Project Videos
  • Project Videos
Project Videos
Documents Iron Man Helmet Heads Up Display -- Episode 415
  • Date Created: 7 Oct 2019 7:09 PM Date Created
  • Last Updated Last Updated: 11 Oct 2019 7:24 AM
  • Views 4273 views
  • Likes 9 likes
  • Comments 8 comments
When Iron Man came out, it certainly had an influence on the maker scene - definitely on Dave. He has decided to finally 3D print the files for a Mark 2/3 helmet found on the internet and upgrade the print with not one but two self made head-up displays! He talks us through the problems he encountered setting up the displays to work and finally install the lenses and displays into the faceplate. Anyone can do lights and servos, but can your helmet tell you what direction you’re flying to and what your altitude is, based on a humidity sensor? Let’s find out if Dave can do it.
Bill of Material:
PowerBoost 1000. LiPo Battery Charger Adafruit 1 Buy Now
Additional Parts:
Product Name
2x 0.96 Inch Display ST7735S RGB 160x80
2x Fresnel lens 50mm radius, 80mm focal length, used for google cardboard VR goggles
Any ESP32 board, like the dev-kit boards
BMP280 sensor board
MPU9250 sensor board
DP08 resources.zip
element14 presents  |  About davedarko  |  Project Videos
  • maker
  • fresnel
  • oled
  • head-up display
  • skyline
  • e14p_DD
  • lens
  • mark 2
  • sensor board
  • cosplay
  • darkodave
  • solder
  • humidity
  • tft
  • robot
  • iron man
  • costumes
  • marvel
  • e14presents_davedarko
  • altitude
  • mark 3
  • rgb
  • augmentation
  • bmp280
  • optics
  • st7735s
  • davedarko
  • soldering
  • mpu9250
  • iron man helmet
  • altimeter
  • compass
  • adafruit
  • davedarko - dave plöeger
  • augmented reality
  • rgb oled
  • friday_release
  • sensor
  • cardboard
  • 3d print
  • 3d printed
  • diy project
    dougw over 6 years ago +3
    Great work building a functional heads-up display.
  • phoenixcomm
    phoenixcomm over 6 years ago +3
    davedarko I love your combiners. on the altitude, you have over though it. Basically, with aircraft, you have to know the barometric pressure for any given airfield and they are all published, So you said…
    DAB over 6 years ago +2
    Nice project. I did a similar project about 40 years ago where we put flight information onto a FLIR display for search and rescue helicopter work. While I did not have the helmet issue you are trying…
  • phoenixcomm
    davedarko
    I love your combiners. on the altitude, you have over though it. Basically, with aircraft, you have to know the barometric pressure for any given airfield and they are all published, So you said that you were in Berlin then you can check with your local airport for the QNH values.  Berlin/Schoenefied International  Has a value of 1011 hPa (hectopascal). Now  1 millibar (mb) == 1 hPa. So as you go up in altitude hPa values decrease. So You could preprogram the reference value or the local airport, and you math would be simple:
    Areading =    1000 hPa
    Aref        = -  1011
    Acurrent   =    989 hPa
    Or you could take one sample when you start Aref then by sampling and running the subtraction against the sample you will always be at the altitude. please remember that it will not be in altitude. ie feet above the ground you will have to convert this as well and temperature can influence this as well.
    to sum up  take alook at this https://sciencing.com/convert-hpa-altitude-8404260.html
  • davedarko
    davedarko over 6 years ago in reply to phoenixcomm
    I'm pretty sure that's what the library did already. I was looking at pressure values on a weather map for Berlin and used them. Sadly it wasn't as accurate, as Berlin is big and I was 6-7km away from the measured points and therefore had an offset of 50-60m in altitude all the time. I could have set a reference point on my balcony first though and then go higher in the building to get the difference of that instead. Schoenefeld is 20km away from my home image Oh right, you said what I said in the second part. That would have been great! Thanks for the input!
  • phoenixcomm
    phoenixcomm over 6 years ago in reply to davedarko
    davedarko great minds think alike. Way too much coffee and beer. personly I don't know which I like better.
  • phoenixcomm
