Project Videos
  • Project Videos
Project Videos
Documents Portal 2 Security Camera with Raspberry Pi 2 -- Episode 461
  • Author Author: cstanton
  • Date Created: 5 Aug 2020 10:14 AM Date Created
  • Last Updated Last Updated: 28 Aug 2020 7:24 AM
  • Views 7282 views
  • Likes 11 likes
  • Comments 22 comments
Feeling like a test subject? Want to keep track of who’s been secretly eating all of your cake and catch them in the act? Whether or not you’re a fan of Portal, this security camera build is a fun weekend project that you can use to keep track of your precious test subjects… er, uh family. Utilizing the latest and greatest high quality camera from the Raspberry Pi foundation, DJ brings another piece of Aperture Science technology to life in today’s video.
Bill of Material:
Raspberry Pi 4 Raspberry Pi 1 Buy Now
Raspberry Pi High Quality Camera Raspberry Pi 1 Buy Now
LED, Red, Through Hole, T-1 3/4 (5mm), 10 mA, 2.1 V, 650 nm MULTICOMP 1 Buy Now
MicroSD Card Sandisk 1 Buy Now
RPI 6MM WIDE ANGLE LENS Raspberry Pi 1 Buy Now
470Ohm Resistor MULTICOMP PRO 1 Buy Now
DC Barrel Jack MCM 1 Buy Now
5V 3A DC Power Supply PRO ELEC 1 Buy Now
3D Filament Verbatim 2 Buy Now
Additional Parts:
Product Name
Laser-cut acrylic
1/2" Aluminum Round Tube
1" Aluminum Square Tube
White/Gray/Black Spray Paint
Noctua 40mm PC Fan
Portal 2 Security Camera_Resources.zip
element14 presents
element14 Presents  |  About DJ  |  Project Videos
  • raspberry pi hq camera
  • valve
  • security
  • mcm
  • portal
  • valve software
  • pro elec
  • robot
  • glados
  • the cake is a lie
  • diy
  • portal 2
  • raspberry pi
  • e14p_DJ
  • robot project
  • raspberrypi
  • camera
  • multicomp
  • pi camera
  • dj
  • portal valve software
  • dj harrington
  • friday_release
  • picam
  • e14presents_djharrigan
  • celcius1
    celcius1 over 5 years ago +1
    Excellent project DJ but a few improvements (and this draws on my knowledge from my day job as a security systems installer) instead of using the DC plug pack to power the security camera a better option…
  • tnjent98
    tnjent98 over 5 years ago in reply to mrvolt +1
    what program opens .step files? Why not just post .stl so the regular 3d printer folks can just open it in Cura or a simple slicer?
  • celcius1
    instead of using the DC plug pack to power the security camera a better option would have been to use the PoE hat and PoE Ethernet switch to power it, plus it would eliminate the need to configure the wireless just run dhcp and looking for the device on your network
    With the lens you probably did not notice it, once focused you can lock the position in place with the adjustment Handles/lugs they should twist locking it in place, and to give a bit more control if you sourced an auto iris security lens, you would need to use two pins configured as PWM to control the iris opening which is normally connected to a light sensor, closing it down for bright light, and opening it up in low light conditions.  I think I have a python script on how to control an auto iris lens somewhere. (And yes I have been playing with a lens on a Pi project just can’t get the software to work)
    But otherwise an excellent security camera project.
  • mrvolt
    mrvolt over 5 years ago in reply to celcius1
    There's definitely room to expand and grow the project. Thanks for the suggestions Paul!
  • mrvolt
