Project Videos
  • Project Videos
Project Videos
Documents A DJ Harrigan Video: Homemade Retro Digital Wristwatch
  • Author Author: pchan
  • Date Created: 25 Jul 2018 9:00 PM Date Created
  • Last Updated Last Updated: 9 Dec 2018 1:53 AM
  • Views 1184 views
Homemade Retro Digital Wristwatch (Arduino)
Back to DJ Harrigan's VCP Profile |  Arduino
After years of thinking about it, I finally made my own digital watch. Here's the process of how it came to be.
V Watch Code V 1
#include <LedDisplay.h>
#include <TimeLib.h>
#include <Bounce.h>
#include <Metro.h>
#define pinButtonLeft  30
#define pinButtonOk    31
#define pinButtonRight 32
#define dataPin 6              // connects to the display's data in
#define registerSelect 7       // the display's register select pin
#define clockPin 8             // the display's clock pin
#define enable 9               // the display's chip enable pin
#define reset 10               // the display's reset pin
#define displayLength 8        // number of characters in the display
LedDisplay myDisplay = LedDisplay(dataPin, registerSelect, clockPin, enable, reset, displayLength);
Bounce buttonLeft = Bounce(pinButtonLeft, 10);
Bounce buttonOk = Bounce(pinButtonOk, 10);
Bounce buttonRight = Bounce(pinButtonRight, 10);
Metro rtcUpdate = Metro(1000);
String timeHoursString = "00";
String timeMinutesString = "00";
String dateString = " JAN 01 ";
String dowNameString = "SUNMONTUEWEDTHUFRISAT";
String dowString = "ZZZ";
String monthNameString = "JANFEBMARAPRMAYJUNJULAUGSEPOCTNOVDEC";
String hourString = "00";
String minuteString = "00";
String domString = "00";
String monthString = "ZZZ";
String yearString = "0000";
String timerMinutesString = "00";
String timerSecondsString = "00";
String tempVolumeString;
String tempHourString;
String tempMinuteString;
String tempDateString;
String tempMonthString;
boolean isAwake = true;
boolean buttonLeftPressed = false;
boolean buttonOkPressed = false;
boolean buttonRightPressed = false;
boolean timerIsActive = false;
boolean timeIs12Hr = true;
boolean flashState = true;
boolean isSettingTime = false;
elapsedMillis flashRate;
elapsedMillis timerCounter;
int brightness = 1; // screen brightness 0 - 15
int curMode = 1;
int curAction = 1;
int curSelection = 0;
int curTimerMinutes = 0;
int curTimerSeconds = 0;
int lastTimerMinutes = -1;
int lastTimerSeconds = -1;
int curHour = 0;
int lastHour = 0;
int curMinute = 0;
int lastMinute = 0;
int curDow = 0;
int curDay = 0;
int lastDay = 0;
int curMonth = 0;
int lastMonth = 0;
int curYear = 2017;
int monthLengths[] = {31, 28, 31, 30, 31, 30, 31, 31, 30, 31, 30, 31};
void setup() { // be sure to reduce clock speed to a minimum (with USB) to save power
 setSyncProvider(getTeensy3Time);
 // set the time provider to the internal RTC time
  setSyncInterval(3600); //every hour
  pinMode(pinButtonLeft, INPUT_PULLUP);
  pinMode(pinButtonOk, INPUT_PULLUP);
  pinMode(pinButtonRight, INPUT_PULLUP);
  myDisplay.begin();
  myDisplay.setBrightness(brightness); // if time > 7 pm < 7 am set brightness low, else higher
  myDisplay.print("V-Watch");
  delay(1250);
  myDisplay.clear();
  myDisplay.home();
 // Serial.begin(9600);
 getTimeInfo();
 formatTimeInfo();
 lastMinute = curMinute;
} // ************************************************************************ END SETUP ****************************************************************
void loop() {
  switch (curAction){
    case 0: // waiting for input
      getInput();
      if (rtcUpdate.check()){ // check every second
        if (isSettingTime == false){
          getTimeInfo(); // don't update the watch from the RTC while we're adjusting it, gets wonky
          formatTimeInfo();
    break;
    case 1: // update and load time
      myDisplay.clear();
      myDisplay.home();
      myDisplay.setCursor(1);
      myDisplay.print(timeHoursString);
      myDisplay.print(":");
      myDisplay.print(timeMinutesString);
      delay(100);
      curAction = 0; // return to waiting for user feedback
    break;
    case 2: // update  and load date
      myDisplay.clear();
      myDisplay.home();
      myDisplay.print(dateString);
      delay(100);
      curAction = 0;
    break;
    case 3: // update  and load timer
      myDisplay.clear();
      myDisplay.home();
      myDisplay.print("TM   :");
