Project Videos
  • Project Videos
Project Videos
Documents How to Build an Open Source Bluetooth Mechanical Keyboard -- Episode 619
  • Date Created: 6 Sep 2023 9:05 PM Date Created
  • Last Updated Last Updated: 7 Sep 2023 11:00 PM
  • Views 16365 views
  • Likes 12 likes
  • Comments 19 comments
In this video, Clem creates a truly unique and open-source wireless keyboard from scratch. He emphasizes the importance of customization for true keyboard enthusiasts. Starting with the choice of mechanical switches, Clem opts for flat low profile KS27 Gateron Blue switches , showcasing his passion for the tactile feedback of mechanical keyboards.
Watch the Video:
Clem uses KiCad to design a custom PCB. Bluetooth connectivity is achieved by utilizing an ESP32-S3 as the main MCU. USB-C acts as the charging port and Serial output. 4 colorful LEDs provide feedback about the current state of the Keyboard and visually indicate if SHIFT-Alt/AltGr or SUPER/FN/GUI are pressed. The keyboard therefore has 4 freely programmable layers available for heavy customization.
To ensure modularity, Clem integrates a flexible interconnect system between two PCBs, one holding the keyboard switches and the other housing the LiPo charging circuit. Both PCBs are interconnected via a universal bus, broken out on a Molex Premo-Flex connector and connected with a simple flat flex ribbon cable. The Premo-Flex connectors break out all power traces and UART connections so the keyboard can easily be used in future projects. He even offers the option for hot-swappable switches, making it adaptable to various preferences.
The keycaps of this keyboard are unique, designed in FreeCAD to accommodate the low-profile switches. Clem prints them with raised letters and symbols on the inside for durability and visibility, even after extensive use.
Finally, Clem dives into the firmware, which he codes from scratch using the Arduino IDE, with the help of the ESP32-BLE keyboard library and the Adafruit keypad library. The code allows for easy customization of the keyboard layout, providing a personalized typing experience. He also adds LED indicators for modifier keys, enhancing the user experience.
One of the distinctive features of Clem's keyboard is its low-profile design, akin to laptop keys, resulting in a compact layout of around 60 keys. He also combines elements from both English and German keyboard layouts to suit his daily needs. The keyboard is powered by a LiPo battery with onboard charging circuit.
Despite facing challenges, like voltage drop issues with LEDs, Clem perseveres and successfully creates an open-source Bluetooth keyboard with a custom layout, 3D-printed keycaps, and unique lighting features.
Bonus Content:
  • GitHub:  https://github.com/mayermakes/00Keyboard
  • Download Code, ECAD and CAD
Bill of Material:
MULTICOMP PRO Zero Ohm Resistor, Jumper, 0603 [1608 Metric], Thick Film, 100 mW, 1 A, Surface Mount Device Multicomp pro 60 Buy Now
BOURNS Small Signal Schottky Diode, Single, 40 V, 300 mA, 500 mV, 2 A, 125 °C BOURNS 60 Buy Now
MOLEX USB Connector, USB Type C, USB 3.1, Receptacle, 24 Ways, Surface Mount, Right Angle MOLEX 1 Buy Now
STMICROELECTRONICS ESD Protection Device, 17 V, SOT-23, 6 Pins, USBLC STMICROELECTRONICS 1 Buy Now
MOLEX FFC / FPC Cable, Premo Flex Jumper, 10 Core, 1 mm, Same Sided Contacts, 6 ", 152 mm, White MOLEX 1 Buy Now
MOLEX FFC / FPC Cable, Premo Flex Jumper, 10 Core, 1 mm, Same Sided Contacts, 2 ", 51 mm, White MOLEX 1 Buy Now
MOLEX FFC / FPC Board Connector, 1 mm, 10 Contacts, Receptacle, Easy-On 52207, Surface Mount, Top MOLEX 1 Buy Now
MOLEX FFC / FPC Board Connector, ZIF, 1 mm, 10 Contacts, Receptacle, Easy-On 52271, Surface Mount, Bottom MOLEX 1 Buy Now
MIKROELEKTRONIKA Rechargeable Battery, 3.7 V, Lithium Polymer, 2 Ah, JST MIKROELEKTRONIKA 1 Buy Now
Additional Parts:
ESP32-S3-Wroom1
Keycaps 3d printed with MAYER MAKES ENGINEERING RESIN + Blue Dye
PCB provided by Aisler.net use code „thanks_mayermakes_23“ for a discount.
