Project Videos
  • Project Videos
Project Videos
Documents DIY Sump Pump Alarm -- Episode 504
  • Date Created: 22 Jun 2021 3:17 PM Date Created
  • Last Updated Last Updated: 25 Jun 2021 7:24 AM
  • Views 4248 views
  • Likes 12 likes
  • Comments 11 comments
Houses with a basement are in a constant fight with the underground water table. As incredible as indoor swimming pools might sound, they are not very fun for a homeowner! Sump systems collect the water that enters a basement and then pump it out of the house; that is, when they have the power they need! The Sump Pump Alarm from Mike (kmikemoo) looks excellent, very functional, and uses all of the parts in the project. A USB power bank is an ideal backup power supply to run a monitoring system to let someone know when the pump isn’t working. We all enjoyed Mike’s excellent project demo video, so you should check it out too!
Supplemental Content:
  • Episode 500:  Build Inside The Box Challenge!
  • Build Inside The Box - Sump Pump Alarm
  • Build Inside The Box - Member Projects!
  • Build Inside the Box Member Challenge - WINNERS!
Bill of Material:
Part Manufacturer Quantity Buy Kit >
Arduino MKR Zero
Arduino 1 Buy Now
PRO Portable USB High Capacity Power Bank Multicomp 1 Buy Now
Pluggable Terminal Block Wago 1 Buy Now
Operational Amplifier Microchip 1 Buy Now
Phototransistor Vishay 1 Buy Now
OLED Graphic Display Midas 1 Buy Now
Temperature Sensor IC Microchip 1 Buy Now
Range/Gesture Sensor ST 1 Buy Now
element14 presents
DIY Sump Pump Alarm
element14 Presents  | Project Videos
  • vishay
  • microchip
  • arduino mkr zero
  • diy
  • sump pump
  • temperature sensor ic
  • terminal block
  • phototransistor
  • st micro
  • oled graphic display
  • multicomp
  • midas
  • arduino mkr zer
  • wago
  • friday_release
  • mike_moore
  • kmikemoo
    kmikemoo over 5 years ago in reply to baldengineer +5
    Thanks, baldengineer . It's kind of weird to build a project you hope you never need to use.
  • baldengineer
    baldengineer over 5 years ago +3
    Awesome job, kmikemoo ! I really liked how practical your project is and how well you used the components. I'm also glad that so many people get to see both your project and your video. My favorite part…
  • Workshopshed
    Workshopshed over 5 years ago +3
    Great combination of sensors. The SDCard on the MKR could be used to keep track of the levels over time.
  • phoenixcomm
    phoenixcomm over 5 years ago
    imagekmikemoo
    Cool video, but I go bigger most of the time and use a sewage pump. All cast Iron on almost never fails. I was using them in a Marble countertop shop I think we had 7 of those things. The funny thing is when the plastic PVC pipe broke at the fitting. water would go up 30 feet. image Each pump was running on 230vac and had a float switch which triggered some ladder logic. to run the pump. BTW each pit was about 3x3 feet and 4 feet deep. every once and a while you have to lift the pump out of the hole and "muck out" the pit.  image
    ~~Cris
  • kmikemoo
    kmikemoo over 5 years ago in reply to phoenixcomm
    phoenixcomm   Thanks.  And wow!  That's a serious sump!  I don't muck the sump often, but when I do... I just agitating the stuff on the bottom and flipping the float switch on.  Even in the Summer, that water is COLD.  Your sumps probably took a bit more work. image
  • phoenixcomm
    phoenixcomm over 5 years ago in reply to kmikemoo
    kmikemoo Thanks, Mike.
  • phoenixcomm
