The Electronics Inside
  • The Electronics Inside
Documents Minidisc MZ-R410 vs 2000's WM-EX631 Walkman Teardown -- The EIectronics Inside 37
Join The Electronics Inside to participate - click to join for free!
  • Date Created: 22 Mar 2021 10:41 PM Date Created
  • Last Updated Last Updated: 9 Dec 2020 8:24 AM
  • Views 2749 views
  • Comments 8 comments
element14 presents
element14 Presents  |  About David   |  Project Videos  |  The Electronics Inside
With just a year between them, how do a tape playing Walkman compare to a Minidisc?
  • tei
  • portable music
  • walkman
  • electronic integration
  • old electronics
  • minidisc
  • e14presents_davidedwards
  • the electronics inside
  • tp86
    tp86 over 2 years ago
    a531016 Hi mate. Yesterday I watched your youtube video on the Sony WM-EX631 teardown. It was very interesting. I unfortunately need to replace or at least probe to diagnose my hold SPDT switch. To do this I need access to the mainboard on the side the tape cassete goes. I was wondering if you managed to get access to this side of the mainboard. Did you do it the way the manual suggests by desoldering the motor solenoid and cable pins? I just curious if there was an easier way.  Many thanks in advance for any advice. Tom P
    Reference video:  www.youtube.com/watch
  • a531016
    a531016 over 5 years ago in reply to beacon_dave
    Wow - good find, thank you!
    beacon_dave over 5 years ago in reply to a531016
    "... The two that switches on the Walkman would pick up Read only and Type II - But why? ..."
    It looks like the outer larger switch is actually a 'cassette tape inserted' detection switch rather than a write protect hole detection switch. It must be large enough to pass over the hole.
    Here is a similar set-up on the WM-EX674 showing the ATS / Tape switches
    https://www.petervis.com/electronics%20guides/Sony%20WM-EX674/Sony%20WM-EX674%20ATS%20Switch.html
    The type IV metal detection ability would require another switch which is not shown however.
    "...I didn't know that about the Minicassette though?..."
    Neither did Stanley Kubrick by the looks of it:
    "A Mini-Cassette of Beethoven’s Symphony No. 9 can be seen in the 1971 film A Clockwork Orange, but the Mini-Cassette was not used for music recordings (unlike the Microcassette)."
    https://obsoletemedia.org/mini-cassette/
    https://obsoletemedia.org/microcassette/
    https://obsoletemedia.org/metal-tape-microcassette/
    Micro-cassette vs Mini-cassette tape path diagram
  • a531016
    I know! I knew I said it wrong in the moment and couldn't get it off the tip of my tounge what I was trying to say!
    I didn't know that about the Minicassette though? Wouldn't that mean a variable quality over the length of the tape as it spooled faster and the driven roll got bigger? Although I guess quality can be tuned for the human voice much more with a dictaphone?
    Good point on the type material, the read only tab was the outer most, then a tab for type II next to it. Type 4 tape was much closer to the middle of the tape. The two that switches on the Walkman would pick up Read only and Type II - But why? I seem to think at this time most good HiFi sets were slot loading for casssettes? And I don't think you'd use this highly engineerd miniture mechanism if space wasn't an issue? Interesting question!
  • a531016
    a531016 over 5 years ago in reply to DAB
    Thank you DAB!
    They were known as 'Compact Cassette' in the UK.
    The smaller Dictaphone/answering machine cassettes being known as 'Minicassette' (Philips ?) and 'Microcassette' (Olympus ?).
    I seem to recall that the Minicassette was spool driven, whereas the Microcassette was capstan driven like the Compact Cassette.
    The microswitch notches on the back of the cassette were write protect on the outside, then type II chrome immediately next to it, then type IV metal much further in towards the centre of the cassette. Why it would have a write protect detect switch is a bit of a mystery unless it shared the same chassis as the recording Walkmans.
    DAB over 5 years ago
    Another great tear down.
    Well done.
