sudo Sergeant
  • sudo Sergeant
sudo Sergeant
Documents sudo Sergeant 21: 3D Desoldering a Raspberry Pi A+
Join sudo Sergeant to participate - click to join for free!
  • Date Created: 25 Jun 2018 4:41 PM Date Created
  • Last Updated Last Updated: 13 Aug 2018 11:05 PM
  • Views 1783 views
element14's The Ben Heck Show
sudo Sergeant
The Learning Circuit
See All Episodes
Felix does something different and focuses on hardware.  He field strips the Raspberry Pi A+ by removing the GPIO, USB port, MIPI camera interface (CSI) connector, HDMI, and  composite video, leaving the power and SD slot in place.  If you don't have a lot of space, where do you want to slim down the Raspberry Pi to keep things really compact? Soldering overflow pins gets them flowing to get ready for the solder sucker.  If you have a different method of field stripping a Raspberry Pi, or you want to see another device field stripped, let us know in the comments below!
  • usb port
  • field strip
  • pins
  • csi
  • mipi camera interace
  • gpio
  • rpibeginner
  • raspberry pi a+
  • soldering station
  • desoldering
  • e14presents_sudosergeant
  • sudosergeant
  • koudelad
    koudelad over 8 years ago +2
    Felix, Rule number one in desoldering is "Add flux". That is why all your desoldering work in the video feels so sticky. When you melt solder (new joint or adding to an existing joint), the flux degrades…
  • koudelad
    koudelad over 8 years ago +1
    There is also a ChipQuik low temperature melting point alloy that can be added to existing joints and provides the user longer time for desoldering, before the alloy gets solid again. Haven't tried that…
  • airbornesurfer
    airbornesurfer over 8 years ago in reply to koudelad +1
    Ben had an interesting little inexpensive desoldering pump that he used in a video a while back (the Vectrex, maybe?). Newark has them for about $40, so it's well within the range of the home gamer, I…
  • koudelad
    There is also a ChipQuik low temperature melting point alloy that can be added to existing joints and provides the user longer time for desoldering, before the alloy gets solid again. Haven't tried that personally, but there is a lot of videos on Youtube.
  • koudelad
