Project Videos
  • Project Videos
Project Videos
Documents Making a Time-lapse Camera with a Raspberry Pi 5 -- Episode 642
  • Date Created: 15 Feb 2024 5:46 PM Date Created
  • Last Updated Last Updated: 15 Feb 2024 5:49 PM
  • Views 4109 views
  • Likes 10 likes
  • Comments 9 comments
In this episode of element14 presents, Katie introduces a project to create a camera for monitoring a 3D printer. She begins by explaining the challenges she faced with her previous camera, an action cam, which met an unfortunate end due to water damage in a saltwater pool. Katie expresses the need for a new camera to monitor her 3D printer, which is located inconveniently far from her workshop.
To address this, she opts to build her own camera using a Raspberry Pi 5, taking advantage of its improved camera capabilities. Katie details the components she gathered for the project, including the Pi 5, a touchscreen interface, an active cooler, and a High-Quality camera module with the Wide-Angle lens attachment. She emphasizes the importance of a light touchscreen interface for controlling the camera and mentions the advantages of the Raspberry Pi 5, such as its enhanced camera quality and convenient on/off button.
Katie walks through the process of connecting the components, testing the camera, and programming it to capture time-lapse images. She provides a brief overview of the code and its functionalities, including the ability to set time intervals for image capture. Additionally, she explains how the captured images are synced with Nextcloud for easy access.
As the project progresses, Katie encounters a setback when she realizes the need for a the 3D printer will get its own enclosure, as her husband decides to prioritize it for the winter. This prompts a redesign of the camera case to accommodate the printer enclosure. Katie utilizes OpenSCAD and FreeCAD to design a multi-part case that fits the Raspberry Pi, touchscreen, and camera. She successfully prints the parts and assembles the camera within the 3D printer enclosure, achieving her goal of monitoring and capturing time-lapse footage seamlessly.
Bonus Video:
Downloads and Links:
  • Download Code and Files
  • GitHub: https://github.com/hifromkatie/Time-Lapse-Camera_Rpi5
Bill of Material:
RASPBERRY-PI RPI5-8GB-SINGLE RASPBERRY-PI 1 Buy Now
RASPBERRY-PI SC1148 SBC, RPI 5-Accessories, Active cooler, For heavy load, Without case RASPBERRY-PI 1 Buy Now
RASPBERRY-PI SC1154 Power Supply, USB-C, 5.1 V, 5 A, Black, UK Plug RASPBERRY-PI 1 Buy Now
MULTICOMP PRO TS32GUSD420T-MCPMicroSD Card, 32 GB, Raspberry Pi MULTICOMP PRO 1 Buy Now
High Quality Camera, IMX477R, All Raspberry Pi Computer Models from Raspberry Pi 1 Model B Onwards RASPBERRY-PI 1 Buy Now
RASPBERRY-PI SC0947 12MP, 2.7MM WIDE-ANGLE LENS RASPBERRY-PI 1 Buy Now
RASPBERRY-PI SC1129 SBC, RPI 5-Accessories, Adapter cables, Length 300mm, Supports camera RASPBERRY-PI 1 Buy Now
MULTICOMP MC002548 3D Printer Filament, 1.75mm Dia, Green, PLA, 1 kg MULTICOMP 1 Buy Now
PIMORONI PIM369 High Resolution Display, HyperPixel 4.0, Touchscreen, Raspberry Pi PIMORONI 1 Buy Now
element14 presents
element14 presents  |  About Katie Dumont |  Project Videos
  • DIY camera enclosure design
  • Maker's guide to webcam projects
  • e14p_KD
  • IY electronics monitoring
  • Raspberry Pi camera project
  • 3D printer surveillance setup
  • Home-built surveillance solution
  • Homemade camera for workshops
  • Electronics maker blog
  • Customized 3D printer monitoring
  • Homemade time-lapse camera
  • 3D printer time-lapse setup
  • Raspberry Pi 5 projects
  • Electronics engineer insights
  • Raspberry Pi 5 camera tutorial
  • Raspberry Pi camera integration
  • friday_release
    beacon_dave over 2 years ago
    Nice project. I wish I had access to this in the early 2000's when I was doing time-lapse photography and live streaming of outdoor construction projects using IP Cameras. Being able to connect in external sensors for exposure and white balance as well as using sunrise/sunset tables and have them adjust the  camera and capture parameters would have been very useful.
    Have you noticed any significant improvements in the image quality using the R-Pi 5 in this project ? Is it a game changer over say a R-Pi 3 set-up ?
    Lots of talk about the ISP improvements in the R-Pi 5 but I've yet to see the results.
    Image processing on Raspberry Pi 5: our new hardware image signal processor
    https://www.raspberrypi.com/news/image-processing-on-raspberry-pi-5-our-new-hardware-image-signal-processor/
  • hifromkatie
    hifromkatie over 2 years ago in reply to beacon_dave
    The closest I've got to compare with is the Lego camera I made with the hq camera, as that's the only other time I've used this camera sensor. My hunch is that the pictures are sharper and clearer, but I should try taking a picture of the same thing on both to compare properly.
    I was setting up a pi3 on my desk at the same time, (without a camera), and the performance of the 5 Vs the 3 was staggered, loading times were significantly faster
  • hifromkatie
