WorkBench Wednesdays
  • WorkBench Wednesdays
Blog Quick: what's your best desoldering braid/wick tip or trick?
Join WorkBench Wednesdays to participate - click to join for free!
  • Author Author: baldengineer
  • Date Created: 1 Feb 2021 4:59 AM Date Created
  • Views 9717 views
  • Likes 14 likes
  • Comments 49 comments
  • soldering
  • solder wick
  • desolder
  • desoldering braid
baldengineer
baldengineer
1 Feb 2021
Since last March 2020, I have been live-streaming three days a week. My streams are all electronics related but include retro computer repairs, soldering kits, Arduino coding, explaining measurements, and other electronics stuff. Several of the recent Workbench Wednesdays episodes have been a result of a live stream. Another outcome from these streams is that my soldering skill has increased significantly. Not just because I am practicing more, but because constantly being watched and critiqued creates motivational awareness!
The other day, someone commented that I am a "solder wick magician." Of the things I get called online, I consider that one a compliment. Though, unlike the other names, it may not be entirely deserved. At least, I don't think so. However, as the animated GIF above shows, I occasionally get an excellent wicking action when using desoldering braid.
There are only a few tips and tricks that I (think I) actually know. So, I thought I'd ask the community about yours. Getting started, here is something obvious to me now, but people usually get the ah-ha look on their faces when I show them. Unless the wick is brand new, I'll dab it with a flux pen before using it. I find flux on the joint I'm trying to remove, plus the extra flux that wicks into the braid, is very effective. (And a great way to use up old braid.)
What are some tips or tricks you have when using desoldering braid (or wick)?
  • Fred27
    Fred27 over 5 years ago +9
    I was also going to suggest using more flux, but it seems everyone's on the same page with that one. I have a "shoe polish" style tin of flux that I must have got free with something from China. I drag…
  • Andrew J
    Andrew J over 5 years ago +7
    For through hole components, don't bend the leads underneath the board to hold them in place on the top side. That "can" make it more difficult to desolder in the future if needed and the part never stays…
  • wolfgangfriedrich
    wolfgangfriedrich over 5 years ago +7
    Use more flux, always....
    genebren over 5 years ago
    In addition to flux, I find it useful to flex the wick back and forth while apply heat and the solder is fluid. This action opens up the braid and allow the solder more freedom to wick.  I also drag the wick to help wipe solder out of the joint/lead.
    • Vote Up +6 Vote Down
  • fmilburn
    fmilburn over 5 years ago in reply to wolfgangfriedrich
    I agree.  Someone told me that the flux in old solder wick can dry out.  I don’t know if that is correct but adding flux when using solder wick seems to always help.  I use flux in paste form and a toothpick to dab it where needed.
    • Vote Up +7 Vote Down
  • wolfgangfriedrich
  • Andrew J
    For through hole components, don't bend the leads underneath the board to hold them in place on the top side.  That "can" make it more difficult to desolder in the future if needed and the part never stays properly in place when you turn the board over.  Instead, keep the leads straight through the hole, place the component on the board on the top side, then hold it place with blu-tac or similar.  When you flip the board over to solder, the part will stay put, you can solder then trim the leads so they are straight.  Try not to get blu-tac in the solder hole!  Any residue on the top side can be removed by dabbing the area with blu-tac - in any case, it is non-conductive.
