The Learning Circuit
  • The Learning Circuit
Documents Making a 12 bit DAC Using an Arduino -- The Learning Circuit 96
  • Date Created: 24 Aug 2021 1:10 PM Date Created
  • Last Updated Last Updated: 24 Feb 2021 8:24 AM
  • Views 8792 views
  • Likes 8 likes
  • Comments 13 comments
element14 presents
The Learning Circuit | element14 presents |  Project Videos
Once analog signals have been processed by electronics and converted to digital, to convert them back to analog, a DAC is needed. In this video, Karen shows how to make an R-2R Ladder DAC using just resistors, all of the same value. The ladder uses 12 of the digital I/O on an Arduino Uno as its inputs. While the Ladder DAC will be 12-bit, Karen is able to use it to show the differences in resolution between a 4-bit, 6-bit, 8-bit, and 12-bit DAC, generating a sine wave as a visual demonstration.
Bill of Material:
Product NameManufacturerQuantityBuy KitBuy Kit
Through Hole Resistor, 1 kohm, 500 mW, ± 1%TT ELECTRONICS / WELWYN36Buy NowBuy Now
Breadboard, MCM 60 rows, ABS, 8.5mm, 165mm x 56mmMULTICOMP1Buy NowBuy Now
Arduino Uno SMD, ATmega328 MCUArduino1Buy NowBuy Now
Wire Kit, Jumper, Male to Male, Solderless, 100 mm - 250 mm, 75 PieceMCM1Buy NowBuy Now
MULTICOMP PRO USB Cable, Type A Plug to Type B Plug, 0.91 m, 3 ft, USB 2.0, BeigeMULTICOMP PRO1Buy NowBuy Now
Additional Parts:
Product Name
Computer for programming
  • digital
  • sine wave
  • port manipulation
  • converter
  • resolution
  • e14_makerkaren
  • conversion
  • analog
    DAB over 5 years ago +1
    Very good episode Karen. You did a great job of showing ADC resolution issues and how they affect the information you can pull out of an analog circuit. DAB
