The Learning Circuit
  • The Learning Circuit
Documents How to Add Multiple Inputs to an Arduino using a Shift Register -- The Learning Circuit 78
  • Date Created: 3 Sep 2020 1:19 PM Date Created
  • Last Updated Last Updated: 10 Jun 2020 7:24 AM
  • Views 9593 views
  • Likes 10 likes
element14 presents
The Learning Circuit | element14 presents |  Project Videos
In this fourth and final video about shift registers, Karen shows how to use them to add inputs to an Arduino. Using one or more parallel-in serial-out shift registers, 8, 16, or more inputs can be added by using only 3 Arduino I/O pins.
Previous Episodes:
  • The Learning Circuit 75: How Shift Registers Work
  • The Learning Circuit 76: How to Make a 4-bit Shift Register Circuit
  • The Learning Circuit 77: How to Add Outputs to an Arduino Using a Shift Register
Bill of Material:
Product NameManufacturerQuantityBuy KitBuy Kit
Arduino Uno, ATmega328P MCU, 14 3.3V I/O, 6 Analogue Inputs, 6 PWM OutputsArduino1Buy NowBuy Now
Breadboard, MCM 60 rows, ABS, 8.5mm, 165mm x 56mmMulticomp2Buy NowBuy Now
SN74HC166NSN74HC166N - Shift Register, 74HC166, Parallel to Serial, Serial to Serial, 1 Element, 8 bit, DIP, 16 PinsTEXAS INSTRUMENTS2Buy NowBuy Now
Through Hole Resistor, 10 kohm,  250 mW, ± 1%TE Connectivity17Buy NowBuy Now
Tactile Switch, 12mm, Yellow, Top Actuated, Through Hole, Round Button, 24 VDC, 50mAOmron4Buy NowBuy Now
Tactile Switch, 12mm, Red, 12 VDC, 50mAMulticomp4Buy NowBuy Now
Tactile Switch, 12mm, Blue, Top Actuated, Through Hole, Round Button, 24 VDC, 50mAOmron4Buy NowBuy Now
Tactile Switch, 12mm, White, Top Actuated, Through Hole, Round Button, 24 VDC, 50mAOmron4Buy NowBuy Now
140 Pc. Jumper Wire Kit, 22 AWG, Solid, Assorted Lengths and ColorsTwin Industries1Buy NowBuy Now
Wire Kit, Jumper, Male to Male, Solderless, 100 mm - 250 mm, 75 PieceMCM2Buy NowBuy Now
USB Cable, USB Type A Plug, USB Type B Plug, 915 mm, 36.1 ", USB 2.0, BlackMULTICOMP1Buy NowBuy Now
Additional Parts:
Product Name
Computer with Arduino IDE
TLC_78 Resources.zip
  • arduino uno
  • e14presents_makerkaren
  • arduino ide
  • arduino_tutorials
  • multiple inputs
  • e14 presents
  • shift registers
  • makerkaren
    makerkaren over 5 years ago in reply to bemmett +1
    Thanks. They must have accidentally put the BOM for one of the other shift register episodes. I'll see about getting that corrected.
    DAB over 5 years ago
    Very good episode.
    You did a good job explaining the chip and its uses.
    Well done.
    Very good episode.
    Well done.
