Project Videos
  • Project Videos
Project Videos
Documents How Far Can I2C Go? -- Episode 666
  • Author Author: cstanton
  • Date Created: 23 May 2025 9:30 AM Date Created
  • Last Updated Last Updated: 23 May 2025 11:10 AM
  • Views 4746 views
  • Likes 8 likes
  • Comments 23 comments
Have you ever wondered if the humble I2C protocol, designed for short-distance communication on a PCB, could work over a stretched-out distance? Clem, an innovative DIY enthusiast, dives headfirst into this question in his latest experiment. Armed with two Raspberry Pi Pico microcontrollers, a coiled-up RG58 coaxial cable, and a few unconventional ideas, he sets out to see if I2C can bridge the gap between devices separated by meters—even outdoors.
Watch the Episode
The Problem: Taking I2C Beyond the PCB
I2C (Inter-Integrated Circuit) is a reliable protocol, but it’s typically intended for communication between components within a single PCB or, at best, over very short distances. The main challenge? Capacitance—as wires get longer, their ability to maintain signal integrity decreases. Clem had an ambitious thought: What if he could use I2C as a bus system running throughout his workshop to connect micro-controllers and sensors scattered across different areas? Could it work over 10 or even 20 meters of cable? Only one way to find out—test it.
The Setup: Breadboards, Raspberry Pi Picos, and Coaxial Cable
Clem began his experiment with a simple setup on breadboards. Using two Raspberry Pi Pico micro-controllers, he established a basic I2C connection with standard jumper wires to simulate a local, short-distance connection. With the baseline working, it was time to introduce the star of the experiment: a 10-meter-long RG58 coaxial cable. Why coaxial? Its shielding properties make it a good candidate for reducing interference, a critical factor when extending the range of I2C.
He connected the two micro-controllers through the coiled cable and ran initial tests. The results were promising—communication was intact! But Clem wasn’t done yet. He wanted to push the boundaries even further.
Taking It Outside: Testing I2C Over 20 Meters
With the system working over 10 meters of cable, Clem decided to push his experiment to the extreme. He ran the coaxial cable through a cellar window and out into his garden, effectively extending the distance to 20 meters. The sight of an I2C bus stretching through a garden might have seemed bizarre, but it was all in the name of science!
To his delight, the I2C communication still worked. By using the RG58 cable's shielding to his advantage, Clem demonstrated that the protocol could handle significant distances, far beyond its typical use case.
Bill of Materials
Raspberry Pi pico H Raspberry Pi 2 Buy Now
RG58 50Ohm Coaxial Cable Multicomp Pro 20 Buy Now
Supporting Code and Links
  •  Supporting Files for Episode 666 of element14 presents
element14 presents
element14 presents  |  About Clem  |  Project Videos
  • i2c bus length limit
  • i2c over coaxial cable
  • rg58 i2c testing
  • i2c wiring tips
  • extend i2c range
  • microcontroller i2c setup
  • i2c protocol tutorial
  • long range i2c experiment
  • raspberry pi pico i2c
  • i2c with raspberry pi
  • i2c communication distance
  • i2c on breadboard
  • i2c signal integrity
  • i2c workshop project
  • friday_release
  • i2c long distance
  • mayermakes
    mayermakes over 1 year ago in reply to kmikemoo +1
    you erased the erase out of the board.
  • colporteur
    colporteur over 1 year ago
    Enjoyed the video presentation. Question: Why is the receives Element 14 breadboard cantilevered over the edge? How did you move it with out destroying the board. Mine I very secure.
    Nostalgia time. I pulled out an old plastic container of I2C hardware. I couldn't find any live links to quick2wire info. I dabbled in I2C when I had my first Pi B using these modules, thinking of making a bus.
    I have a Pi interface board still not assembled. Time for a yard sale!
  • mayermakes
    mayermakes over 1 year ago in reply to colporteur
    the breadboard is moved to make room for an Arduino Mega mounted on the board to use with the breadboard, but I needed that Mega for another project so its no longer there. the breadboard is secured with 2 screws underneath, just had to unscrew it and use the other hole to resecure it., the now free hole is used to mount the Arduino.
    hurray for yard sales, thats where I got a ton of project materials.
  • colporteur
    colporteur over 1 year ago in reply to mayermakes
    Well lookie there, it has screws. I had a unit where the breadboard used two sided sticky table. I destroyed the breadboard trying to get it separated. Hummm move it over to make room for a pi on legs. That was supposed to be my inside voice:)
  • mayermakes
    most sticky tape can be soaked with IPA to loosen it, sometimes a bit of acetone is needed.
    Jan Cumps over 1 year ago in reply to mayermakes
    or warmed up with (not too) hot air
  • colporteur
    Way more chemicals involved than I care to try.
  • kmikemoo
    kmikemoo over 1 year ago in reply to mayermakes
     mayermakes Laughing  Ah, yes.  Acetone.  Very effective BUT it will come at a cost - because it is effective.  When the dry erase board didn't erase, my wife grabbed my can of Acetone.  Now I have bought a new dry erase board.  Joy
  • mayermakes
  • colporteur
    colporteur over 1 year ago in reply to kmikemoo
    Ah yes, I've experienced the quick-fix or have-you-tried replacement model. What was I thinking is usually the post project review question:)
  • colporteur
