WorkBench Wednesdays
  • WorkBench Wednesdays
Forum What are some Multimeter Tips / Tricks / Unique Measurements?
  • Episodes
Join WorkBench Wednesdays to participate - click to join for free!
  • Replies 17 replies
  • Subscribers 112 subscribers
  • Views 7181 views
  • dmm
  • multimeter
baldengineer
baldengineer over 4 years ago
While looking at my humble handheld multimeter, I got to thinking about different tricks for using a DMM.
For example, the trick to check the ammeter's built-in fuse or measurements like verifying if a BJT is blown.
What are some fun measurements you can do with a DMM?
  • kmikemoo
    kmikemoo over 4 years ago +5
    Rereading some of the comments reminded me, I use my (also ancient) Fluke 87 as a noncontact frequency meter. I can just hang a meter lead by an AC line and it will give me a frequency measurement. Learned…
  • colporteur
    colporteur over 4 years ago in reply to dougw +4
    I tried your suggestion on my 36-year-old fluke 77 meter using the diode testing mode and it worked. I never thought of doing that. Great share!
  • baldengineer
    baldengineer over 4 years ago in reply to dougw +4
    You know what's funny? I do this ALL the time. Most of my meters won't tell you the forward voltage (since it is more than 0.9v), but its a great way to verify the cathode and the color!
    Jan Cumps over 4 years ago
    Measure inductance with the capacity function
    shabaz over 4 years ago
    You can make decent noise measurements, (e.g. power rail noise) but need to have a multimeter with True RMS, and decent AC bandwidth. Info on how to do it is near the bottom of this blog post: /challenges-projects/project14/diy-test-instrumentation/b/blog/posts/viewing-noise-with-a-measurement-amplifier
    If you have a 4.5 digit or so multimeter, then it's possible to connect a thermistor to it, and measure the resistance, and then shining a laser pointer on the thermistor provides sufficient energy to warm it up, which is measurable : ) The thermistor can be placed in a small transparent glass jar, to prevent direct air currents causing too much drift.
    dougw over 4 years ago
    Measure the on resistance of a MOSFET by using the DMM in resistance mode to charge the gate before measuring the drain-source resistance. The gate capacitance will hold its charge and keep the FET on during the channel resistance measurement.
  • baldengineer
    baldengineer over 4 years ago in reply to shabaz
    Another impressive project that is now on my to-do list.
  • rsjawale24
    rsjawale24 over 4 years ago
    Put the DMM in the diode mode and use it to identify if a BJT is good or bad. The diode mode will give the voltage drop "Vbe" (base emitter junction) if the BJT is not damaged. I use this to check transistors bought in bulk. This also helps to identify the base emitter leads on the transitor package.
    Some DMMs have enough voltage and current on their Ohms or diode modes to turn LEDs on - so you can tell what color they are, what their polarity is and if they work.
  • rsjawale24
    rsjawale24 over 4 years ago in reply to dougw
    I use this method to determine the common anode/cathode of a 7 segment display. It also helps to identify if the 7 seg is a CA or CC.
  • colporteur
    dougw over 4 years ago in reply to colporteur
    That is a great meter for everything else as well.
