Project Videos
  • Project Videos
Project Videos
Documents Mendel 3D Printer Upgrade and Maintenance -- Episode 473
  • Date Created: 18 Nov 2020 7:58 PM Date Created
  • Last Updated Last Updated: 20 Nov 2020 8:24 AM
  • Views 3655 views
  • Comments 9 comments
By now a lot of you might have an old cheap 3D printer around. Clem upgrades his old cheap fire hazard of a 3D printer with a genuine Arduino Mega running Marlin 2.0 and a Custom made PCB to give it quick access buttons for functions  like Filament loading and Unloading and increase its security features with independent measurement of temperatures and Heater voltage and current. While upgrading his own machine he walks you through the settings you need to properly configure your machine should you choose to upgrade it.
Supplemental Material:
  • Bonus Content: Mendel 3D Printer: Marlin 2.0 Configuration Walkthrough
  • Bonus Content: Mendel 3D Printer: Custom Arduino Code Walkthrough
  • Order the 3d printer Tester Addon Board at Aisler.net: https://aisler.net/p/IYJACNWM
  • Download the latest marlin version:  https://marlinfw.org/meta/download/
  • Shop for 3D Printers in the US Store or the UK Store
Bill of Material:
TEXAS INSTRUMENTS Current Sense Amplifier, 1 Amplifier, SOIC, 8 Pins, -40 °C, 125 °C TI 2 Buy Now
BOURNS SMD Current Sense Resistor, 0.1 ohm, CR Series, 2512 [6432 Metric], 3 W, ± 1%, Metal Film BOURNS 2 Buy Now
MIDAS Graphic OLED, 64 x 32 Pixels, White on Black, 3V, I2C, 14.85mm x 16.6mm, -40 °C MIDAS 1 Buy Now
SAMTEC PCB Receptacle, Board-to-Board, 2.54 mm, 1 Rows, 8 Contacts, Through Hole Mount, SSQ Series SAMTEC 1 Buy Now
SAMTEC PCB Receptacle, Elevated Strip, Board-to-Board, 2.54 mm, 2 Rows, 40 Contacts, Through Hole Mount SAMTEC 1 Buy Now
ARDUINO Development Board, Arduino Mega 2560, ATmega2560 MCU, 54 5V I/O, 16 Analogue Inputs, 4 UARTs ARDUINO 1 Buy Now
OMEGA PCC-SMD-20 Connector OMEGA 4 Buy Now
TMC2208 SILENTSTEPSTICK Trinamic 4 Buy Now
Additional Parts:
Product Name
Ramps 1.4
old junky 3d printer
Printastick (aprintapro.com)
Mendel3DPrinter_Resources.zip
element14 presents
element14 Presents  |  About Clem  |  Project Videos
  • clem
  • 3d printer firmware
  • trinamic
  • e14presents_mayermakes
  • how to refurbish a 3d printer
  • how to flash marlin 2.0
  • easy 3d printer calibration
  • best 3d printer upgrades 2
  • how to troubleshoot 3d printer
  • samte
  • ramps1
  • firmware update
  • 8bit vs 32bit
  • 3d printer troubleshooti
  • 4 config
  • how to configure marlin 2.0
  • bourns
  • midas
  • friday_release
  • 3d printer troubleshooting
  • arduino mega
  • mayermakes
  • e14p_CMM
  • mfetting
    mfetting over 5 years ago +2
    The five areas that I will be interested in learning: Improvements for ease of use Ways to increase my print accuracy How to improve printer speed Ways to increase my printers build envelope Overall reliability…
  • airbornesurfer
    airbornesurfer over 5 years ago +2
    I may have to try this on my old Robo3D. It's seen MUCH better days! Also: I have the skeleton of a mini milling machine sitting in the corner, and I'm wondering if I couldn't apply this to get that up…
    DAB over 5 years ago +2
    Very good project Clem. Great job of providing useful tips for new and old 3D printers. DAB
  • aspork42
    aspork42 over 5 years ago
    Dang that is cool!
    I think I own the same "cheap printer"... I picked it up a couple years back right when I did the Smart Range Hood project on E14.
    About two weeks ago I started doing a new custom build to create a 400 mm ^3 build volume printer which uses Core XY movement. I'll have to start blogging about it. I've been taking in all the different 3D printer tips and tricks and build notes that I can find. I really like the idea of a custom PCB to monitor current consumption and how you can "man-in-the-middle" from your board to send custom GCode. I may follow that route!
    Both Octoprint and Marlin can detect thermistor errors which is great. I was always curious if there was a way to detect issues when stranded-core wire starts to fatigue and do something before the cable melts itself and catches fire...
  • mayermakes
    mayermakes over 5 years ago in reply to aspork42
    yes, that addon board exactly aims for such failures, that would not trigger the firmware, like fatigue or a general drift.
    Also if you want you can use the code and blueprint of the addon to make a jogg controller similar to what DJ did to his shapeoko in a previous episode. its basically the same thing from the harware perspective.
    that might come in handy when calibrating your setup and levelling it.
    if you can add a serial output that gives the current (in code values) for thermistors to the addon mcu and compare it to the measurements (giving that both have been calibrated prior to the same resistor)
    you wiould be able to see fatigue in wires and connectors or even predict failures.
    for now I do it by "brain".
    meaning I compare the values I read over octoprint with the values measured by the board..but it sjust a matter of putting the time into  the code.
  • mayermakes
