The Learning Circuit
  • The Learning Circuit
Documents micro:bit DIY Compass -- The Learning Circuit 57
  • Date Created: 21 Oct 2019 9:38 PM Date Created
  • Last Updated Last Updated: 21 Oct 2019 7:24 AM
  • Views 2440 views
The Learning Circuit | element14 presents |  micro:bit
Along with many other features, the BBC micro:bit has a built-in compass. The built-in magnetometer can sense the magnetic poles of the Earth. Navigational compasses usually have a piece of metal that is attracted to either the north or south pole of the Earth so that its arrow always points North. Watch as Karen shows how to make a more technical compass that can display not only arrows, but also the name of the direction being faced.
Bill of Material:
Product NameManufacturerQuantityBuy KitBuy Kit
BBC micro:bit go + 3V battery holder, USBBBC MICRO:BIT1Buy NowBuy Now
MAGNET, 1.6X1.6X12.7, H-31-MAGNETHamlin1Buy NowBuy Now
TLC_57_Code.zip
  • learning circuit
  • micro:bit led array
  • e14presents_makerkaren
  • microbit
  • stem projects
    beacon_dave over 7 years ago +1
    The display is a bit limited but you could perhaps create a treasure map type game where you create a starting location e.g. garden tree and then have to 'walk 10 paces North, walk 5 paces East, etc.'…
    Adding it to a rover bot you could perhaps recreate some of the features of the Milton Bradley 'Big Trak' toy from the 80's, or recreate a turtle type robot. Using the compass it should help with getting…
  • rajpot
    rajpot over 7 years ago +1
    Hello mam Karen hope you will be fine Iam new here few moments ago I join. Thanks a lot for sharing your unique experience
    The display is a bit limited but you could perhaps create a treasure map type game where you create a starting location e.g. garden tree and then have to 'walk 10 paces North, walk 5 paces East, etc.' and X finally marks the spot. Digging is optional but not always appreciated...
    The display could perhaps be enhanced by adding a ring of 36 LEDs around the micro:bit (high density addressable pixel LED strip formed into a ring ?) which would then give you 10degree intervals. North could be indicated by a steady red LED and then optionally a desired heading indicated by another colour or a flashing LED. A series of waypoints could be stored and recalled, with the LED matrix on the micro:bit scrolling text messages.
    Could also perhaps add an OLED display to get a higher resolution display for the compass needle.
    Logging of data is one advantage over a traditional compass so perhaps the compass combined with an accelerometer used as a pedometer could give you a log of direction and number of steps which could allow you to map out areas where GPS is ineffective, e.g. wooded areas.
