Project Videos
  • Project Videos
Project Videos
Documents Raspberry Pi Auto Etch A Sketch™︎ -- Episode 372
  • Author Author: kellyhensen
  • Date Created: 20 Nov 2018 7:52 PM Date Created
  • Last Updated Last Updated: 14 Dec 2018 8:24 AM
  • Views 4921 views
  • Comments 17 comments
Raspberry Pi Auto Etch A SketchTm
element14 presents  |  daftmike's VCP Profile  |  Project Videos
In this video Mike builds an automatic Etch A SketchTm machine using stepper motors and 3D printed gears.
Bill of Material:
Product NameManufacturerQuantity
Buy Kit
Raspberry Pi 3 Model B+, BCM2837B0 SoC, IoT, PoE, NOOBS Included
RASPBERRY-PI1Buy Now
Raspberry Pi DC Stepper Motor Hat Develo
ADAFRUIT1Buy Now
3D Printer Filament, 1.75 mm, PLA, Red, 1 kgMULTICOMP1Buy Now
Stepper Motor, High Torque, DC, 0.5 N-m, 1.8 A, Two Phase, 1.75 ohm, 3.3 mHNANOTEC1Buy Now
CONTINUOUS ROTATION SERVOADAFRUIT1Buy Now
Arduino Flip Code:
  GY-521 IMU test code for flipping the etch a sketch - daftmike 2018
#include <Wire.h>
#include <Servo.h>
// Servo is attached to pin 5
Servo servo;
const int servoPin = 5;
// Variables used for the IMU readings
long accelX, accelY, accelZ;
float gForceX, gForceY, gForceZ;
long gyroXCali = 0, gyroYCali = 0, gyroZCali = 0;
long gyroXPresent = 0, gyroYPresent = 0, gyroZPresent = 0;
long gyroXPast = 0, gyroYPast = 0, gyroZPast = 0;
float rotX, rotY, rotZ;
float angleX = 0, angleY = 0, angleZ = 0;
long timePast = 0;
long timePresent = 0;
// Variables used to keep track of the 'flip'
bool flipStarted = 0;
bool flipFinished = 0;
int flips = 0;
int servoDir = 90;
// String to hold the serial data from the Pi
String piMsg;
// Speed, angle and number of 'flips'
const int forwardSpeed = 60;
const int backwardSpeed = 180;
const int numFlips = 5;
const int lowAngle = -140;
const int midAngle = -120;
void setup() {
  Serial.begin(9600);  // start the serial port
  Wire.begin();  // start i2c
  setUpMPU();  // start IMU coms
  calibrateGyroValues();
  timePresent = millis();  // time reference for IMU readings
void loop() {
  readAndProcessAccelData();
  readAndProcessGyroData();
  readPi();
void servoFlip() {
  if (servoDir == 90) {
  servo.attach(servoPin);
  servoDir = forwardSpeed;
  servo.write(servoDir);
  Serial.println("flip started, servo moving forward...");
  flipStarted = 1;
  if (flipStarted == 1) {
   if (servoDir == forwardSpeed && angleX < lowAngle && flips < numFlips) {
  servoDir = backwardSpeed;
  Serial.println("servo backward...");
  flips++;
  Serial.print("flip number: ");
  Serial.println(flips);
   if (servoDir == backwardSpeed && angleX > midAngle && flips < numFlips) {
  Serial.println("servo forward...");
  flips++;
   if (servoDir == backwardSpeed && -2 < angleX) {
  Serial.println("turning servo OFF...");
  servo.detach();
  servoDir = 90;
  flips = 0;
  flipStarted = 0;
   delay(2000);
   setUpMPU();
void readPi() {  // read data from the serial port into a string to check for messages
  if (Serial.available()) {
  piMsg = Serial.readString();
   if (piMsg == "flip") {
   servoFlip();
   else if (piMsg == "cali") {
  Serial.println("calibrating gyro values...");
   setUpMPU();
void setUpMPU() {
  // power management
  Wire.beginTransmission(0b1101000);  // Start the communication by using address of MPU
  Wire.write(0x6B);  // Access the power management register
  Wire.write(0b00000000);  // Set sleep = 0
  Wire.endTransmission();  // End the communication
  // configure gyro
  Wire.write(0x1B);  // Access the gyro configuration register
  // configure accelerometer
  Wire.write(0x1C);  // Access the accelerometer configuration register
void calibrateGyroValues() {
  for (int i = 0; i < 5000; i++) {
   getGyroValues();
  gyroXCali = gyroXCali + gyroXPresent;
  gyroYCali = gyroYCali + gyroYPresent;
  gyroZCali = gyroZCali + gyroZPresent;
  gyroXCali = gyroXCali / 5000;
  gyroYCali = gyroYCali / 5000;
  gyroZCali = gyroZCali / 5000;
void readAndProcessAccelData() {
  Wire.write(0x3B);
  Wire.requestFrom(0b1101000, 6);
  while (Wire.available() < 6);
  accelX = Wire.read() << 8 | Wire.read();
  accelY = Wire.read() << 8 | Wire.read();
  accelZ = Wire.read() << 8 | Wire.read();
