WorkBench Wednesdays
  • WorkBench Wednesdays
Blog Op Amp Proto Board (SOIC-8)
Join WorkBench Wednesdays to participate - click to join for free!
  • Author Author: baldengineer
  • Date Created: 25 Jan 2023 5:55 PM Date Created
  • Views 2332 views
  • Likes 15 likes
  • Comments 5 comments
  • kicad
  • op amp
  • pcb
baldengineer
baldengineer
25 Jan 2023
Solderable Protoboard Examples
In the Slew Rate vs Rise Time video, I used this little breakout board. The bottom side is a continuous copper plane. On the top, the square pins have solder pads that you can connect to the top and bottom copper pour. The idea is to provide as much ground as possible.
There are a few 2.54mm spaced holes for each pin. These allow for through-hole passives or 0805 surface mounts.
The headers on the "top" and "bottom" of the board are connected to each other and intended for power rails.
Originally, I designed the board for SOIC-8. I didn't think of DIP compatibility. So on version 1, you can get a DIP-8 to fit, but you have to bend the pins a bit.
Last, the PCB fab I used can, apparently, print silk directly on HASL. I assumed they wouldn't, so I didn't remove any of the top-layer silk. Oops. In the microscope shot below, you can see white silk screen around the "solder jumper" footprint pads. The silk does help contain the solder when shorting them, so that was nice.
microscope of silk on copper
Anyway, I found the board worked well, especially compared to a breadboard.
$32 for qty 5 shipped from an Asia-based PCB house.
Design Files
Download the KiCad design files here.
    DAB over 3 years ago
    Nice build.
  • baldengineer
    baldengineer over 3 years ago in reply to wolfgangfriedrich
    Oh, big pale rectangles are blocks of silk screen on the bottom. They were meant to give me a place to label the circuits.
    The original plan was to compare multiple op amps. But, then I got side-tracked along the way.
  • wolfgangfriedrich
    wolfgangfriedrich over 3 years ago
    From the top the board looks almost home etched (minus the silkscreen) or from good old Alberta Printed Circuits.
    But what layer are the big pale rectangles? Oh, maybe bottom layer silkscreen...
  • baldengineer
    baldengineer over 3 years ago in reply to shabaz
    I wonder if this was an unintentional manufacturing step. I mean, I should not have included the silk layer at all. But, I was fully expecting them to ignore it.
    That said, it doesn't really affect anything significant. i was just surprised because at first I thought the gnd-jumpers had disconnects in them!
    shabaz over 3 years ago
    "the PCB fab I used can, apparently, print silk directly on HASL"
    That used to be quite common : ) unfortunately it's one of the minor things that the low-cost China prototype PCB services don't seem to support.
    Sometimes it is handy (especially for prototying boards as you're doing, or for RF boards, or for where you've got lots of heatsinking going on, and you might want the occasional bit of silkscreen when there's no mask layer).
