Project Videos
  • Project Videos
Project Videos
Documents Laser Cutter Command Station -- Episode 510
  • Date Created: 3 Aug 2021 3:27 PM Date Created
  • Last Updated Last Updated: 6 Aug 2021 7:24 AM
  • Views 6436 views
  • Likes 9 likes
  • Comments 12 comments
Every time I want to use my new laser cutter I have to turn on and plug in a bunch of different things. Too much work! In this episode I am going to build a command station for the laser so that all the switches are in one place controlling relays to turn them off and on. Join me on my crash course through sheet metal forming, acrylic bending, code, and about a mile of wires!
Supplemental Content:
  • Download code from Github: https://github.com/KalebTheMaker/E14-LaserCommandStation
Bill of Material:
ARDUINO Evaluation Board, MCU 8-Bit, Arduino Mega2560, AVR, ATmega2560 ARDUINO 1 Buy Now
MULTICOMP PRO Solid State Relay, 25 A, 280 VAC, Panel, Screw, Zero Crossing MULTICOMP PRO 3 Buy Now
MULTICOMP PRO Toggle Switch, On-Off, SPST, Non Illuminated, 15 A, Panel Mount MULTICOMP PRO 8 Buy Now
HAMMOND Handle, round metal , 5u, Chrome, 76.2 mm, Steel, 4-40, Chassis Handles 1427 Series HAMMOND 2 Buy Now
MULTICOMP PRO Solid State Relay, 10 A, 280 VAC, Panel, Screw, Zero Crossing MULTICOMP PRO 5 Buy Now
SCHURTER Power Entry Connector, 5-15R, Snap In, Power Entry, 15 A, Black, Thermoplastic Body, 125 V SCHURTER 8 Buy Now
SWITCH, SPDT, 5A, 120VAC C&K COMPONENTS 2 Buy Now
Additional Parts Manufacturer Quantity
RJ54 CAT5E Jacks x6
20A NEMA 5-20P x2
1/2" Water Flow Hall Sensor Switch Flow Meter Flowmeter Counter 1-30L/min
100 PSI Pressure Transducer Sender Sensor with Connector
3mm Acrylic
Misc 3mm & 4mm hex cap nuts & bolts
6.25mm Acrylic
12/3 Conductor. 12ft
Misc 12g stranded wire
Crimp Blade connectors
Crimp butt connectors
1mm clear acrylic
WS2812b Addressable RGB LED's
Kaleb Clark - Kaleb_020-CAD-Files.zip
element14 presents
element14 presents  |  About Kaleb |  Project Videos
  • kaleb
  • e14presents_kalebclark
  • schurter
  • laser cutter
  • multicomp
  • hammond
  • diy arduino helicopter collective joystick control
  • c&k components
  • e14p_KC
  • helicopter
  • friday_release
    DAB over 5 years ago +2
    Very good build. DAB
  • KalebTheMaker
    KalebTheMaker over 5 years ago in reply to kmikemoo +2
    Thanks! I was tired of how fast my labeler eats through batteries, so I broke out the old embossed tape labeler and swapped it for my primary. The adhesive on the new tape does not seem as good as the…
  • KalebTheMaker
    KalebTheMaker over 5 years ago in reply to DAB +2
    Thank you DAB, had a blast building this one.
  • kmikemoo
    kmikemoo over 5 years ago
    Awesome build!  Looks great.  I especially like the Power and Dot labels.  That really fits the motif - straight outta NASA.
  • KalebTheMaker
    Thanks! I was tired of how fast my labeler eats through batteries, so I broke out the old embossed tape labeler and swapped it for my primary. The adhesive on the new tape does not seem as good as the old stuff, but that's not really a surprise.
  • KalebTheMaker
  • kmikemoo
    kmikemoo over 5 years ago in reply to KalebTheMaker
    KalebTheMaker  I have a battery guzzling label maker as well.  I finally broke down and bought the wall wart.  Fantastic decision.  Wish I would have done it much earlier.
