WorkBench Wednesdays
  • WorkBench Wednesdays
Blog Are you still using 7400-Series Logic, if so, where?
Join WorkBench Wednesdays to participate - click to join for free!
  • Author Author: baldengineer
  • Date Created: 9 Dec 2020 7:50 PM Date Created
  • Views 9506 views
  • Likes 11 likes
  • Comments 37 comments
  • 7400 logic chips
baldengineer
baldengineer
9 Dec 2020
Over the past several months, I have been learning about and repairing 8-bit computer and video game systems. So far, I have worked on the VIC-20, C64, ZX-81, Apple II, and have been learning about the TI 99/A.
It always amazes how much of these early computer systems were built almost entirely with standard 7400-series (LS and HC) chips.
Occasionally, I need to replace a 7400-series chip. (I always hope it is one of those and not one of the ASICs!) While looking for modern replacements, I have noticed the trend that they are becoming more scarce. The LS-series is almost entirely gone--and with good reason. While HC and HCT continue to be somewhat available, they are usually only available in surface-mount packages.
That leads me to the question: Who is still using the venerable 7400-series logic chips today?
To me, there are three groups that might be using them:
  1. Learning. Students and hobbyist learning about digital logic
  2. New Design. Hardware that needs glue-logic. Are these using multi-gate chips or the single-gate variants?
  3. Repair. Older electronics in need of replacements. Here is where I mostly sit.
Do you fit into one of those categories? If not, where do you land?
And THEN, which chips are the must-have on-hand?
Obviously, the answer depends on how you might be using them. But, I'm curious to know how you use 7400-series chips and which ones would you keep in stock?
  • michaelkellett
    michaelkellett over 5 years ago +13
    The high spot of my 74xxx design works was about 1987 when I designed this beastie. Subsequent designs used FPGAs or micro-controllers. I was lucky enough to find one on Ebay recently, not quite working…
    shabaz over 5 years ago +8
    Here an electronics chain called Maplin was selling 74-series TTL right until 2018, when it closed for good! I guess people were still buying them, perhaps to repair old equipment. I think this is the…
  • ralphjy
    ralphjy over 5 years ago +7
    I just used a couple of 4000 series logic chips in the Pong game that I rebuilt. And I have an assortment of 74 and 74LS (even some 54 mil grade parts) from the late 70s and early 80s when I did a lot…
  • michaelkellett
    I use the occasional modern 74 series type chip for glue logic, usually single gate things, occasionally multi channel level shifters.
    I've done some new designs in the last few years which use shift registers or 4016 type parts (whch I'll count as 74 series for the purpose of this discussion image)
    As soon as you need more than a few 74 series type parts you're better off with an FPGA, there are 48 pin parts starting at £2 or £3 even in 10s - and
    of course they are much more capable .
    My last big 7400 type design was done in about 1985 !
    MK
    DAB over 5 years ago
    Hi James,
    I still have quite a few 7400 series of various types.
    I use them to prototype logic circuits on a breadboard.
    They are still very easy to use and you can put together quick circuits.