  processAccelData();
void processAccelData() {
  gForceX = accelX / 16384.0;
  gForceY = accelY / 16384.0;
  gForceZ = accelZ / 16384.0;
void readAndProcessGyroData() {
  gyroXPast = gyroXPresent;  // Assign Present gyro reaging to past gyro reading
  gyroYPast = gyroYPresent;  // Assign Present gyro reaging to past gyro reading
  gyroZPast = gyroZPresent;  // Assign Present gyro reaging to past gyro reading
  timePast = timePresent;  // Assign Present time to past time
  timePresent = millis();  // get the current time in milli seconds, it is the present time
  getGyroValues();  // get gyro readings
  getAngularVelocity();  // get angular velocity
  calculateAngle();  // calculate the angle
void getGyroValues() {
  Wire.write(0x43);  // Access the starting register of gyro readings
  Wire.requestFrom(0b1101000, 6);  // Request for 6 bytes from gyro registers (43 - 48)
  while (Wire.available() < 6);  // Wait untill all 6 bytes are available
  gyroXPresent = Wire.read() << 8 | Wire.read();  // Store first two bytes into gyroXPresent
  gyroYPresent = Wire.read() << 8 | Wire.read();  // Store next two bytes into gyroYPresent
  gyroZPresent = Wire.read() << 8 | Wire.read();  // Store last two bytes into gyroZPresent
void getAngularVelocity() {
  rotX = gyroXPresent / 131.0;
  rotY = gyroYPresent / 131.0;
  rotZ = gyroZPresent / 131.0;
void calculateAngle() {
  // same equation can be written as
  // angleZ = angleZ + ((timePresentZ - timePastZ)*(gyroZPresent + gyroZPast - 2*gyroZCalli)) / (2*1000*131);
  // 1/(1000*2*131) = 0.00000382
  // 1000 --> convert milli seconds into seconds
  // 2 --> comes when calculation area of trapezium
  // substacted the callibated result two times because there are two gyro readings
  angleX = angleX + ((timePresent - timePast) * (gyroXPresent + gyroXPast - 2 * gyroXCali)) * 0.00000382;
  angleY = angleY + ((timePresent - timePast) * (gyroYPresent + gyroYPast - 2 * gyroYCali)) * 0.00000382;
  angleZ = angleZ + ((timePresent - timePast) * (gyroZPresent + gyroZPast - 2 * gyroZCali)) * 0.00000382;
void printData() {
  Serial.print("X : ");
  Serial.print(angleX);
  Serial.print("° | Y : ");
  Serial.print(angleY);
  Serial.print("° | Z : ");
  Serial.print(angleZ); Serial.println("°");
Supporting Files:
Click Here for access to all the supporting files you will need to replicate this build!
Auto-Etch-A-Sketch-master.zip
  • episode 372: raspberry pi auto etch a sketch™
  • raspberri pi
  • friday_release
  • e14presents_daftmike
  • Sean_Miller
    Sean_Miller over 7 years ago +4
    Great use of joints in Autodesk Fusion. That is a critical skill to master. It allows one's prints to do what you want with the first printed part attempt - preventing hours of rework. Surprisingly low…
    DAB over 7 years ago +3
    Nice build. I recently saw another post where someone used a CNC cad program to drive the stepper motors to do a similar task with the etchasketch. Adding the self erase feature was a good modification…
  • mayermakes
    mayermakes over 7 years ago +2
    Compliment on the stunnign print quality of your 3d printed parts, and awesome build!!
  • Sean_Miller
    Surprisingly low backlash on the gears as well.
    Great project!
    Sean
  • Sean_Miller
    Great project!
    Sean
  • daftmike
    daftmike over 7 years ago in reply to Sean_Miller
    Thanks Sean. You're right, it's really useful to try things out in CAD before printing, especially with larger parts.
    The gears came out really well, there's a bit of sloppiness in the etch a sketch itself but I think that can be tuned out in software.
  • Sean_Miller
    Sean_Miller over 7 years ago in reply to daftmike
    I found with our tennis ball pitch machine project last year that spur gears can be noisy.  We switched over to a belt drive.  For the etchasketch, it might be interesting to try small timing belts like you see in a 3D printer.  However, your gears looked to mesh pretty good.
    This is one of my favorite sources for drive gear...
    Small Mechanical Components: Precision Gears, Timing Belts, Gear Assemblies, Timing Belt Pulleys, Couplings, Bearings an…
    See ya',
    Sean
