Project Videos
  • Project Videos
Project Videos
Documents DIY Wall Mounted Arduino Barometer -- Episode 475
  • Date Created: 24 Nov 2020 7:13 PM Date Created
  • Last Updated Last Updated: 4 Dec 2020 8:24 AM
  • Views 4124 views
  • Comments 11 comments
Making a wall mounted barometer, which not only shows the current pressure and temperature but the last 24 hours of readings. To help you see how the weather is changing and predict what the imminent future weather might be!
Supplemental Content:
  • Code and circuit diagrams
Bill of Material:
Development Board, Arduino Uno, ATmega328P MCU ARDUINO 1 Buy Now
Daughter Board, Arduino UNO Click Shield MIKROELEKTRONIKA 1 Buy Now
1506 LED Strip, NeoPixel Digital RGB, 144 LED's, 1m Black ADAFRUIT 1 Buy Now
Pin Header, Board-to-Board, 2.54 mm, 1 Rows, 18 Contacts, Through Hole Straight, MC34 Series MULTICOMP PRO 1 Buy Now
MIKROE-3216 Add-On Board, Pressure 6 Click Board, Pressure Sensor, 300hPa To 1300hPa, MikroBUS MIKROELEKTRONIKA 1 Buy Now
E005 Stripboard, FR4, Epoxy Fibreglass, 1.5mm, 160mm x 100mm KEMO ELECTRONIC 1 Buy Now
DS1307+ RTC IC, Date Time Format (Day/Date/Month/Year hh:mm:ss), I2C, Serial, 4.5 V to 5.5 V, DIP-8 MAXIM INTEGRATED PRODUCTS 1 Buy Now
38-HX5F12.5-32.768KHZ Crystal ILSI AMERICA 1 Buy Now
Pin Header, Board-to-Board, 2.54 mm, 1 Rows, 3 Contacts, Through Hole Right Angle, MC34 Series MULTICOMP PRO 1 Buy Now
Battery, Coin Cell, Single Cell, 3 V, 2032, Lithium Manganese Dioxide, 230 mAh, PCB Pins, 20 mm VARTA 1 Buy Now
08-50-0032 Contact, KKRegistered 254, KK 254 4809 Series, Socket, Crimp, 22 AWG, Tin Plated Contacts MOLEX 3 Buy Now
Connector Housing, KK 254 2695, Receptacle, 3 Ways, 2.54 mm MOLEX 1 Buy Now
Through Hole Resistor, 10 kohm, SFR125 Series, 400 mW, ± 5%, Axial Leaded, 250 V VISHAY 2 Buy Now
MF25 470R Through Hole Resistor, 470 ohm, MF25 Series, 250 mW, ± 1%, Axial Leaded, 250 V MULTICOMP PRO 1 Buy Now
SW4047G C ADAPTOR INTL 12V 2A VI POWERPAX 1 Buy Now
Additional Parts:
Product Name
Vinyl (cut with scale on)
Wood-Oak
Polycarbonate sheet
Cook & Freeze round storage Dish 1.7L
element14 presents
element14 presents  |  About Katie |  Project Videos
  • molex
  • e14p_KD
  • arduino uno
  • e14presents_kdumont
  • barometer
  • pressure
  • coin cell battery
  • neopixels
  • mikroe
  • temperature
  • weather
  • kemo
  • katie
  • mikroelectronika
  • varta
  • multicomp
  • adafruit
  • powerpax
  • ilsi
  • friday_release
    beacon_dave over 5 years ago +3
    The last 24hours of readings is a very useful feature to have when you share a house with people who insist on resetting the needle every time they pass the barometer ! A variation may be to use an e-paper…
  • neilk
    neilk over 5 years ago +2
    Very nice build and video. I was most impressed by the library you wrote for the pressure sensor. At the moment, writing a library is way above my pay grade!! Neil
  • hifromkatie
    hifromkatie over 5 years ago in reply to beacon_dave +2
    I like the e-paper idea, I've got another project in mind to use a big e-ink display as a home monitor, and adding local information such as temperature and weather would be an interesting addition to…
  • neilk
    Neil
  • hifromkatie
    hifromkatie over 5 years ago in reply to neilk
    Thanks.
    I used to think it was a bit daunting, but after having to do some changes to an exsisting library at work I got my head around it fairly easily and realised it's not that different to any other code.
  • hifromkatie
    Thanks.
