The Learning Circuit
  • The Learning Circuit
Documents Intro to Arduino -- The Learning Circuit 11
  • Date Created: 7 May 2018 3:28 PM Date Created
  • Last Updated Last Updated: 9 May 2018 7:24 AM
  • Views 2924 views
  • Likes 14 likes
  • Comments 6 comments
element14's The Ben Heck Show
Join Karen as she shares her enthusiasm for teaching STEM subjects, gives you what you need to know to get started on electronics projects, and more.
Featured Bonus Content
See All Episodes
Karen gives an introduction to Arduino and the open-source platform that it is based on.  She explains what makes it a good platform for beginners and how you can take advantage of its ease-of-use and extensive documentation to get started with electronics projects.  The Arduino UnoArduino Uno, such as the one included with Arduino Starter KitArduino Starter Kit, is a great place to start if you’re new to Arduino.
Related Content:
  • The Learning Circuit 12: Arduino Starter Kit: Spaceship Interface
  • Introduction to Arduino
  • sudo Sergeant 04: Ditch the Arduino IDE for the Linux Terminal
  • Arduino, What is It Good For?
You can power an Arduino UnoArduino Uno through the power jack or the serial port.  You can also power it directly to pins VCC/GND. The Serial Port can be used for programming or you can program it through the ICSP header with an AVR programmer.  You would use GND and voltage pins to power components in your projects.  There's lot's of I/O for both digital and analog with pins for PWM so its versatile for a wide range of projects. Arduino makes it easy to plug in sensors and peripherals so that it can act as the brains of your electronic projects. There is no soldering required with Arduino and the board is well labeled for ease of programming.  The board includes a reset button, if there is something buggy with your program or project you can easily reset the microcontroller without having to mess with the code or a computer.
The microcontroller isn't soldered directly on the board, but instead is in a sociket. You can pop it out  and swap out just the chip, without replacing the whole board, should something happen. The Arduino uses its own IDE (integrated development environment).  The syntax is similar to C or C++ but does not require any prior programming knowledge. You can easily integrate many components with Arduino to sense your environment such as through heat, motion, light, and touch.  You can also use Arduino to affect your environment through motors, servos, LEDs, or as the brain of your electronics project.
For  motors and fans, they may be rated for more power, but try to get as low as you can near 3V. These motors and fans can handle more power, but will still work at 3V. Most LEDs are rated for 1.5-3V DC. Be careful with the LEDs. If they are fed too many volts, they’ll burn out and stop working. While that’s true for most components, LEDs tend to be less tolerant to voltages above their rating. We’ll also make blocks with interrupts, like buttons, switches, and potentiometers.
  • batteries
  • tlc
  • arduino uno
  • digital
  • avr programmer
  • arduino_vcp
  • e14presents_makerkaren
  • switches
  • io
  • simplified c
  • arduino ide
  • potentiometers
  • arduino_tutorials
  • vcc
  • motors
  • led
  • icsp
  • gnd
  • arduino starter kit
  • stem projects
  • analog
  • thelearningcircuit
  • airbornesurfer
    airbornesurfer over 8 years ago in reply to rivera82falcon +3
    Arduino is pretty awesome once you learn the system, and it's really set up as a "learn by doing" process, so it's extremely easy to get started even if you know jack squat about coding or circuits! The…
  • rivera82falcon
    rivera82falcon over 8 years ago +2
    Great intro video as I don't know squat about Arduino. Keep the videos coming and please do more videos on this. Curious...are you sitting at Ben's Desk??? Sorcery!!!
  • airbornesurfer
    airbornesurfer over 8 years ago +2
    Quite a thorough intro to Ardunio, Karen! Can't wait to see what comes next!
  • rivera82falcon
  • makerkaren
    makerkaren over 8 years ago in reply to rivera82falcon
    I was. I hadn't worked out screen cap only laptop yet, so I set up at his desk. Ben configures all his programs very specifically to his liking and it's always weird to use his computer for things. It compelled me to figure out how to do screen cap on my laptop so I will be able to do screen caps on my own machine in the future. We all love our toys the way we like them, I suppose.
  • makerkaren
