
  • Last Updated Last Updated: 16 Jun 2023 7:24 AM
  • Views 25124 views
  • Likes 9 likes
  • Comments 25 comments
Following on from building an air hockey table, Lorraine is recreating another classic arcade game: the Derby. Instead of horses racing along a track, it will be runners! Find out how to download your running data from strava and move a runner along a track in competition with your family and friends. This project involves a bit of everything: 3d printing, laser cutting, coding in C and using motors with the Arduino Wifi board.
Watch the Video:
Bonus Content:
  • Registration Required:  Download Code  (Register to become a Member!)
  • Registration Required:  Download CAD Files   (Register to become a Member!)
Bill of Materials
DFROBOT Micro DC Motor, TT Geared, Encoder, 6V, 160RPM, 120:1, L Shape, Arduino Board DFRobot 4 Buy Now
Expansion Board, Quad DC Motor Driver Shield, Arduino Development Board DFRobot 1 Buy Now
Microswitch, Miniature, Long Hinge Lever, SPST-NO, Quick Connect, 16 A, 8 V Omron 4 Buy Now
Single Board Computer, Arduino Uno WiFi, ATmega328P, 14 I/O, 48KB Flash, 6144Bytes SRAM, 256Bytes Arduino 1 Buy Now
Rocker Switch, On-Off, SPST, Non Illuminated, Panel Mount, Black, PRA TE Connectivity 1 Buy Now
DC Power Connector, Socket, 2.1 mm, Chassis Mount, Solder Pro Signal 1 Buy Now
AC/DC Power Supply, Level VI, 1 Output, 15 W, 5 VDC, 3 A Multicomp 1 Buy Now
Pin Header, Right Angle, Board-to-Board, 2.54 mm, 1 Rows, 6 Contacts, Through Hole Right Angle AMP - TE CONNECTIVITY 1 Buy Now
Jumper Wire Kit, Male to Female, Multi-Coloured, 200 mm, 0.1" Dupont Connector, 0.2 mm² Multicomp 1 Buy Now
Additional Parts:
3mm laser acrylic for box, supports and runners
3d printed pulleys
3d printed supports for motors and runners
Timing belt 6mm, 640mm long x 4
element14 presents
element14 presents  |  About Lorraine |  Project Videos
  • e14p_LU
  • arduino uno
  • 3dprinter
  • strava
  • the derby
  • arcade
  • laser cutter
  • childhood games
  • arcade games
  • 3dprinting
  • strava API
  • DF Robot
  • electronics
  • friday_release
  • laser cutting
  • running
  • RoRo87
    RoRo87 over 2 years ago +1
    Why are the Download Elements not available?
    beacon_dave over 2 years ago in reply to RoRo87 +1
    Code: /challenges-projects/element14-presents/m/files/147743 CAD: /challenges-projects/element14-presents/m/files/147744
  • RoRo87
    RoRo87 over 2 years ago in reply to tmazer +1
    I can't give you a answer because i didn't tried it out.But i wouldn't do it with strava.I prefer to build it with roll-a-ball like the original horse race but a little bit smaller.
    dougw over 3 years ago
    Outstanding idea and build. Obviously it could be used in many applications and even more with a few software tweaks. I'm sure I'm not the only one thinking about what I would do with such a machine.
    beacon_dave over 3 years ago
    To make it multifunctional you could perhaps create a user interface to it so as you can play the original Derby type arcade game when not viewing Strava running data. To take it one step further you could make it networked a Derby game by being able to link multiple games units over the Internet. The user interface could either be like the traditional balls into pockets game or perhaps a touch screen interface. Could perhaps even try a haptic device where the longer you hold a ball-shaped button down, the greater the force feedback gets before you release, creating a virtual ball roll.
    I guess there is also potential to turn it into a more generic linear display indicator type device. It should scale up quite well for use in larger displays, especially outdoors where other displays may not be suitable.
    DAB over 3 years ago
    Fun build, you could also set this up for monitoring academic challenges, book reading, household chores, all kinds of things.
    You could perhaps try using some springs to apply a little bit of tension the belts seeing as you have adjustment slots at one end.
    Perhaps could use some cable clips/ties to secure the cables to the base plate. You can get clips with sticky fixers which are quick and simple but they tend to dry out and  fail after a while. However as you are laser cutting, then you could cut some holes in nice straight lines at an even spacing to keep it neat and tidy. Could also cut a groove to lay them into with dabs of hot glue to secure. (Health and safety first - don't want your runners tripping over cables)
    The movement of the runners is looking pretty smooth.
  • donnersm
    donnersm over 3 years ago
    So when there is a winner...al participants get an email  or text saying they lost?   whaa...That would be nice too.  But I love the idea of runners on display. I love office gadgets and I think I can do something with this...like connect it to mouse clicks bewteen me and my co workers
