Project Videos
  • Project Videos
Project Videos
Documents Arduino Uno RC Remote - Can It Be Done? -- Episode 443
  • Date Created: 16 Apr 2020 3:45 AM Date Created
  • Last Updated Last Updated: 24 Apr 2020 7:24 AM
  • Views 4343 views
  • Comments 10 comments
Can you build an RC remote controller with just an Arduino Uno and a random Wifi module? That is the question this project video answers! Clem got visited by his friend Goofy who is driving RC crawlers in a local trophy series and tasks him with improving his current controller by adding more analog channels and open firmware to allow competitors to freely mod their systems. Clem only uses parts commonly found in a makers workshop such as an Arduino Uno, shift registers  and some wifi modules to build an RC system from scratch. While it works, he cuts some corners to get latency down, and shows you how to get different microcontrollers to talk to each other over UART and WiFi.
Supplemental Content:
  • Episode 391: First Person View RC Car with PS1 Steering Wheel
  • Episode 439 - Mechanical Arcade Game with Barebones Arduino
  • Github for Adafruit Library for the display
  • RC Crawler competition mentioned in the video: ASTS – Austrian Scale Team Series
  • Goofy‘s tattoo art
Bill of Material:
MULTICOMP PRO Toggle Switch, On-On, SPDT, Non Illuminated, 2M Series, Through Hole, 100 mA MULTICOMP PRO 8 Buy Now
TT ELECTRONICS / BI TECHNOLOGIES Rotary Potentiometer, 10 kohm, 1 Turns, Linear, 200 mW, ± 20%, P160 Series TT ELECTRONICS / BI TECHNOLOGIES 4 Buy Now
NEXPERIA Shift Register, HC Family, 74HC165, Parallel to Serial, 1 Element, 8 bit, SOIC, 16 Pins NEXPERIA 3 Buy Now
NEXPERIA Shift Register, 74HC595, Serial to Parallel, Serial to Serial, 1 Element, 8 bit, SOIC, 16 Pins NEXPERIA 2 Buy Now
DURATOOL Spring Set, Compressed & Extending, Assorted, 200 Pieces DURATOOL 1 Buy Now
DURATOOL Desoldering Wire, Black, 2.5 mm Width, 1.5 m Length DURATOOL 1 Buy Now
ON SEMICONDUCTOR Linear Voltage Regulator, Fixed, 5.0 V to 18 V In, 5.0 V / 1 A Out, DPAK-3 ON SEMICONDUCTOR 2 Buy Now
TEXAS INSTRUMENTS Linear Voltage Regulator, Fixed, 4.75V To 26V In, 3.3V And 400mA Out, SOT-223-4 TEXAS INSTRUMENTS 2 Buy Now
MICROCHIP 8 Bit Microcontroller, AVR ATmega Family ATmega328 Series Microcontrollers, 20 MHz, 1 KB, 32 KB MICROCHIP 2 Buy Now
MULTICOMP PRO LED, Inbuilt Resistor, 5V, Red, Through Hole, T-1 3/4 (5mm), 10 mA, 2.1 V, 650 nm MULTICOMP PRO 8 Buy Now
MULTICOMP 3D Printer Filament, 1.75mm Dia, Blue, PLA, 1 kg MULTICOMP 1 Buy Now
C & K COMPONENTS DIP / SIP Switch, 8 Circuits, Raised Slide, Through Hole, SPST-NO, 5 V, 100 mA C & K COMPONENTS 1 Buy Now
MULTICOMP Tactile Switch, MCDTS-6 Series, Top Actuated, Through Hole, Round Button, 160 gf, 50mA at 12VDC MULTICOMP 8 Buy Now
MIDAS Graphic OLED, 48 x 64 Pixels, White on Black, 3V, I2C, 15.9mm x 27mm, -40 °C MIDAS 1 Buy Now
Additional Parts:
Product Name
RC car wheel as steering wheel
RC Car  ( Cars used in the Epsiode: modded Reely Bulldog/Rockdog / AMR Mini Scud with Mini Cooper Body)
ESP8266 modules (ESP-01S) or any other wifi module
Resources_RC Remote.zip
element14 Presents  |  About Clem  |  Project Videos
  • ardunio uno to esp8266
  • fast udp data
  • shift register
  • oled
  • potentiometer
  • arduino uno
  • voltage regulator
  • clem
  • nexperia
  • uart between arduino and esp
  • microchip
  • how to wifi on esp8266
  • duratool
  • send data with wifi .
  • rc car
  • e14presents_mayermakes
  • how to send data over wifi
  • how to make arduino and esp talk.
  • rc remote controller
  • esp8266 rc
  • arduino rc
  • esp8266 remote controlled
  • how to use wifi with arduino
  • how to udp
  • eps8266
  • multicomp
  • radio control car
  • udp
  • friday_release
  • mayermakes
  • eps8266 wifi
  • e14p_CMM
    DAB over 6 years ago +2
    Good project Clem. Well done. DAB
  • celcius1
    celcius1 over 6 years ago +2
    With the self centering steering leg, you could use a coil spring, for the centering, if your interested I can send you my fusion 360 file of a test of working printable coil spring, I will state it works…
  • celcius1
    celcius1 over 6 years ago in reply to mayermakes +2
    Hey Clem, Happy to help, here is the link to my github https://github.com/Celcius1/MiscFiles where I have uploaded it to. It's the only file there for the moment but I'll add more as I release some other…
  • mayermakes
    mayermakes over 6 years ago in reply to celcius1
    thnaks for the Offer at the moment My design might not need that specialiced gel (and I expect it to be very expensive). But if I have the need I wil lget back to you! thanks for the tremendous support!
  • celcius1
    Glad to help, this design would give you an idea how the use of a coil spring works, and can be adapted, a variation on the design with more constraint can be used, but still uses the same concept in the uploaded file.  If you get stuck more than happy to upload a variation on this file
  • mayermakes
    Awesome, thanks for Posting your design!
  • celcius1
    Hey Clem,
    Happy to help, here is the link to my github https://github.com/Celcius1/MiscFiles where I have uploaded it to.  It's the only file there for the moment but I'll add more as I release some other items to the public.  But like I said it was a test to see if I could print a coil spring, which you would most commonly find in wind up watches and clocks.
    Regards
    Paul
  • mayermakes
    thank you ! of course I'm interested in your design, please post it right here so other community members can see it as well!
    I had a design with a steel "rotary"? spring (no idea how its correctly called) in mind but it did not work out as intended, the design shown in the video was easiest to integrate with the pcb design.
  • celcius1
    With the self centering steering leg, you could use a coil spring, for the centering, if your interested I can send you my fusion 360 file of a test of working printable coil spring, I will state it works best when printed in PETG, as PETG seems to have the right type of springiness.
    The nature of the coil spring would do the trick due to how a coiled spring functions, as its more representative of the motion used for the steering control
  • mayermakes
    mayermakes over 6 years ago in reply to DAB
    thank you!
    Good project Clem.
    Well done.
  • mayermakes
    mayermakes over 6 years ago in reply to kmikemoo
    thank you!
  • kmikemoo
    kmikemoo over 6 years ago
    I enjoyed the code detail, but the highlight was definitely the intro.  It was fantastic!  I had to watch it a couple of times. imageimage
