sudo Sergeant
  • sudo Sergeant
sudo Sergeant
Documents sudo Sergeant 11: Account Management
Join sudo Sergeant to participate - click to join for free!
  • Date Created: 7 Dec 2017 8:32 PM Date Created
  • Last Updated Last Updated: 24 Feb 2018 3:02 AM
  • Views 1638 views
element14's The Ben Heck Show
sudo Sergeant
The Learning Circuit
See All Episodes
Linux is a multi-user operating system that allows more than one user to use Linux at the same time.  An important role of a system administrator is managing accounts.  Felix goes over some of the mechanisms used for account management.  He shows you how to create accounts, modify accounts, and remove accounts.
From terminal, Felix takes a look at all the accounts on his machine:
$ cat /etc/passwd
This takes him to all the accounts that are on the system. To add an account you would use:
$ sudo useradd  -m  -G  sudo -s /bin/bash username
This creates a user account named username with sudo privileges.  To login to your new account you will need to first setup a password:
$ sudo passwd username
You’ll be asked to create a new password and the system will tell you when it has been updated. To login to your new account you would switch users using:
$ su username
To get out of the directory you were just in use:
$ cd ~
You’ve now created a new account, given it a password, given it sudo privileges, created a login shell, and home directory. You can now view the new user account by using:
$ cat/etc/password
To change the directory that the user account is located in use:
$ sudo usermod  -d /home/newdirectory  -m user
This will change the directory from username to user. To change the shell from /bin/bash to /bin/zsh you would use:
$ sudo usermod   -s /bin/zsh
To change the account name you would use following command:
$ sudo usermod   -l newusername username
This changes the account name from username to newusername.   You can confirm this by typing in:
$ cat /etc/passwd
To add a system account you would use the user add instruction again:
$ sudo useradd  -r  -s  /usr/nologin  system-account
This would be useful, for instance, if you had some kind of a background daemon running that needed a user.  You would assign a system account to the group.  To delete this account when you no longer need it, you would use the following command:
$ sudo userdel  -r system-account
  • multiuseroperatingsystem
  • putty
  • system administration
  • open source
  • command line
  • sudo
  • sudosergeant
  • linux
    DAB over 8 years ago +2
    Nice episode Felix. Thanks for reminding me why I don't use Linux. DAB
  • Workshopshed
    Workshopshed over 8 years ago +2
    Great episode although perhaps a bit mean to give your aunt an account called potatohead.
  • Workshopshed
  • Workshopshed
