Project Videos
  • Project Videos
Project Videos
Documents Making the Simplest DIY Wind Energy Generator - How Hard Could it Be? -- Episode 608
  • Date Created: 13 Jun 2023 5:18 PM Date Created
  • Last Updated Last Updated: 23 Jun 2023 7:24 AM
  • Views 28012 views
  • Likes 8 likes
  • Comments 11 comments
How do you power a project in the middle of nowhere? Solar is not the only option, and in rough climates wind might be equally as viable. Clem has a little piece of land he would like to use as testing ground for various projects, so he tries to build the simplest and smallest wind generator suitable to power an IoT project. Using a DC motor as a generator, mishandling rectifier circuits and charging caps. How hard could it be to harvest the power of wind?
Watch the Video:
Bonus Content:
  • Login Required: Download CAD files and Schematics  (Register to become a Member!)
  • Maxon Guide to Use Motors as Generator
Bill of Material:
MAXON MOTOR DC Motor, A-Max 32, Graphite Brushes, Brushed, 6000 rpm, 39.1 mN-m, 15 W, 32 mm Maxon motor 1 Buy Now
1n4007 Diode multicomp pro 4 Buy Now
Fixed LDO Voltage Regulator, 2.1V to 6V, 210mV Dropout, 3.3Vout, 500mAout, TO-220-3 microchip 1 Buy Now
Electrolytic Capacitor, Miniature, 4700 µF, 16 V, ± 20%, Radial Leaded, 2000 hours @ 85°C, Polar rubycon 10 Buy Now
Additional Parts:
Mayer Makes Engineering Resin for 3d printed parts
M8 threaded rod
2 Skateboard bearings
Polypropylen foil
Screws, nuts and washers. M8 and M3
element14 presents
element14 presents  |  About Clem  |  Project Videos
  • off grid
  • energy harvesting
  • How To
  • wind generator
  • diy generator
  • solar
  • friday_release
  • e14p_CMM
  • stevethackery
    stevethackery over 3 years ago +1
    Hang on, those blades don't seem right. It is important to decide whether you are aiming for a rotor that uses lift, or one that uses drag. The latter, known as the Savonius, has an assymetric appearance…
    beacon_dave over 3 years ago
    Perhaps has some potential for a novelty garden windmill/spinner kinetic sculpture of some sort ?
    Traditionally they tend to be wood choppers, or winding a well winch handle but I guess with a electric generator then there are some new hi-tech options.
    An eInk display could be updated to show messages and it wouldn't matter if there were days with no wind as it could just stay displaying the last update.
    Some low power LED lighting could be used to brighten up garden spinner on a dull but windy day, or in the darker winter evenings.
    POV type display on the rotating blades displaying speed / direction etc. or message received over LoRa.
