Project Videos
  • Project Videos
Project Videos
Documents Raspberry Pi Virtual Reality Arcade -- Episode 364
  • Date Created: 17 Oct 2018 11:29 PM Date Created
  • Last Updated Last Updated: 19 Oct 2018 7:24 AM
  • Views 6043 views
  • Likes 9 likes
  • Comments 21 comments
Raspberry Pi Virtual Reality Arcade #VR
element14 Presents  |  MAYER MAKES' VCP Profile  |  Project Videos
Clem revisits his HACK like HECK project, the VRpi!  A Virtual Reality System for the Raspberry Pi. The original device did run  Doom exclusively. The VRpi  2 runs OpenArena and other Games, you can even use it as a cheap pseudo VR Kit for your PC-Games. Thanks to the Raspberry Pi 3+ some Arduino micros and Radio transmitters.
Product NameManufacturerQuantity
Buy Kit
2465 -  PowerBoost 1000 LiPo Charger 5V 1A Boost
ADAFRUIT2Buy Now
Rechargeable Battery 3.7 V Lithium Polymer 1100 mAh Connector
BAK2Buy Now
E003 -  Stripboard, FR2, Epoxy Paper, 1.5mm, 160mm x 100mmKEMO ELECTRONIC1Buy Now
Development Board Arduino Micro ATmega32U4 MCU 20 3.3V I/O 12 Analogue Inputs ISCP Header ARDUINO2Buy Now
RPI3-MODBP -  Single Board Computer, Raspberry Pi 3 Model B+, BCM2837B0 SoC, IoT, PoE EnabledRASPBERRY-PI1Buy Now
RAPB-MSDH16GPH-8010I -  Integral 16gb MicroSD Card with AdapterINTEGRAL1Buy Now
TRANSMITTER 433.92MHZ 3KBPS SIP RF SOLUTIONS2Buy Now
AM-RX12E-433P -  RF RECEIVER MODULE, 433.92, -110DBMRF SOLUTIONS2Buy Now
RIBBON CABLE 10 CONDUCTOR 100FT 28AWG 300V 3M1Buy Now
Joystick 2 6 A 240 V KELAN1Buy Now
VRPI2_FOR DOWNLOAD.zip
imageClem Mayers Viewer Challenge 2018_TermsandConditions.pdf
  • vr diy
  • virtualreality
  • raspberrypi gaming
  • vr games free
  • e14presents_mayermakes
  • raspberri pi
  • vr
  • gaming
  • cheap vr
  • friday_release
  • easy vr*
  • vrpi
  • virtual reality
    DAB over 8 years ago +2
    Great episode Clem. I like the design for VR control. I am not a gamer, but I can see many uses for this approach. DAB
  • mayermakes
    mayermakes over 8 years ago +1
    Hi , folks You can download all the Files to get your own VRpi up and running right under this video. Hope you have fun with it, feel free to improve upon the Code and concept! I'd love to see this thing…
  • mayermakes
    mayermakes over 8 years ago in reply to DAB +1
    Thanks, Even for non gamers this thing might come in handy when playing around with 3d Software. I also tried it out for FPV-Flying Simulators, which also works good.
  • pi4.raspberry99999
    pi4.raspberry99999 over 5 years ago
    Hey,
    Is der any document that explains the circuit connection for the overall setup?
  • mayermakes
    mayermakes over 5 years ago in reply to pi4.raspberry99999
    not really a doc, basically the video is the documentation.
    in short form:
    Video:
    connect the composite video testpoint and gnd to the 5,8ghz sender module
    Head tracker:
    The mpu6050 is connected to an atmega 32u4 base MCU (arduino micro) via I2C (default pins)
    connect the Head tracking unit  via USB cable to the pi
    Controller:
    controller is another Arduino micro that reads buttons and is also connected via usb to the pi
    the rest is code and configuration available in the download section /seen in the video.
    pi4.raspberry99999 over 5 years ago in reply to mayermakes
    I shall drop you a text if I am lost during the process.
    Thanks
    Thanks
