WorkBench Wednesdays
  • WorkBench Wednesdays
Documents Win a Tenma Power Supply
Join WorkBench Wednesdays to participate - click to join for free!
  • Author Author: kellyhensen
  • Date Created: 19 Sep 2019 2:23 PM Date Created
  • Last Updated Last Updated: 19 Nov 2019 6:47 PM
  • Views 8038 views
  • Likes 15 likes
  • Comments 128 comments
Congratulations to our winners!
Wow! You guys came up with some really creative ideas! There were over 100 individual ideas submitted and they were a blast to read through.
The winner of the Tenma Supply is Andrew J!
His submission literally made James laugh out loud: turning the supply into a mouse to scare a cat.
Congrats on your new supply!
But that's not all! We're going to find some element14 Community swag for the following honorable mentions:
neuromodulator
liamsenior
dougw
javagoza
This giveaway is closed.
Now that you know the basics of how to use a power supply, wouldn't it be great to have one to use on your very own bench?  Well, you are so lucky because James has one to give away!
Unsupported video URL format.
James is always looking for novel ideas for how to use the equipment on his work bench. . . so in this contest, he's asking for ideas on the most unique use for a power supply that maybe isn't just using it as a power supply.  (I don't think he means gutting it and using it for a potted plant.)
Add your suggestion in the comments below (no later than Friday, November 1) and you're entered with a chance to win.
James will select the winner and announce her/him on this page no later than November 14, 2019.
Learn More about the Tenma Power SupplyLearn More about the Tenma Power Supply
Full Terms and Conditions
  • giveaways
  • ww_giveaway
    dougw over 6 years ago +10
    I would like to set this power supply up to be able to rapidly test USB cable performance. I have a large collection of USB cables that is still growing. It seems every device comes with yet another USB…
  • baldengineer
    baldengineer over 6 years ago +9
    Wow! You guys came up with some really creative ideas! There were over 100 individual ideas submitted and they were a blast to read through. The winner of the Tenma Supply is Andrew J ! His submission…
    Jan Cumps over 6 years ago +8
    That is a very good PSU! also: I encourage baldengineer to give away *all* the equipment that we can see in the video
  • jpentecost
    jpentecost over 6 years ago
    Electrolysis, electroplating, load calculation, battery charging, there are lots of uses for a very stable reglauted power supply!
  • ubergeeknz
    ubergeeknz over 6 years ago
    This Tenma power supply would not only be handy as a hefty paperweight to keep those all important datasheets and service manual pages from flying around, but also for charging batteries, electroplating metals, electrochemical corrosion/rust removal, testing faulty equipment, cooking hot dogs by conduction, heating a hotwire cutter for polystyrene or a resistive tip for woodburning, powering a slotcar set, as a low voltage lighting dimmer, run a computer fan to keep me cool at my workbench, heat ballast resistors to keep me warm at my workbench, hm,p both at once to act as a fan heater, powering a pair of USB heated socks ... and supplying a peltier plate to keep my tea warm - or my beer cold.
  • jimmyngai84
    jimmyngai84 over 6 years ago
    A clean and powerful power supply is a dream for audiophiles. So how about using this kind of bench-top power supplies to replace those Hi-Fi power supplies that cost more than a few ten thousands?
  • fyaocn
    fyaocn over 6 years ago
    Late for theme Energy Harvest , but still slow in progress  The specified item was not found. .
    There is no new use of Power Supply. Challenging part is how to set the parameter on RF transmission line and antenna. Measuring power efficiency and output curve may need the Power Supply.
    Still like to see other innovated use of this power bench.
  • powermeup
    powermeup over 6 years ago
    A new dual output digital power supply is a useful item. I have many uses for something of this type.
  • clem57
    clem57 over 6 years ago
         Call me crazy or what, but I have a plan. I would like tho take the output of two or more channels and measure the ripple using a MCU with ADC taking up to 12.5 mega-samples/second using 12/16 bit samples. Overtime these will vary according to the ripple in the power supplied by the Tenma power supply. The result can be compared to the channels used from the Tenma power supply. I plan on using a sigma delta filter module to sense the current flowing. By varying the current, I can see how the ripple fluctuates from a low level to a higher level. This can be very instructive on usage of the power supply choices of current vs voltage in projects in the future.
    Thanks baldengineer ,
    Clem
    • Vote Up +5 Vote Down
  • mariuss_suciu
    mariuss_suciu over 6 years ago
    Connect the power supply to a power resistance, and warm up your legs.....winter is coming image
  • liamsenior
    liamsenior over 6 years ago
    Cool contest! I like the novel uses some poeple have suggested image
    I would suggest it could be used to gold (or silver) plate probe tips / contacts via electrochemistry to take advantage of the low contact resistance gold plating provides and give us more precise measument ability, but I see someone has already suggested using it for copper plating which is very cool too. Similar to this is electrically anodising titanium or aluminium to help prevent galling from metal to metal contact between bearing surfaces (or purely for cosmetic reasons to colour it!).
    My suggestion instead is to use it to be able to test low resistance values in cables or in circuit non-destructively. A good example of this is testing shielded cable to estimate percentage braid coverage or the gauge of the drain wire. If we measure the current in series with our device under test and measure the voltage drop across it, after plotting our readings for several supply current and voltage combinations, we can produce a quite accurate estimate without having to do destructive testing or 4 wire measuments.
    Thanks for reading,
    Liam Senior
  • parisi
    parisi over 6 years ago
    Hi all,
    this Tenma power supply does not have a very important futures like FORCE&SENSE.
    When the power supply can delivery high currents (like this!), it is very important to enable the SENSE input otherwise you risk to have an invisible bad connection and your DUT does not work.
    The SENSE feature is a must in the semi-professional and professional equipment.
    This is my opinion and I hope to be useful to my colleagues who are choosing a new power supply,
    Best Regards,
    Fulvio
  • valiza
    valiza over 6 years ago
    I would burn electronic components with it, maybe try to melt something using graphite electrodes. (since it's free)