      myDisplay.setCursor(3);
      myDisplay.print(timerMinutesString);
      myDisplay.setCursor(6);
      myDisplay.print(timerSecondsString);
      delay(100);
      curAction = 0;
    break;
  } // ************************************************************************ END ACTION SWITCHCASE
  switch (curMode){
    case 0: // asleep
    break;
    case 1: // display time
      if (buttonLeftPressed){
        curMode = 3;
        curAction = 3; //enter timer mode
      if (buttonOkPressed){
        curMode = 4;
        curAction = 0; //enter set time mode
        isSettingTime = true;
      if (buttonRightPressed){
        curMode = 2;
        curAction = 2; //enter date mode
      if (lastMinute != curMinute){
        curAction = 1;
    break;
    case 2: // display date
        curMode = 1;
        curAction = 1; //enter time mode
        curMode = 5;
        curAction = 0; //enter set date mode
        curMode = 3;
    break;
    case 3: // display timer
        curMode = 2;
        curMode = 6;
        curAction = 0; //enter set timer mode
        curMode = 1;
      if (timerIsActive){ // timer only decrements in timer mode, could be changed to be universal
        if (timerCounter > 1000){
          curTimerSeconds-=1;
          if (curTimerSeconds < 0 && curTimerMinutes >= 1){
            curTimerSeconds = 59; curTimerMinutes-=1;
          if (curTimerSeconds < 0 && curTimerMinutes == 0){
            timerIsActive = false; // times up!
          formatTimerMinutes();formatTimerSeconds();
          timerCounter = 0;
    break; // ************************************************************************ END DISPLAY MODES
    case 4: // set time
      if (curSelection == 0){ // set hours
          curHour--;
          if (curHour < 0) curHour = 23;
          curSelection = 1;
          flashState = true; // lock in so that the display remains on here
          delay(100); // allow finger release time
          flushInput();
          curHour++;
          if (curHour > 23) curHour = 0;
        if (lastHour != curHour){
          lastHour = curHour;
          formatTimeInfo();
        if (flashRate > 250){
          if (flashState){
          } else {
            myDisplay.print("  ");
          flashRate = 0;
          flashState = !flashState;
      if (curSelection == 1){ // set minutes
          curMinute--;
          if (curMinute < 0) curMinute = 59;
          curMode = 1;
          curSelection = 0;
          flashState = true;
          myDisplay.setCursor(4);
          setTime(curHour, curMinute, 0, curDay, curMonth, curYear);
          Teensy3Clock.set(now());
          curMinute++;
          if (curMinute > 59) curMinute = 0;
          formatTimeInfo();
          if (flashState){
          } else {
          flashRate = 0;
    break;
    case 5: // set date
      if (curSelection == 0){ // set month
          curMonth--;
          if (curMonth < 1) curMonth = 12;
          curSelection = 1;
          myDisplay.print(monthString);
          flushInput();
          curMonth++;
          if (curMonth > 12) curMonth = 1;
        if (lastMonth != curMonth){
          lastMonth = curMonth;
          formatTimeInfo();
          if (flashState){
          } else {
          flashRate = 0;
      if (curSelection == 1){ // set day
          curDay--;
          if (curDay < 1) curDay = monthLengths[curMonth-1];
          curMode = 2;
          curSelection = 0;
          flashState = true;
          myDisplay.setCursor(5);
          myDisplay.print(domString);
          curDay++;
          if (curDay > monthLengths[curMonth-1]) curDay = 1;
        if (lastMinute != curDay){
          lastMinute = curDay;
          formatTimeInfo();
          if (flashState){
          } else {
          flashRate = 0;
    break;
    case 6: // set timer
      if (curSelection == 0){ // set minutes
          curTimerMinutes--;
          if (curTimerMinutes < 0) curTimerMinutes = 59;
          curSelection = 1;
          flushInput();
          curTimerMinutes++;
          if (curTimerMinutes > 59) curTimerMinutes = 0;
        if (lastTimerMinutes != curTimerMinutes){
          lastTimerMinutes = curTimerMinutes;
          if (flashState){
          } else {
          flashRate = 0;
          curTimerSeconds--;
          if (curTimerSeconds < 0) curTimerSeconds = 59;
