WorkBench Wednesdays
  • WorkBench Wednesdays
Documents Considerations for Solder Station Upgrades -- Workbench Wednesdays 03
Join WorkBench Wednesdays to participate - click to join for free!
  • Author Author: Matt
  • Date Created: 16 Jan 2019 10:01 PM Date Created
  • Last Updated Last Updated: 6 Feb 2019 8:24 AM
  • Views 6729 views
  • Likes 11 likes
  • Comments 23 comments
element14 Presents  |  Bald Engineer: James Lewis' VCP Profile |  Project Videos
After a multimeter, a soldering iron is the most useful tool in electronics. In this episode, James looks at potential upgrades to your soldering station. Whether you currently don't have a soldering iron or even if you have a complete re-work station, this video introduces you to possible upgrade options.
Do you have questions or other ideas on the best soldering equipment for your work bench?  Share them in the comments below.
Featured Parts (Thanks to our friends at Weller for providing these!):
Part
Hobbyist Soldering Station (WLC-200)
Buy NowBuy Now
Soldering Station, WE Series (WE1010)Buy NowBuy Now
Soldering Station (WES51)Buy NowBuy Now
Soldering Station Power Supply, For Weller WX Soldering System (WX1N)Buy NowBuy Now
Dual Control Unit For Weller Hot Air Pencil (WXA2N)Buy NowBuy Now
Soldering Station Power Supply (WXR3N)Buy NowBuy Now
Low Voltage Soldering Iron (WXP120WXP120 )Buy NowBuy Now
Desoldering Tweezer, Micro, for use with WX Series Soldering Stations (WX MTMS)Buy NowBuy Now
Low Voltage Soldering Iron (WXP65)Buy NowBuy Now
  • workbench_wednesdays
  • e14presents_baldengineer
  • solder station upgrades
    shabaz over 7 years ago in reply to pjnoxon +3
    I can get by with even a low-cost Antex (except they're not as low-cost any more) since one eventually gets used to and can work around some tool limitations, but nowadays I have an old but decent JBC…
  • mayermakes
    mayermakes over 7 years ago +2
    I´d like to see a comparison on desoldering tools, wick vs manual pump vs automatic pump etc... showing which is best for a particular job. and a general guide on which solder to use in certain cases,…
  • Fred27
    Fred27 over 7 years ago +2
    Could you do a version where you pronounce "solder" the right way?
  • sdrake@ece.ualberta.ca
    sdrake@ece.ualberta.ca over 7 years ago
    I would like to see how you clean you tip and desoldering tools, what chemicals do you use when soldering, like rosin, do you use it?
    What about tip cleaner, can you show different tips, how fine a tip can get to solder SMD, at what point do you have to give up doing
    by hand and goto reflow ovens.  Do you use a microscope to help when soldering?  How do you determine what temperature to use
    when soldering, how many sizes of solder are there?  I would like to know from professionals like yourself about these things, like with
    videos you make, I really enjoy them and the really help me.  Thank you for your work.
  • dangillham
    dangillham over 7 years ago
    Sorry to put my oar in, but I have an expensive Weller station (hot air pencil, iron, tweezers, desolder gun etc £1,600+), and 2 x Metcal stations (around £800 each), which are less pricey, but in my book, unbeatable. Since I purchased the Metcal units, I've never gone back to the Weller one except when I need hot air. The Metcals come with desoldering gun too, which plugs into a compressor, so it sucks the solder brilliantly. If you're thinking of spending well over a grand (£1600+ for Weller) spend £800 or so on Metcal PSU/iron/desolder gun instead - or 2 for around the same price as the Weller! Apologies, but that's my view. And it largely solves the solder wick problem!
    beacon_dave over 7 years ago in reply to baldengineer
    Used one back in the late 80's for over 3 years. The back of the  tips are made of a material which changes its magnetic properties with temperature, allowing for thermostatic control. The tips were available for purchase pre-set at different temperatures, so by swapping the type you could change the soldering temperature. I recall that there was a number stamped onto the back of each tip for identification of its temperature setting.
  • baldengineer
    baldengineer over 7 years ago in reply to beacon_dave
    Interesting, I wasn't aware of the Magnastat. I'll need to check out that type at some point.
    A couple of other soldering iron styles at the lower end of the budget which may be worth mentioning, would be the likes of the Weller W61 with Magnastat temperature controlled tip:
    https://www.weller-tools.com/professional/EUR/en/Professional/Soldering+technology/Soldering+irons/Mains-powered+solderi…
    or the likes of the Antex TCS50 with variable temperature control:
    https://www.antex.co.uk/products/precision-range-soldering-irons/tcs50w/
  • baldengineer
    baldengineer over 7 years ago in reply to Fred27
    Lol. Stay tuned... image
    For what it is worth, I did pronounce Aluminium in a capacitor video (that hasn't been released yet.)
  • Fred27
    Could you do a version where you pronounce "solder" the right way? image
  • baldengineer
    baldengineer over 7 years ago in reply to kc0iog
    What tools do you like to use for holding the work in place?
    Hi Brian,
    You'll see in an upcoming video that I use PCB holders from Panavise. I'm a big fan of their tools. Plus they support both the professional and maker community, so I try to support them when I can. (I always check them out at the Bay Area Maker Faire, to see if they have anything new I need!)
    Panavise 324 PCB Holder324 PCB Holder
    Panavise 201 Bench Vise Mini201 Bench Vise Mini
    If you don't have a place to bolt them down on your workbench, try a piece of cast iron or even thick wood. It is relatively stable and easily portable.
  • baldengineer
    baldengineer over 7 years ago in reply to dsedohr68
    Hi Daniel,
    As a said in the video, any iron is better than no iron! However, for getting started, you don’t need to jump to the WXR3. I do think you should push your budget for something like the WE1010 instead of the cheap stick.
    Even if you are only focused on salvaging parts, controlling the temperature and having some other tip options available will be a big help. For now, I think learning to use solder wick, and a manual pump is a good idea.
    If you find yourself needing to speed up that process, or there is a financial benefit to getting more done faster, then I would start looking at an electronic de-soldering tool. Thing is, no matter how useful the tool is, you’ll still occasionally need to use the manual pump, and you’ll always be using wick for something. So you’ll be happy to have mastered those basic skills.
  • kc0iog
    kc0iog over 7 years ago
    James,
    First of all, GREAT timing!  I was just thinking about investing in a soldering station as an upgrade to my dual wattage pencil iron.  One challenge I always have is about holding the work, iron, and solder.  I wish I had 4 hands at times.  What tools do you like to use for holding the work in place?  What about lighted magnifiers for intricate work?  Another topic is tip selection.  Which tips for which jobs?
    This is going to be an enjoyable series.  Thank you for putting this together!
    Brian
