Project Videos
  • Project Videos
Project Videos
Documents DIY #3DPrinted Label Spooler -- Episode 416
  • Date Created: 15 Oct 2019 4:10 PM Date Created
  • Last Updated Last Updated: 18 Oct 2019 7:24 AM
  • Views 4129 views
  • Comments 10 comments
My wife works at home as a shipping manager and has to print several hundred shipping labels each day. The label printer she has just spills them out onto the floor and then she has to roll them up by hand. I decided to jump in and overengineer a solution so she can get that 30-40 minutes back every day. Come have a look at my approach and see if you would do it the same way!.
Bill of Material:
PRO ELEC AC/DC Power Supply, 1 Output, 36 W, 12 VDC, 3 A PRO ELEC 1 Buy Now
LINEMASTER Foot Operated Switch, Treadlite II Series, SPDT, (On), 15 A, 125 V, 25.4 mm LINEMASTER 1 Buy Now
MULTICOMP DC Power Connector, Jack, 5 A, 2.5 mm, Panel Mount, Solder MULTICOMP 1 Buy Now
E-SWITCH Rocker Switch, On-Off-On, DPDT, Non Illuminated, Panel Mount, Black, R5 Series E-SWITCH 1 Buy Now
3D Print Files.zip
element14 presents  |  About Kaleb |  Project Videos
  • kaleb
  • e14presents_kalebclark
  • linemaster
  • dymo labels
  • pro elec
  • dc motor direction switching
  • e14 presents
  • multicomp
  • product design
  • e14p_KC
  • friday_release
  • e-switch
  • 3d print
  • phoenixcomm
    phoenixcomm over 7 years ago +2
    Very Practical..
  • kmikemoo
    kmikemoo over 7 years ago +1
    Practical engineering. I love it.
  • KalebTheMaker
    KalebTheMaker over 7 years ago in reply to kmikemoo +1
    Thanks Mike! Practical is kind of my thing. More to come!
  • Twilight2110
    Twilight2110 10 months ago
    hi I've just come across this project which i would like to make not sure what motor you are using cause its not listed in the build of materials not sure what the voltage wand rpm would be for this project
    thanks in advance
    David
  • phoenixcomm
    phoenixcomm over 5 years ago in reply to KalebTheMaker
    KalebTheMaker I always keep a few dozen of each size maybe more. also same goes for switches that have screws you should always use an islet on them. Oh by the way for wire to wire connections they have a shrink tube with low temp solder at each end, I never leave home without them. .
    ~~Cris
  • KalebTheMaker
    KalebTheMaker over 5 years ago in reply to phoenixcomm
    Thanks, Cris!
    I had to scrub through the video to see what you were talking about, It's been a bit since I looked at this project. To answer your question, it's probably because I didn't have any of the crimp connectors in stock.
    -Kaleb
  • KalebTheMaker
    KalebTheMaker over 5 years ago in reply to nitro12
    I dont, but I did replace the motor and this device is used every day in production. I must have just got a bad motor.
    -Kaleb
  • phoenixcomm
    KalebTheMaker Nice job, but one kvetch, why in the world did you solder to both the switches, when they were push on crimp connectors???
    ~~Cris
    ps Kvetch is complane, or bit-h.
  • nitro12
    nitro12 over 5 years ago
    Hello do you have a video showing if it works?
    DAB over 7 years ago
    Nice build, but you really should have looked at the torque requirements before sizing the motor.
  • KalebTheMaker
  • phoenixcomm
    Very Practical..
  • kmikemoo
    Practical engineering.  I love it. imageimage
