Project Videos
  • Project Videos
Project Videos
Documents Raspberry Pi 4 Experimental Resin 3D Printer Updated! -- Episode 452
  • Date Created: 15 Jun 2020 5:37 PM Date Created
  • Last Updated Last Updated: 26 Jun 2020 7:24 AM
  • Views 6050 views
  • Likes 8 likes
  • Comments 14 comments
Clem has built a giant resin based 3d printer concept in a previous video, and today it is time to put the concept upside down! The people on the element14 community gave him a lot of advice and ideas to make his idea finally work as it should! Clem builds a second iteration of his 3d printer using daylight resins and easily obtainable parts.  The new Raspberry pi 4 8 GB reduces slicing times and makes for a more responsive GUI on this experimental 3d printer! Now its time for the community to take his findings and iterate  for a bright future of cheap huge 3d printers!
Supplemental Content:
  • Episode 414: Raspberry Pi 4 Experimental Resin 3D Printer
Bill of Material:
RASPBERRY-PI Single Board Computer, Raspberry Pi 4 Model B, BCM2711 SoC, 4GB DDR4 RAM, USB 3.0, PoE Enabled Raspberry-PI 1 Buy Now
MULTICOMP PRO 3D Printer Filament, 1.75mm Dia, Blue, TPE, 1 kg Multicomp 1 Buy Now
PRO SIGNAL Audio / Video Cable Assembly, HDMI A Plug to Micro HDMI D Plug, 6.6 ft, 2 m, Black PRO SIGNAL 1 Buy Now
PHOTOCENTRIC 3D Printer Resin, Grey, 1kg, 510cPs Viscosity, 1.16 g/cm³, 6% Elongation Photocentric 1 Buy Now
RASPBERRY-PI Daughter Board, Raspberry Pi 7" Touch Screen Display, 10 Finger Capacitive Touch RASPBERRY-PI 1 Buy Now
MIDAS TFT LCD, 7 ", 1024 x 600 Pixels, WSVGA, Landscape, RGB, 5V MIDAS 1 Buy Now
MEAN WELL AC/DC Enclosed Power Supply (PSU), ITE, 1 Outputs, 50.4 W, 12 V, 4.2 A MEAN WELL 1 Buy Now
MULTICOMP Axial Fan, 12 V, DC, 60 mm, 33.05 dBA, 18.84 cu.ft/min MULTICOMP 3 Buy Now
MEAN WELL AC/DC Enclosed Power Supply (PSU), ITE, 1 Outputs, 15 W, 5 V, 3 A MEAN WELL 2 Buy Now
TRINAMIC Evaluation Board, TMC2209 SilentStepStick, 2-Phase Motor Driver TRINAMIC 1 Buy Now
NANOTEC Stepper Motor, High Torque, DC, 0.5 N-m, 1.8 A, Two Phase, 1.75 ohm, 3.3 mH NANOTEC 1 Buy Now
OMRON Microswitch, Snap Action, Hinge Roller Lever, SPDT, Solder, 5 A OMRON 1 Buy Now
Additional Parts:
Product Name
Aluminium Extrusion for the Frame
PMMA-XT for the Vat
PMMA/Acrylic for the Case
MAYER MOVES DEVKIT available at Aisler.net on demand
ResinPrinter2.0_Resources.zip
element14 Presents  |  About Clem  |  Project Videos
  • 3d printer
  • resin
  • episode 452: raspberry pi 4 experimental resin 3d print
  • clem
  • nanotec
  • trinamic
  • omron
  • e14presents_mayermakes
  • raspberry pi touch screen
  • stepper motor
  • raspberry pi 4
  • raspberry pi
  • 3d_printer
  • multicomp
  • friday_release
  • mayermakes
  • e14p_CMM
  • mayermakes
    mayermakes over 6 years ago in reply to celcius1 +2
    I actually have that exact breakout in stock, but the catch is that Nanodlp only Accepts the Display conenctor or HDMI1 as valid outputs. the software is not open source so I can't change that.
  • mayermakes
    mayermakes over 6 years ago +1
    Looking forward to all the comments, Ideas and input all the people have on my second iteration! As stated in the video, I tried to incroporate as many ideas from the community as possible but I'm sure…
  • celcius1
    celcius1 over 6 years ago +1
    Just checked the spec sheet on the Midas screen, it’s still usable if you have not thrown it out. The TFT screen uses a 40 pin ribbon connector if you can get to this connector you can plug it into a breakout…
    DAB over 6 years ago
    Good update Clem.
    Have you considered using a small vibrator to disperse the fluid over the surface evenly?
    Good update Clem.
  • mayermakes
    mayermakes over 6 years ago in reply to DAB
    considered yes, but I focused on making it pritn at all first.
    DAB over 6 years ago in reply to mayermakes
    I am thinking you will get better print results with an even layer of resin to start each layer.
