The Learning Circuit
  • The Learning Circuit
Documents Intro to DC Motors -- The Learning Circuit 41
  • Date Created: 25 Dec 2018 3:00 AM Date Created
  • Last Updated Last Updated: 20 Feb 2019 8:24 AM
  • Views 2164 views
  • Likes 8 likes
Intro to DC Motors
The Learning Circuit | element14 presents |  Project Videos
We've learned about how electricity and magnetism work together in inductors. Now see how those same coils and forces are used to turn electrical energy into mechanical energy in motors.
  • electromagnetism
  • e14presents_makerkaren
  • dc motors
  • mechanical energy
  • the learning circuit
  • coils
  • electrical energy
  • thelearningcircuit
  • makerkaren
    makerkaren over 7 years ago in reply to baldengineer +1
    I did! I picked up a Dremel Micro a while back and it's super useful for applications such as this. Diamond cutting wheels are great!
    jw0752 over 7 years ago +1
    Hi Karen, Another interesting presentation. Thanks John
    DAB over 7 years ago
    Good episode.
    Understanding the right hand rule is essential to fully understand the relationship between electric charge and magnetism.
    The electric field and magnetic field are always orthogonal. That means they must be oriented at 90 degrees to each other. Yes, the sign does matter.
    If you look at how solar particles interact with the Earth's magnetic field at the poles, you will notice that you get Aurora displays that appear to circle the magnetic pole. That orientation is the right hand rule in action.
    When a charged particle encounters a magnetic field, it encounters a force which causes it to rotate perpendicular to the magnetic field. For the north pole, the particles rotate clockwise. For the south pole, they rotate counterclockwise.
    Hi Karen,
    Thanks John
  • makerkaren
  • baldengineer
    baldengineer over 7 years ago
    Great job!
    I was wondering when you showed the PC fan if you were going to address brushless vs. brushed. Glad to see you did. Discussing the two different motor types isn't trivial, which made the video that more impressive.
    Did you take a Dremel to those motors to get the cut-away view? That was an awesome way to see inside of them!
