The Electronics Inside
  • The Electronics Inside
Blog Dishwasher Fault Finding and Repair
Join The Electronics Inside to participate - click to join for free!
  • Author Author: a531016
  • Date Created: 6 Oct 2022 3:12 PM Date Created
  • Views 1386 views
  • Likes 9 likes
  • whitegoods
  • dishwasher
  • teardown
  • the electronics inside
a531016
a531016
6 Oct 2022
Since my dishwasher started acting up, and I was going to take it apart, it only seemed appropriate to share it with the community! From the outset I suspected a mechanical issue, not an electrical one, but since it was open any way, it was a good oportunity to take a look inside.
  • a531016
    a531016 over 4 years ago in reply to dang74
    And this really was rewarding! The trick is finding just the right moment in time when I won't get in trouble at home for taking the dishwasher apart if the new replacement doesn't work!
    What features would you look to add if we did replace the controls? Smart home integration, notification on completion, electricity tariff tie in?
  • dang74
    dang74 over 4 years ago
    It's always rewarding to fix something.  I like the 'teaser' at the end when you suggest the possibility to change out the dish washer's stock electronic controller with a custom design instead.
  • a531016
    a531016 over 4 years ago in reply to DAB
    Thanks DAB. I was expecting to find a failed seal that may have been a challenge to replace, so finding a loose connection was a big relief!
    I like the idea of replacing the contoller as a fun project, however, I wonder how hard it will be to replicate the programs exactly?
    DAB over 4 years ago
    Good investigation to find the problem.
    It is always a challenge to find out what a device should do verses what it is failing to do.
