Project Videos
  • Project Videos
Project Videos
Documents A Smart Youtube Counter With An Audio Analyzer - Episode - 658
  • Author Author: e14phil
  • Date Created: 10 Jul 2024 11:41 AM Date Created
  • Last Updated Last Updated: 15 Jul 2024 8:46 AM
  • Views 3342 views
  • Likes 9 likes
Mark has a thing with Audio Analyzers: "They are simply fun to look at. Patterns moving up and down to the music. Amazing. On my private channel, called The Electronic Engineer, I published dozens of analyzers. I also did a few for element 14 like a web-based analyzer and another one made of Lego bricks."
In this episode of element14 presents Mark builds a new backdrop item, a Smart Youtube Counter with Audio Analyzer.
Watch the Video:
So, with my mind set for analyzers, I just had to include one when I designed this YouTube subscriber counter and the result is amazing. I am very pleased with the outcome:
  • YouTube subscriber counter
  • Playback of audio files for new subscribers
  • Possibility to program different sounds for milestones.
  • It’s connected to the internet using WIFI, so adding a clock or a messenger service is technically possible
  • Audio analyzer displaying FFT results of the audio.
  • Microphone input!
Components and Parts:
Although the number of components is only a few, I did design a PCB. You can order your own (check out the part list). The PCB production files are included.
Take note when assembling the PCB, not all components are required. I added two row headers only for the purpose to have the pins available if I need those. No need to actually assemble those headers. Same goes for connector H9, you only need it if you decide to use a microphone on a wire.
Programming
If you are using the designed PCB, programming the firmware is easy. The only things you need to change is your WIFi credentials and the info to your youtube channel.
The author of the specific library that is used made a nice tutorial on how to do that:
https://github.com/witnessmenow/arduino-youtube-api
One important thing that is not shown in the video:
You need to upload the mp3 files from the data folder to the Arduino internal storage.
To do so you have to select the ESP32 Sketch Data upload function from the Tools Menu in Arduino IDE
Bill of Materials:
Trimpot, Multi Turn, Cermet, Top Adjust, 10 kohm, Through Hole, 12 Turns 10K Bourns 1 Buy Now
Pin Header, Wire-to-Board, 2.54 mm, 1 Rows, 2 Contacts, Through Hole Right Angle, KK 254 7478 Molex 2 Buy Now
Pin Header, Signal, 2.54 mm, 1 Rows, 3 Contacts, Through Hole Right Angle, KK 254 7478 Molex 1 Buy Now
Pin Header, Signal, 2.54 mm, 1 Rows, 4 Contacts, Through Hole Right Angle, KK 254 7478 Molex 1 Buy Now
Pin Header, Signal, Wire-to-Board, 2.54 mm, 1 Rows, 5 Contacts, Through Hole Right Angle Molex 1 Buy Now
Pin Header, Signal, Wire-to-Board, 2.54 mm, 1 Rows, 6 Contacts, Through Hole Right Angle Molex 1 Buy Now
Fixed LDO Voltage Regulator, 2.6V to 27V, 1.3V Dropout, 5Vout, 5Aout, TO-220-3 Texas Instruments 1 Buy Now
DIODES INC. Schottky Rectifier, 60 V, 3 A, Single, DO-201AD, 2 Pins, 740 mV Diodes Inc. 1 Buy Now
LITTELFUSE Fuseholder, PCB, 1 Fuse, 6.3 A, 250 VAC, 250 VDC, TE5, TR5, Solder Lug Littelfuse 1 Buy Now
LITTELFUSE Fuse, PCB Leaded, 1.6 A, 250 V, TR5 370 Series, Fast Acting, Radial Leaded Littelfuse 1 Buy Now
KYCON DC Power Connector, Jack, 3.5 A, 2 mm, PCB Mount, Through Hole Kycon 1 Buy Now
XP POWER AC/DC Power Supply, ITE & Medical, 1 Output, 10 W, 5 VDC, 2 A XP Power 1 Buy Now
XP POWER Power Supply Accessory, Interchangeable AC Input Plug, Euro, ACM Series XP Power 1 Buy Now
KOA Through Hole Resistor, 330 ohm, CF, 250 mW, ± 5%, Axial Leaded, 300 V KOA 1 Buy Now
KOA Through Hole Resistor, 100 kohm, CF, 250 mW, ± 5%, Axial Leaded, 300 V KOA 1 Buy Now
MULTICOMP PRO Electrolytic Capacitor, 10 µF, 25 V, ± 20%, Radial Leaded, Polar Multicomp Pro 1 Buy Now
MULTICOMP PRO Electrolytic Capacitor, 22 µF, 16 V, ± 20%, Radial Leaded, 2000 hours @ 85°C Multicomp Pro 1 Buy Now
MULTICOMP PRO Electrolytic Capacitor, 10 µF, 16 V, ± 20%, Radial Leaded, 2000 hours @ 85°C Mulitcomp Pro 1 Buy Now
KEMET Multilayer Ceramic Capacitor, 0.1 µF, 50 V, ± 10%, Radial Leaded, X7R, 5.08 mm Kemet 2 Buy Now
Speaker, Mini, 5 cm, 3 W, 50 ohm, 180 Hz to 17000 Hz Visaton 1 Buy Now
MULTICOMP PRO 6MS1S3M1RESlide Switch, SPDT, On-On, Through Hole, Side Actuator, 100 mA, 20 V Mulitcomp Pro 1 Buy Now
PCB Receptacle, Board-to-Board, 2.54 mm, 1 Rows, 24 Contacts, Through Hole Mount, Tiger Claw BCS Samtec 2 Buy Now
Additional Parts:
ESP32 DOIT DEVKIT 1,0  Aliexpress or local store
I used: https://nl.aliexpress.com/item/32797879940.html
PCB-> use the included pcb production files to order a pcb at your prefered manufacturer
or get it here:  https://www.tindie.com/products/35039/
I2S Audio Board based on MAX98357
https://nl.aliexpress.com/item/1005005985389931.html
INMP441-MEMS-I2S-MIC-MODULE
I used: https://nl.aliexpress.com/item/1005005933408624.html
ledstrip WS2812 approx. 1 meter
I used: https://nl.aliexpress.com/item/4001322411818.html
8-Bit Max7219 60 × 60 Dot Matrix Module Microcontroller Led Display Module Voor Diy Kit
I used: https://nl.aliexpress.com/item/1005006222492232.html
TM1637 Led Display Module 0.56 Inch 6 Digitale Led Indicator Buis Voor Arduino
I used: https://nl.aliexpress.com/item/1005002060120661.html
Downloads and Links:
  • Code and PCB Design Files inc arduino youtube-api snapshot
  • https://github.com/witnessmenow/arduino-youtube-api
element14 presents
element14 presents  |  About Mark Donners |  Project Videos
  • Smart Youtube Counter with Audio Analyzer
  • mark donners
  • e14presents
  • Audio analyzer
  • web based analyzer
  • arduino ide
  • The Electronic Engineer
  • e14p_MD
  • friday release
  • friday_release
  • lego bricks
    DAB over 2 years ago
    Fun build, well done.
  • donnersm
    donnersm over 2 years ago in reply to manojroy123
    What ever stats you can mine from the net, you can display. Go for it!
  • manojroy123
    manojroy123 over 2 years ago
    I am looking to make similar thing for click through rate count and Conversation rate. Very Inspiring project.
