Project Videos
  • Project Videos
Project Videos
Documents Make Your Own CNC Pyrography Wood Burner -- Episode 359
  • Date Created: 13 Sep 2018 2:16 PM Date Created
  • Last Updated Last Updated: 14 Sep 2018 7:24 AM
  • Views 2953 views
element14 Presents  |  MAYER MAKES VCP Profile  |  Project Videos
Clem tries to convert his cheap tiny CNC machine that never really worked into an easy to use tool. The tiny CNC should use the same worflow and software like a standard 3d printer does. There is one rule that always applies, „ If you buy cheap random stuff from unknown sources- you are in for a bad time“ The Struggle is real, but the result is a CNC Woodburning machine!
Product NameManufacturerQuantity
Buy Kit
A000067 -  Development Board, Arduino Mega 2560, ATmega2560 MCU, 54 3.3V I/O, 16 Analogue Inputs, 4 UARTs
Arduino1Buy Now
TMCM-TRAMS -  Evaluation Board, Trinamic RepRap Arduino Mega Shield, 3D-Printers with TMC5130 Motor Controller
Trinamic1Buy Now
  • 3d printer
  • halloween 2018
  • woodburning
  • trinamic
  • e14presents_mayermakes
  • cura for cnc
  • cnc
  • arduino shield
  • vcp_arduino
  • ardexpert
  • evaluation board
  • atmega2560
  • friday_release
  • tmcm-trams
  • motor controller
  • arduino mega
  • mayermakes
  • phoenixcomm
    phoenixcomm over 7 years ago +1
    cool, but I need a foam cutter that can handle a 4x8 foot sheets and would have X/Y/Z normal axis, with maybe an additional axis for spindle tilt. Since my foam ranges from 1 to 4 inches in thickness,…
  • phoenixcomm
    cool, but I need a foam cutter that can handle a 4x8 foot sheets and would have X/Y/Z normal axis, with maybe an additional axis for spindle tilt. Since my foam ranges from 1 to 4 inches in thickness, I will most likely have to hold the foam down with some sort of vacuum system, and a separate vacuum for sucking up the blizzard of snow!
    It would also be nice to have two spindles on two different gantries so that I can cut this at a) twice the speed b) two items at the same time.
    Why the 4x8 requirement? Its used in experimental aircraft construction. image
    If you want to double down on this hardware there are "pin-locks", powered by air that can be mounted on the gantry to remove the spindle and the mounts. then replace it with maybe a laser? or a drill, etc.
  • mayermakes
    mayermakes over 8 years ago in reply to DAB
    tahnks, Give it a shot, it is never to late
    DAB over 8 years ago
    Nice episode.
    I too have an old CNC that never really came together.
    Maybe it is time I made something of it.
