Project Videos
  • Project Videos
Project Videos
Documents Retro Gaming Handheld Without a PCB -- Episode 384
  • Date Created: 19 Dec 2018 4:07 AM Date Created
  • Last Updated Last Updated: 8 Mar 2019 8:24 AM
  • Views 13029 views
  • Likes 15 likes
  • Comments 58 comments
element14 presents  |  davedarko's VCP Profile   |  Project Videos
Dave is a big fan of freeform soldering styles and made a tiny skeleton handheld. As the wise Ben Heckendorn said years before, Dave too tells everyone to collect spare LED legs. "Don't throw them away, as they might come in handy one day!" - or they get stuck in your maglock sockets. Here we need them to connect an Attiny85 with some buttons and an I2C display.
Supplemental Content:
  • Learn more about Charlieplexing: The Charlieplexing
  • For more on resistors checkout Karen's The Learning Circuit 17: Resistors
  • Now encased in Resin:Episode 384: Skeleton Handheld is now encased in resin!
Bill of Material:
Part
ATTINY85-20PU
MICROCHIP 1 Buy Now
6MM TACT SWITCH
ALCOSWITCH 5 Buy Now
SPDT SLIDE SWITCH MFS101D-14-Z NIDEC COPAL ELECTRONICS 1 Buy Now
MF25 2K MULTICOMP 2 Buy Now
MF25 3K9 MULTICOMP 1 Buy Now
MF25 8K2 MULTICOMP 1 Buy Now
MF25 18K MULTICOMP 1 Buy Now
MF25 10K MULTICOMP 1 Buy Now
S8421-45R -  HOLDER HARWIN 1 Buy Now
KXG1205 -  Buzzer KINGSTATE 1 Buy Now
IC & Component Socket - DIP8 TE CONNECTIVITY 1 Buy Now
Additional Parts:
Product Name
0.96 inch - I2C OLED display - SSD1306
2mm single core copper wire 1/2 meter
7418.Code.zip
Schematics.zip
  • episode 384: retro gaming handheld without a pcb
  • e14presents_davedarko
  • retro game
  • davedarko - dave plöeger
  • friday_release
  • xlamzerg
    xlamzerg over 7 years ago in reply to davedarko +8
    After burning bootloader everything works beautifully! Finished the project on a plastic card, so its become portable Many thanks Dave! looking forward for more cool projects like this
  • javahead
    javahead over 7 years ago +7
    Hi Dave, Great project. Here's one I made. I plan to build a base inspired by Paolo Bacigalupi's "Drowned Cities." Sort of a post-apocalyptic gaming system. I will post a picture once it's done. Cheers…
  • davedarko
    davedarko over 7 years ago in reply to davedarko +5
  • Pedro147
    Pedro147 over 7 years ago
    What a great little project and I am amazed at the quality of the graphic for such a simple circuit with such A Tiny processor image
  • davedarko
    davedarko over 7 years ago in reply to vinhcatba
    Not without changing the code heavily, no. The library for the display doesn't work with the Nokia display and the resolution isn't the same. The Nokia display has 84x48 pixels, while the OLED is 128x64. The only game "platform" around that display that I know off is the first Gamebuino version and the makerbuino as a DIY clone. The makerbuino should have plans out there to DIY one for yourself. It would run on an Atmega328 instead of an Attiny85. Hope it helped a bit.
  • vinhcatba
    vinhcatba over 7 years ago
    is it possible to to make this but with Nokia 5110 LCD?
    5110 needs 4 pin, can I trade it with the buzzer and action button?
  • davedarko
    Here's an update on the console image
  • davedarko
    davedarko over 7 years ago in reply to bdrourke
    Hi Brian,
    sorry for the late reply. The code linked here is infact ready to use for the values of resistors given here.
    You seem to have an issue with your programming setup - have you tried that before and did it work on other chips? I sometimes put other programs on my Arduino and forget to reprogram the Arduino ISP code afterwards. Just checking if you have programmed your arduino as an ISP programmer. This seems to be the issue, as otherwise it would say that the target (the attiny) didn't response. Maybe try another Arduino, if burning the ISP program doesn't work out for you.
    Good luck, hope it helped
  • bdrourke
    bdrourke over 7 years ago
    awesome project, its so bare bones. its a skeleton boy.
    I'm currently recreating your project. Im curious, the code you linked, is it already configured for the resistor values and the pins of the attiny85?
    as you said in your video you had to edit the code.
    Also, when i try to compile the sketch it says programmer not responding
    i have the arduino set under tools, programmer, "arduino as isp"
    ive selected attiny85 as the board and the processor, i have the clock set at "internal at 16MHz"
    Id appreciate anyone's suggestions
    Arduino: 1.8.9 (Windows Store 1.8.21.0) (Windows 10), Board: "ATtiny25/45/85, ATtiny85, Internal 16 MHz"
    Sketch uses 7928 bytes (96%) of program storage space. Maximum is 8192 bytes.
    Global variables use 374 bytes (73%) of dynamic memory, leaving 138 bytes for local variables. Maximum is 512 bytes.
    avrdude: stk500_recv(): programmer is not responding
    avrdude: stk500_getsync() attempt 1 of 10: not in sync: resp=0x01
    avrdude: stk500_getsync() attempt 2 of 10: not in sync: resp=0x01
    avrdude: stk500_getsync() attempt 3 of 10: not in sync: resp=0x01
    avrdude: stk500_getsync() attempt 4 of 10: not in sync: resp=0x01
    avrdude: stk500_getsync() attempt 5 of 10: not in sync: resp=0x01
    avrdude: stk500_getsync() attempt 6 of 10: not in sync: resp=0x01
    avrdude: stk500_getsync() attempt 7 of 10: not in sync: resp=0x01
    avrdude: stk500_getsync() attempt 8 of 10: not in sync: resp=0x01
    avrdude: stk500_getsync() attempt 9 of 10: not in sync: resp=0x01
    avrdude: stk500_getsync() attempt 10 of 10: not in sync: resp=0x01
    Problem uploading to board.  See http://www.arduino.cc/en/Guide/Troubleshooting#upload for suggestions.
  • davedarko
    davedarko over 7 years ago in reply to caseol
    thank you!
  • caseol
    caseol over 7 years ago
    Inspiring job! Well done sir!
  • cstanton
    cstanton over 7 years ago in reply to xlamzerg
    Excellent!
  • davedarko
    davedarko over 7 years ago in reply to rmyklatun
    I'm sorry but that won't happen image
