WorkBench Wednesdays
  • WorkBench Wednesdays
Documents Win a Tenma Power Supply
Join WorkBench Wednesdays to participate - click to join for free!
  • Author Author: kellyhensen
  • Date Created: 19 Sep 2019 2:23 PM Date Created
  • Last Updated Last Updated: 19 Nov 2019 6:47 PM
  • Views 8152 views
  • Likes 15 likes
  • Comments 128 comments
Congratulations to our winners!
Wow! You guys came up with some really creative ideas! There were over 100 individual ideas submitted and they were a blast to read through.
The winner of the Tenma Supply is Andrew J!
His submission literally made James laugh out loud: turning the supply into a mouse to scare a cat.
Congrats on your new supply!
But that's not all! We're going to find some element14 Community swag for the following honorable mentions:
neuromodulator
liamsenior
dougw
javagoza
This giveaway is closed.
Now that you know the basics of how to use a power supply, wouldn't it be great to have one to use on your very own bench?  Well, you are so lucky because James has one to give away!
Unsupported video URL format.
James is always looking for novel ideas for how to use the equipment on his work bench. . . so in this contest, he's asking for ideas on the most unique use for a power supply that maybe isn't just using it as a power supply.  (I don't think he means gutting it and using it for a potted plant.)
Add your suggestion in the comments below (no later than Friday, November 1) and you're entered with a chance to win.
James will select the winner and announce her/him on this page no later than November 14, 2019.
Learn More about the Tenma Power SupplyLearn More about the Tenma Power Supply
Full Terms and Conditions
  • giveaways
  • ww_giveaway
    dougw over 6 years ago +10
    I would like to set this power supply up to be able to rapidly test USB cable performance. I have a large collection of USB cables that is still growing. It seems every device comes with yet another USB…
  • baldengineer
    baldengineer over 6 years ago +9
    Wow! You guys came up with some really creative ideas! There were over 100 individual ideas submitted and they were a blast to read through. The winner of the Tenma Supply is Andrew J ! His submission…
    Jan Cumps over 6 years ago +8
    That is a very good PSU! also: I encourage baldengineer to give away *all* the equipment that we can see in the video
  • piotrva
    piotrva over 6 years ago
    In our laboratory we have a setup, where we can rotate a sample with attached probe inside huge electromagnet. The sample is turned using stepper motors (connected with non-magnetic turning table using system of belts), that are controlled by dedicated control device (that provide also absolute positioning and PC interface). Unfortunately steper drivers involved in the device are PWM controllers, and the noise generated by this switching caused interference with precise measurement setup (involving lock-in amplifiers). In order to continue measurements we decided to build an improvised non-switching stepper driver.
    This involves:
    1. Two variable high-end power supplies (acting as voltage controlled voltage sources)
    2. NI-USB measurement card, which together with PC software provides an interface between original controller and analog control inputs of power supplies
    3. Original stepper motor controller with switching-mode stepper drivers disconnected
    For test purposes we used an MSO as a signal generator to drive power supplies.
    Is it over-engineered and over-complicated? YES
    Is it over-rated? YES
    Does it work? YES
    So everything is OK. But we are pretending to get a title for making the most overrated and most over-sized stepper motor controller image
    Here is a video presenting the proof-of-concept using the MSO.
    And... this was done... a month ago... And... we still use the setup as we are waiting for someone to design a new stepper motor controller - without PWM that was ruining our measurements image
  • piotrva
    This involves:
    Does it work? YES