          if (curTimerSeconds > 0 || curTimerMinutes > 0){
            timerIsActive = true;
          curMode = 3;
          curSelection = 0;
          flashState = true;
          timerCounter = 0;
          curTimerSeconds++;
          if (curTimerSeconds > 59) curTimerSeconds = 0;
        if (lastTimerSeconds != curTimerSeconds){
          lastTimerSeconds = curTimerSeconds;
          if (flashState){
          } else {
          flashRate = 0;
    break;
  flushInput();
} // ************************************************************************ END MAIN LOOP ****************************************************************
void formatTimerMinutes(){
  String tempCurTimerMinutesString = String(curTimerMinutes);
  if (curTimerMinutes < 10){
    timerMinutesString.setCharAt(0, '0'); // add a leading 0
    timerMinutesString.setCharAt(1, tempCurTimerMinutesString.charAt(0));
  } else {
    timerMinutesString.setCharAt(0, tempCurTimerMinutesString.charAt(0));
    timerMinutesString.setCharAt(1, tempCurTimerMinutesString.charAt(1));
void formatTimerSeconds(){
  String tempCurTimerSecondsString = String(curTimerSeconds);
    if (curTimerSeconds < 10){
      timerSecondsString.setCharAt(0, '0'); // add a leading 0
      timerSecondsString.setCharAt(1, tempCurTimerSecondsString.charAt(0));
    } else {
       timerSecondsString.setCharAt(0, tempCurTimerSecondsString.charAt(0));
       timerSecondsString.setCharAt(1, tempCurTimerSecondsString.charAt(1));
void  getTimeInfo(){
  curHour = hour();
  curMinute = minute();
  curDay = day();
  curMonth = month();
  curYear = year();
void formatTimeInfo(){
  if (timeIs12Hr && curHour > 12){
    curHour -= 12;
  if (curHour == 0)curHour = 12;
  tempHourString = String(curHour);
  tempMinuteString = String(curMinute);
  tempDateString = String(curDay);
  //tempMonthString = String(curMonth);
  yearString = String(curYear);
  curDow = getDayOfWeek(curYear, curMonth, curDay);
  dowString.setCharAt(0, dowNameString.charAt(curDow * 3));
  dowString.setCharAt(1, dowNameString.charAt(curDow * 3 + 1));
  dowString.setCharAt(2, dowNameString.charAt(curDow * 3 + 2));
  monthString.setCharAt(0, monthNameString.charAt((curMonth-1) * 3));
  monthString.setCharAt(1, monthNameString.charAt((curMonth-1) * 3 + 1));
  monthString.setCharAt(2, monthNameString.charAt((curMonth-1) * 3 + 2));
   if (curHour < 10){
     hourString.setCharAt(0, ' '); // add a leading space
     hourString.setCharAt(1, tempHourString.charAt(0));
   } else {
     hourString.setCharAt(0, tempHourString.charAt(0));
     hourString.setCharAt(1, tempHourString.charAt(1));
   if (curMinute < 10){
     minuteString.setCharAt(0, '0'); // add a leading 0
     minuteString.setCharAt(1, tempMinuteString.charAt(0));
   } else {
     minuteString.setCharAt(0, tempMinuteString.charAt(0));
     minuteString.setCharAt(1, tempMinuteString.charAt(1));
   if (curDay < 10){
     domString.setCharAt(0, '0'); // add a leading 0
     domString.setCharAt(1, tempDateString.charAt(0));
   } else {
     domString.setCharAt(0, tempDateString.charAt(0));
     domString.setCharAt(1, tempDateString.charAt(1));
   timeHoursString.setCharAt(0, hourString.charAt(0));
   timeHoursString.setCharAt(1, hourString.charAt(1));
   timeMinutesString.setCharAt(0, minuteString.charAt(0));
   timeMinutesString.setCharAt(1, minuteString.charAt(1));
   dateString.setCharAt(1, monthString.charAt(0));
   dateString.setCharAt(2, monthString.charAt(1));
   dateString.setCharAt(3, monthString.charAt(2));
   dateString.setCharAt(5, domString.charAt(0));
   dateString.setCharAt(6, domString.charAt(1));
 /*  if (curMonth < 10){ // This is always displayed in 3 letter characters, but could be in numbers
     monthString.setCharAt(0, '0'); // add a leading 0
     monthString.setCharAt(1, tempMonthString.charAt(0));
   } else {
     monthString.setCharAt(0, tempMonthString.charAt(0));
     monthString.setCharAt(1, tempMonthString.charAt(1));
int getDayOfWeek(int tempYear, int tempMonth, int tempDay){ // 1 <= m <= 12,  y > 1752 (in the U.K.) Credit to Tomohiko Sakamoto via Wikipedia
  const int t[] = {0, 3, 2, 5, 0, 3, 5, 1, 4, 6, 2, 4};
  tempYear -= tempMonth < 3;
  return (tempYear + tempYear/4 - tempYear/100 + tempYear/400 + t[tempMonth-1] + tempDay) % 7; // 0 for Sunday, 1 for Monday etc.