Switches used are Gateron Blue KS27,  sockets are random parts i found by searching for the switches.
element14 presents
element14 presents  |  About Clem  |  Project Videos
  • Low-profile keyboard
  • firmware development
  • Personalized typing experience
  • no qmk
  • keyboard
  • Keycap customization
  • ESP32 S3 microcontroller
  • Wireless keyboard project
  • Maker's journey
  • 3D-printed keycaps
  • Keyboard layout customization
  • diy bluetooth keyboard
  • Mechanical switches
  • Electronics project tutorial
  • DIY form scratch
  • mechanical keyboard
  • mechanical keyboard diy
  • friday release
  • DIY keyboard
  • Custom PCB design
  • friday_release
  • eps32s3
  • Open-source Bluetooth keyboard
  • Keyboard enthusiast
  • keyboard firmware
  • e14p_CMM
  • scottiebabe
    scottiebabe over 3 years ago +3
    I'll let you in on a little secret from the cheapskate queen. Search "bargains" on newark.com A few years ago you would see nothing but the "Red Stars" then just choose something close enough for your…
  • mayermakes
    mayermakes over 3 years ago +1
    Don't forget to watch the 3 bonus video if you are interested in the details of each section! What keyboard layout is your favourite?
  • kmikemoo
    kmikemoo over 3 years ago +1
    mayermakes Really cool keyboard. I really like that the key symbols will never wear off! That's brilliant.
    beacon_dave over 2 years ago in reply to tibault1
    Try this link to the project resources page:
    /challenges-projects/element14-presents/m/files/148196
     and click the blue Download button top right.
    ( tariq.ahmad  looks like the link to the resources needs updating )
  • tibault1
    tibault1 over 2 years ago
    how can i get the code
  • temyra
    temyra over 3 years ago in reply to mayermakes
    Thanks a lot for prompt answer.
    My idea it's use it with smart tv wi-fi and ipad or other smartpad/phone via BLE.
    Thanks again and see you next
  • mayermakes
    mayermakes over 3 years ago in reply to temyra
    sure thats just a matter of code. only wifi and bluetoot hat the same time are not possible for now I think.
  • temyra
    An amazing interesting project.
    Do you think possible to switch beetween wi-fi or bluetooth methode to use it in smart tv i.e.?
    Thanks a lot and see you next
  • mayermakes
    mayermakes over 3 years ago in reply to DAB
    thanks,
    the keycaps are exactly the same size as any regular key. i also thought that the ortholinear layout would be hard to get used to, but actually the staggered layout is much more unnatural in movement. according to some "touch typist" tests iǘe seen on youtube, it takes a little time to get used to it, but the differences are so minute that it does not matter, much also switching back and forth seems not to be an issue for most people.
    it just a matter of preference.
    some sources claim that ortholinear keyboards enable faster typing . it allows punching in style like on the numpad/ a desk calculator..whic hI did for ten years daily..so its not hard for me to imagine i will quickly get up to speed on an ortholinear board.
    DAB over 3 years ago
    Nice build, but my fingers are probably too big to use it.
    Plus I learned to type back when we had mechanical typewriters, so the stagger is very important for speed typing.
  • mayermakes
    mayermakes over 3 years ago in reply to iLikeDarbo
    great ,thanks for the link!
  • iLikeDarbo
    iLikeDarbo over 3 years ago
    Great project Clem and thanks for sharing!
    For keycaps, there is a great OpenSCAD tool put together by riskable. It's on github at Keycap Playground
    The keycaps are fully customisable and there are presets for different profiles and switch stems
  • mayermakes
    mayermakes over 3 years ago in reply to kmikemoo
    thanks, i hope to experiment further on this subject to make the more readable maybe with a backfilling.
