The Learning Circuit
  • The Learning Circuit
Documents Making a 12 bit DAC Using an Arduino -- The Learning Circuit 96
  • Date Created: 24 Aug 2021 1:10 PM Date Created
  • Last Updated Last Updated: 24 Feb 2021 8:24 AM
  • Views 8895 views
  • Likes 8 likes
  • Comments 13 comments
element14 presents
The Learning Circuit | element14 presents |  Project Videos
Once analog signals have been processed by electronics and converted to digital, to convert them back to analog, a DAC is needed. In this video, Karen shows how to make an R-2R Ladder DAC using just resistors, all of the same value. The ladder uses 12 of the digital I/O on an Arduino Uno as its inputs. While the Ladder DAC will be 12-bit, Karen is able to use it to show the differences in resolution between a 4-bit, 6-bit, 8-bit, and 12-bit DAC, generating a sine wave as a visual demonstration.
Bill of Material:
Product NameManufacturerQuantityBuy KitBuy Kit
Through Hole Resistor, 1 kohm, 500 mW, ± 1%TT ELECTRONICS / WELWYN36Buy NowBuy Now
Breadboard, MCM 60 rows, ABS, 8.5mm, 165mm x 56mmMULTICOMP1Buy NowBuy Now
Arduino Uno SMD, ATmega328 MCUArduino1Buy NowBuy Now
Wire Kit, Jumper, Male to Male, Solderless, 100 mm - 250 mm, 75 PieceMCM1Buy NowBuy Now
MULTICOMP PRO USB Cable, Type A Plug to Type B Plug, 0.91 m, 3 ft, USB 2.0, BeigeMULTICOMP PRO1Buy NowBuy Now
Additional Parts:
Product Name
Computer for programming
  • digital
  • sine wave
  • port manipulation
  • converter
  • resolution
  • e14_makerkaren
  • conversion
  • analog
    DAB over 5 years ago +1
    Very good episode Karen. You did a great job of showing ADC resolution issues and how they affect the information you can pull out of an analog circuit. DAB
    beacon_dave over 1 year ago in reply to Mandy2710
    The original project code can be found here:
    https://www.hackster.io/instrumentation-system/dac-8-bit-using-r-2r-ladder-964837
    https://github.com/mfaliha/DAC-R-2R-Ladder-8-bit-Arduino-Uno
    Follow along with Karen in the video to make the changes.
  • Mandy2710
    Mandy2710 over 1 year ago
    Where i can get code of it
  • thiagoennes
    thiagoennes over 3 years ago in reply to beacon_dave
    let's call it poetic license :)
    beacon_dave over 3 years ago in reply to thiagoennes
    The DAC as per the episode title "Making a 12 bit DAC Using an Arduino" was 12bit and not limited by the ADC.
    The serial plotter (being used as an accessible alternative to an oscilloscope), was limited by the ADC in the Arduino to 10bit resolution.
    However as the demo jumped from 8bit to 12bit, the 10bit resolution on the serial plotter was still sufficient to show a difference from the 8bit output.
  • thiagoennes
    exactly... the 12bit demo was in fact 10bit limited by the adc.
    The ADC doesn't care about what created the signal. In each instance, it's just sampling the signal at its input with 10bit resolution, which is then being plotted.
  • thiagoennes
    How did you read a 12bit dac output with the 10bit adc from the arduino uno?
  • Hillary
    Hillary over 3 years ago in reply to makerkaren
    Hello! I actually tried this project and had so much fun testing it. I managed modified your code a little, you can check it out on my github: https://github.com/HillaryatGitHub/Multiple-Bit-DAC. Again thank you so much for making such an in depth video Sparkles
  • makerkaren
    makerkaren over 5 years ago in reply to koudelad
    That's.....a really good point. I'm not really sure. I'd have to have someone that knows Arduino code better than I, take a look at the code and see if there's anything that is reducing the visual output. But yeah, you're right. It looks like there are fewer steps than the full resolution each time. Hmmmmm.
  • koudelad
    koudelad over 5 years ago in reply to makerkaren
    At 5:04 at the video, you adjust the code to 4 bit resolution of the DAC. However, at 5:20, there are only 4 voltage levels. That is where I would expect to see 16 voltage levels, as you described.
    At 5:29 the code is adjusted to 6 bits, which should produce 64 different voltage level, however, I can only see 16.
    Or maybe I got something wrong...