void getInput(){
  if (buttonLeft.update()){
    if (buttonLeft.fallingEdge()) buttonLeftPressed = true;
  if (buttonOk.update()){
    if (buttonOk.fallingEdge()) buttonOkPressed = true;
  if (buttonRight.update()){
    if (buttonRight.fallingEdge()) buttonRightPressed = true;
void flushInput(){ // clear any button flags that haven't been processed in the main loop
  if (buttonLeftPressed) buttonLeftPressed = false;
  if (buttonOkPressed) buttonOkPressed = false;
  if (buttonRightPressed) buttonRightPressed = false;
time_t getTeensy3Time()
  return Teensy3Clock.get();
LED Display Library:
LedDisplay Library
For details, see http://www.arduino.cc/playground/Main/LedDisplay
This library allows you to send text to an Avago HCMS-29xx LED display. The HCMS 29xx displays are pretty little displays that contain a row of 5x7 LED matrices.
The displays have a synchronous serial interface. You'll need five digital output lines to control them. The pins are as follows:
  * data - bits in from the microcontroller
  * register select - selects whether you're sending display data or control data
  * clock - timing clock from the microcontroller
  * enable - enables or disables the display
  * reset - resets the display
The library manages all the necessary pin control and data shifting for you.
Methods:
LedDisplay(int dataPin, int registerSelect, int clockPin, int chipEnable, int resetPin, int displayLength) - instantiates the library. The first five parameters are the Arduino pin numbers that are connected to the display. The last sets the length of the display (8 for the HCMS-291x and HCMS-297x, 4 for the HCMS-290x and 296x).
example:
  LedDisplay myDisplay = LedDisplay(2,3,4,5,6,8);
begin() - initializes and resets the display.
example:
myDisplay.begin();
Printing methods
write(char whatCharacter, byte whatPosition) - writes a single character to the display at a particular position
example:
myDisplay.write('A', 4);
LedDisplay inherits all the print() and println() methods from the Print library, so you can use those methods to print to the display, as long as what you print fits within the display. For example here's how to print the millis and a title string to the display:
  myDisplay.print("ms:");
  myDisplay.print(millis());
You can also do the usual Print things, like:
  int myInt = 12;
  myDisplay.print(myInt, DEC);
  // or
  myDisplay.print(myInt, HEX);
Scrolling methods
If you want to be able to automatically scroll a string of text, you need to use the setString() method first. This method stores a character string in the library instance, so you can then use the scroll() method to move it left and right.
setString(char* stringToDisplay) - displays a string on the display. If the string is longer than the display, the beginning of the string is displayed. You can use the scroll() method to step the string forward on the display.
getString() - returns the string to display.
example:
  // print out the display string for debugging:
  Serial.println(myDisplay.getString());
stringLength() - returns the length of the display string. See the scrolling example below for usage.
scroll(int direction) - scrolls the display using the string set by setString(). Negative numbers scroll left, positive numbers scroll right.
example:
void setup() {
  // scroll a string that's longer than the display:
  myDisplay.setString("This is a very long string");
void loop() {
  // when the string scrolls off the display, reverse scroll direction.
  // On the right, it scrolls off at position 8.
  // on the left, it scrolls off when the cursor is less than -(the length of the string):
  if ((myDisplay.cursorPosition() > displayLength) ||
  (myDisplay.cursorPosition() <= -(myDisplay.stringLength()))) {
  myDirection = -myDirection;
  delay(1000);
  // scroll:
  myDisplay.scroll(myDirection);
  delay(100);
Cursor control methods
clear() - clear the display.
example:
  myDisplay.clear();
home() - set cursor to far left hand position.
example:
  myDisplay.home();
setCursor(int whichPosition) - set cursor to any position.
example:
  myDisplay.serCursor(4);
getCursor() - get the cursor position.
example:
  int cursorPosition = myDisplay.getCursor();
Display Control methods
setBrightness(int bright) - lets you set the brightness from 0 to 15.
example:
  myDisplay.setBrightness(15);
If you want to set the opcodes of the display directly (you can learn them from the data sheet), the following methods will do the trick.
loadControlRegister(int dataByte) - sends 8 bits to one of the control registers.
loadDotRegister() - sends 320 bits to the dot register
Version method
version() - returns the version number of the library.
  • wearabletech
  • vcp_program
  • vcp_arduino
  • djharrigan
  • wearabletechch
  • vcp program
  • vcp
