WorkBench Wednesdays
  • WorkBench Wednesdays
Blog Quick: what's your best desoldering braid/wick tip or trick?
Join WorkBench Wednesdays to participate - click to join for free!
  • Author Author: baldengineer
  • Date Created: 1 Feb 2021 4:59 AM Date Created
  • Views 9707 views
  • Likes 14 likes
  • Comments 49 comments
  • soldering
  • solder wick
  • desolder
  • desoldering braid
baldengineer
baldengineer
1 Feb 2021
Since last March 2020, I have been live-streaming three days a week. My streams are all electronics related but include retro computer repairs, soldering kits, Arduino coding, explaining measurements, and other electronics stuff. Several of the recent Workbench Wednesdays episodes have been a result of a live stream. Another outcome from these streams is that my soldering skill has increased significantly. Not just because I am practicing more, but because constantly being watched and critiqued creates motivational awareness!
The other day, someone commented that I am a "solder wick magician." Of the things I get called online, I consider that one a compliment. Though, unlike the other names, it may not be entirely deserved. At least, I don't think so. However, as the animated GIF above shows, I occasionally get an excellent wicking action when using desoldering braid.
There are only a few tips and tricks that I (think I) actually know. So, I thought I'd ask the community about yours. Getting started, here is something obvious to me now, but people usually get the ah-ha look on their faces when I show them. Unless the wick is brand new, I'll dab it with a flux pen before using it. I find flux on the joint I'm trying to remove, plus the extra flux that wicks into the braid, is very effective. (And a great way to use up old braid.)
What are some tips or tricks you have when using desoldering braid (or wick)?
  • Fred27
    Fred27 over 5 years ago +9
    I was also going to suggest using more flux, but it seems everyone's on the same page with that one. I have a "shoe polish" style tin of flux that I must have got free with something from China. I drag…
  • Andrew J
    Andrew J over 5 years ago +7
    For through hole components, don't bend the leads underneath the board to hold them in place on the top side. That "can" make it more difficult to desolder in the future if needed and the part never stays…
  • wolfgangfriedrich
    wolfgangfriedrich over 5 years ago +7
    Use more flux, always....
  • Fred27
    Has anyone tried using solder wick to fix the worn out brushed on a Scalextric car? I've not tried it myself but I think it would work pretty well.image
    Jan Cumps over 5 years ago in reply to cstanton
    cstanton  wrote:
    I've never had any luck with solder wick. No matter the temperature or how much flux I have, it doesn't pull the solder away and I end up resorting to a suction gun or bulb of some kind. Perhaps it's the solder I end up working with? it tends to have this kind of liquid suspension that means it doesn't want to attach itself to anything or be wicked away and ends up sitting there unless it's sucked.
    There is indeed something wrong, Christopher. It should actively wick away the solder.
    I use lead free, and usually wick at (ducking for cover) 400° C or more. With flux paste on the area that needs to be wicked.
  • cstanton
    cstanton over 5 years ago
    jw0752 over 5 years ago in reply to 14rhb
    Hi Rod,
    Here is the link to the posting on repair of a circuit board fuse clip.
    https://www.element14.com/community/people/jw0752/blog/2021/02/03/solder-wick-repair-of-damaged-circuit-board
    Thanks for your encouragement.
  • 14rhb
    14rhb over 5 years ago in reply to jw0752
    Hi John,
    Whilst I have no need to repair anything to that level currently, whilst you are mentioning it, I would encourage you to post those pictures (and separate blog as mentioned). Someone will always find it useful in the future and with the right metadata tabs at the bottom should stumble across it nice and quick image
