WorkBench Wednesdays
  • WorkBench Wednesdays
Blog Are you still using 7400-Series Logic, if so, where?
Join WorkBench Wednesdays to participate - click to join for free!
  • Author Author: baldengineer
  • Date Created: 9 Dec 2020 7:50 PM Date Created
  • Views 9499 views
  • Likes 11 likes
  • Comments 37 comments
  • 7400 logic chips
baldengineer
baldengineer
9 Dec 2020
Over the past several months, I have been learning about and repairing 8-bit computer and video game systems. So far, I have worked on the VIC-20, C64, ZX-81, Apple II, and have been learning about the TI 99/A.
It always amazes how much of these early computer systems were built almost entirely with standard 7400-series (LS and HC) chips.
Occasionally, I need to replace a 7400-series chip. (I always hope it is one of those and not one of the ASICs!) While looking for modern replacements, I have noticed the trend that they are becoming more scarce. The LS-series is almost entirely gone--and with good reason. While HC and HCT continue to be somewhat available, they are usually only available in surface-mount packages.
That leads me to the question: Who is still using the venerable 7400-series logic chips today?
To me, there are three groups that might be using them:
  1. Learning. Students and hobbyist learning about digital logic
  2. New Design. Hardware that needs glue-logic. Are these using multi-gate chips or the single-gate variants?
  3. Repair. Older electronics in need of replacements. Here is where I mostly sit.
Do you fit into one of those categories? If not, where do you land?
And THEN, which chips are the must-have on-hand?
Obviously, the answer depends on how you might be using them. But, I'm curious to know how you use 7400-series chips and which ones would you keep in stock?
  • michaelkellett
    michaelkellett over 5 years ago +13
    The high spot of my 74xxx design works was about 1987 when I designed this beastie. Subsequent designs used FPGAs or micro-controllers. I was lucky enough to find one on Ebay recently, not quite working…
    shabaz over 5 years ago +8
    Here an electronics chain called Maplin was selling 74-series TTL right until 2018, when it closed for good! I guess people were still buying them, perhaps to repair old equipment. I think this is the…
  • ralphjy
    ralphjy over 5 years ago +7
    I just used a couple of 4000 series logic chips in the Pong game that I rebuilt. And I have an assortment of 74 and 74LS (even some 54 mil grade parts) from the late 70s and early 80s when I did a lot…
    dougw over 5 years ago
    I still have some 7400 parts but I have more 4000 (CMOS) series parts. I only use them when I am breadboarding since they are DIPs (almost all my newer stuff is SMT). I actually use PCBs for prototypes, so it is a bit rare for me to build circuits on a breadboard.
    • Vote Up +6 Vote Down
  • zst123
    zst123 over 5 years ago
    According to my lecturers, the 74-series is useful for small glue logic. But for large glue logic, a CPLD is much cheaper, and easy to modify design anytime even after building the circuit PCB.
    Recently in school (diploma level) it appears the curriculum is shifting to add some basic CPLD knowledge. I learnt the 74-series but also learnt some simulation by creating schematics in Intel Quartus software.
    • Vote Up +5 Vote Down
  • ntewinkel
    ntewinkel over 5 years ago
    Hi James,
    Good question, makes me wonder too if better (cheaper, easier, newer, readily-available) solutions are available for them in general.
    I have a bunch on hand still.
    I remembered using them in one of my university courses so when I got back into electronics I started playing with them again - at that point mostly just learning projects playing with logic.
    Recently I tried building a brake/signal light circuit with them, but I'm still having trouble with startup timing causing strange startup states. So I'll likely switch to using an ATTiny eventually.
    Best,
    -Nico
  • neilk
    neilk over 5 years ago
    I still have a few 7400 series ICs in my inventory. I last used one back in about 1990.
    Neil
    genebren over 5 years ago
    I started out in electronics when 74 series logic chips where all the rage.   I used to build a lot of prototypes, in basic gates/counters, all in wirewrap and then converted to PCBs.
    Now, I have a single 74 series part in my active inventory, 74HC4066D, a quad, SPST, analog switch.  A few years ago, I was contracted to design some modules for rack-mount synthesizers. Analog switching is a big part of this work, so I had quite a few different devices that I could use depending on the type of circuit, e.i. audio on control.  The 74HC4006D was my go to part for routing/switching control voltages in some of these designs.
