Project Videos
  • Project Videos
Project Videos
Documents Raspberry Pi Virtual Reality Arcade -- Episode 364
  • Date Created: 17 Oct 2018 11:29 PM Date Created
  • Last Updated Last Updated: 19 Oct 2018 7:24 AM
  • Views 6201 views
  • Likes 9 likes
  • Comments 21 comments
Raspberry Pi Virtual Reality Arcade #VR
element14 Presents  |  MAYER MAKES' VCP Profile  |  Project Videos
Clem revisits his HACK like HECK project, the VRpi!  A Virtual Reality System for the Raspberry Pi. The original device did run  Doom exclusively. The VRpi  2 runs OpenArena and other Games, you can even use it as a cheap pseudo VR Kit for your PC-Games. Thanks to the Raspberry Pi 3+ some Arduino micros and Radio transmitters.
Product NameManufacturerQuantity
Buy Kit
2465 -  PowerBoost 1000 LiPo Charger 5V 1A Boost
ADAFRUIT2Buy Now
Rechargeable Battery 3.7 V Lithium Polymer 1100 mAh Connector
BAK2Buy Now
E003 -  Stripboard, FR2, Epoxy Paper, 1.5mm, 160mm x 100mmKEMO ELECTRONIC1Buy Now
Development Board Arduino Micro ATmega32U4 MCU 20 3.3V I/O 12 Analogue Inputs ISCP Header ARDUINO2Buy Now
RPI3-MODBP -  Single Board Computer, Raspberry Pi 3 Model B+, BCM2837B0 SoC, IoT, PoE EnabledRASPBERRY-PI1Buy Now
RAPB-MSDH16GPH-8010I -  Integral 16gb MicroSD Card with AdapterINTEGRAL1Buy Now
TRANSMITTER 433.92MHZ 3KBPS SIP RF SOLUTIONS2Buy Now
AM-RX12E-433P -  RF RECEIVER MODULE, 433.92, -110DBMRF SOLUTIONS2Buy Now
RIBBON CABLE 10 CONDUCTOR 100FT 28AWG 300V 3M1Buy Now
Joystick 2 6 A 240 V KELAN1Buy Now
VRPI2_FOR DOWNLOAD.zip
imageClem Mayers Viewer Challenge 2018_TermsandConditions.pdf
  • vr diy
  • virtualreality
  • raspberrypi gaming
  • vr games free
  • e14presents_mayermakes
  • raspberri pi
  • vr
  • gaming
  • cheap vr
  • friday_release
  • easy vr*
  • vrpi
  • virtual reality
    DAB over 8 years ago +2
    Great episode Clem. I like the design for VR control. I am not a gamer, but I can see many uses for this approach. DAB
  • mayermakes
    mayermakes over 8 years ago +1
    Hi , folks You can download all the Files to get your own VRpi up and running right under this video. Hope you have fun with it, feel free to improve upon the Code and concept! I'd love to see this thing…
  • mayermakes
    mayermakes over 8 years ago in reply to DAB +1
    Thanks, Even for non gamers this thing might come in handy when playing around with 3d Software. I also tried it out for FPV-Flying Simulators, which also works good.
  • acedlight
    acedlight over 5 years ago
    Hi Clem,
    Great video, but I can't seem to grasp the connections for each part in the video accurately.
    For example, the listing AM-RX12E-433P -  RF RECEIVER MODULE, 433.92, -110DBM is shown before the video cuts into "Component layout and solder" part but I do not see how it is connected to the Raspberry Pi board (or if I have missed it do let me know) Also, is there a difference in connection from the 5.8GHz transmitter used in the video and the TRANSMITTER 433.92MHZ 3KBPS SIP listed?
    Thank you!
  • acedlight
    Hi Clem,
    Thank you!
  • mayermakes
    mayermakes over 5 years ago in reply to acedlight
    Yeah you caught something important.
    the rf modules listed are ones availabe at the time that should work for that application, wiring is the same as with the 5,8ghz. Signal ,gnd and power it is that simple. Receiver and sender need to be tuned to the exact same frequency. BUT here is the catch: it is not legal to use these modules in all countries and for some specific applications, the law differs vastly among places and has significantly changed since that video was published (almost two years).
    I have used a 5,8Ghz transmitter that I modified to allow for only 20mW of transmitting power and restricted it to the B-band to be legal at my specific location(at that time). the modules listed are ISM band and only allowed for short bursts as someone else nearby could use the same frequency for a garage door  or a weather station. Meanwhile new applications for that spectrum are prohibited in my area.
    5,8Ghz also gives you a better trasnission rate but lower reach.
    Its not possible to give advice or an rf solution that will work for everybody or is even legal in that persons location so you need to inform yourself about your specific needs.
    to my knowledge the specific module I used is no longer available.
    But in general: you want:
    Analog transmission
    An ISM range that is usable without license
    maybe tunable frequencys or auto-hopping
    good antennas
    conenctions are just signla , power, gnd
