Project Videos
  • Project Videos
Project Videos
Documents Creating an IMU based 3D Mouse with an ESP32-S3 -- Episode-636
  • Date Created: 4 Jan 2024 3:18 PM Date Created
  • Last Updated Last Updated: 22 Jan 2024 5:01 PM
  • Views 12306 views
  • Likes 11 likes
  • Comments 46 comments
Clem, driven by curiosity and the age-old wisdom of "you won’t know until you try", embarked on a quest to create a mouse with a motion sensor, or more precisely, an inertial measurement unit (IMU). Wondering why major manufacturers hadn't explored this avenue, he pondered the potential of leveraging IMUs, given the success of smartphones and game controllers in spatial movement tracking.
Watch the Video:
Equipped with an MPU6050 MEMS accelerometer, an ESP32S3 for Bluetooth connectivity, and a reliable battery charging circuit, Clem jumped into the design process. Drawing inspiration from a classic Logitech BT83 mouse, Clem meticulously crafted a board in KiCad to fit a familiar mouse-shaped shell. In fact, the project came to mind when the BT83 he’d been using for the past two decades started misbehaving, a problem caused by a worn-out cable, which was easily fixed in an afternoon.  After receiving the PCB from Aisler, Clem quickly soldered all the SMD parts to the board and proceeded to check if the MPU6050 was recognized over I2C. The unit successfully booted and after flashing a modified I2C_detect example, revealed that a device was detected at address 0x68, the expected default ID of the MPU6050!  However, the success was short-lived; checking readout examples showed that the IMU was only recording zeroes. Investigation with other libraries and raw sensor stat reports pointed to the culprit being most likely not a software error, but a damaged sensor. After consulting online makers, Clem pinpointed the culprit—a likely impact during the ultrasonic cleaning process, damaging the delicate MEMS device.
Undeterred, Clem replaced the damaged chip with a new one from Farnell. Taking a cautious approach, he opted for a sensitive PCB cleaning method, utilizing a toothbrush dipped in Isopropanol. Yet, the challenges didn't end there; Clem still faced the formidable task of deriving lateral motion from angular velocity, acceleration, and gyroscopic movement.
The next hurdle came in form of complex mathematics. In theory, deriving lateral motion from angular velocity and acceleration, as well as gyroscoping movement, can be done by recording a range of values over time and using a not-so-simple formula to analyze the changes. The formulas involve integrals of integrals, with a side-effect of yielding extremely big numbers that crashes the MCU.
After scouring the web for solutions, Clem discovered that while possible, the practical approach involved using two superior IMUs or offloading data processing to a desktop PC—beyond the scope of his project. This underscored why major manufacturers steer clear of relying on IMUs for mouse tracking; it's intricate, calculation-intensive, and less accurate.
After a quick chat with fellow host Katie, Clem pivoted to a new design inspired by the trackpoint on IBM/Lenovo laptops. He took advantage of the MPU6050_light library for Arduino to design a circular red mouse with two buttons, highlighting the ease of building a 3D air mouse compared to the challenges of creating a "simple" mouse with an IMU. Clem's journey showcased the complexities and unexpected turns that innovation often entails.
Downloads and Links:
  • Download CAD Files, Code, and Schematics!
  • Paper about the challenge of tracking lateral movement with IMU
Bonus Video:
Bill of Material:
Product Name Quantity Buy Kit
TDK INVENSENSE MPU-6050 1 Buy Now
DIODES INC. AP9101CK-AHTRG1 1 Buy Now
STMICROELECTRONICS USBLC6-2SC6 1 Buy Now
MOLEX 105450-0101 1 Buy Now
MICROCHIP MCP73831T-2ACI/OT 1 Buy Now
Additional Parts:
Case made with MAYER MAKES Engineering Resin https://lectronz.com/products/mayer-makes-engineering-resin-extreme-strength-1kg
USE CODE : „ELEMENT14“ for a 10% Discount for Element14 community members.
element14 presents
element14 presents  |  About Clem  |  Project Videos
  • Arduino Mouse Project
  • Bluetooth Air Mouse
  • Inertial Measurement Unit Mouse
  • Mouse Design
  • Electronic DIY Innovation
  • MPU6050 Mouse
  • Logitech BT83 Inspired Mouse
  • Maker Electronics
  • DIY Mouse Project
  • 3D Air Mouse Design
  • Open Source Electronics
  • IMU Sensor Innovation
  • Trackpoint Inspired Mouse
  • PCB Design for Mouse
  • Motion Sensor Mouse
  • friday_release
  • e14p_CMM
    Jan Cumps over 2 years ago
    Anyone considered a mouse that you can mount under your shoe?
    Let me quickly go get a worldwide patent ...
  • mayermakes
    mayermakes over 2 years ago in reply to Jan Cumps
    iḿ courious for that usecase...there might actually be one.
    genebren over 2 years ago in reply to Jan Cumps
    I had a friend that developed a sliding platform (with an embedded mouse) that he used to mouse around the screen with his feet.  This was very helpful when he was doing other things with his hands, like holding an oscilloscope probe or working with knobs on a piece of equipment.  Not a polished design, but it did basically work.
    I have seen multiple uses for foot switches in manufacturing situations where an operator could trigger an event with their feet.
    So, this is not a completely crazy idea, just maybe just a solution to a narrow problem set.
    Jan Cumps over 2 years ago in reply to genebren
    I worked in an automotive factory. Heavy machines (like presses) were usually operated by two hand switches and one foot switch. The hand switches (left and right mounted away from the action) were there, to ensure that the operators had their hands at a safe location, away from the press.. The foot switch was there because they had no hands left to actually activate the machine.
    Jan Cumps over 2 years ago in reply to Jan Cumps
    > " go get a worldwide patent ..."
    I'll have to keep my current job. https://en.wikipedia.org/wiki/Footmouse
    beacon_dave over 2 years ago in reply to Jan Cumps
    That was so '60s Slight smile
    There was also the knee input device amongst others:
    https://www.dougengelbart.org/content/view/162/#5
    beacon_dave over 2 years ago in reply to mayermakes
    Just one ? There will be several.
    One is when you need to constantly switch between typing at a keyboard to using a mouse (or two mouses) for navigation/selecting. For 3D CAD you might have SpaceMouse in one hand, and a mouse in the other hand so you can quickly target an insertion point but then darn you now need the keyboard to type in a textual or numeric information, then return back to the mouses for the next insertion point.
    Patenting is sometimes harder than it looks. According to the Wikipedia page about the first rolling ball mouse:
    "...Anecdotal reports claim that Telefunken's attempt to patent the device was rejected by the German Patent Office due to lack of inventiveness..."
  • mayermakes
    mayermakes over 2 years ago in reply to beacon_dave
    the patent office back then actually cared if its even an invention, my current impression is they only look for propperly filled out forms and the paid fee...if anyone easily takes it down with a counterclaim orlack of susbtance/infringement on other IP/patents that is the patent holders problem to defend.
    Jan Cumps over 2 years ago in reply to mayermakes
    Yes, looks like they turned into registration offices.
