WorkBench Wednesdays
  • WorkBench Wednesdays
Documents Win a Tenma Power Supply
Join WorkBench Wednesdays to participate - click to join for free!
  • Author Author: kellyhensen
  • Date Created: 19 Sep 2019 2:23 PM Date Created
  • Last Updated Last Updated: 19 Nov 2019 6:47 PM
  • Views 8038 views
  • Likes 15 likes
  • Comments 128 comments
Congratulations to our winners!
Wow! You guys came up with some really creative ideas! There were over 100 individual ideas submitted and they were a blast to read through.
The winner of the Tenma Supply is Andrew J!
His submission literally made James laugh out loud: turning the supply into a mouse to scare a cat.
Congrats on your new supply!
But that's not all! We're going to find some element14 Community swag for the following honorable mentions:
neuromodulator
liamsenior
dougw
javagoza
This giveaway is closed.
Now that you know the basics of how to use a power supply, wouldn't it be great to have one to use on your very own bench?  Well, you are so lucky because James has one to give away!
Unsupported video URL format.
James is always looking for novel ideas for how to use the equipment on his work bench. . . so in this contest, he's asking for ideas on the most unique use for a power supply that maybe isn't just using it as a power supply.  (I don't think he means gutting it and using it for a potted plant.)
Add your suggestion in the comments below (no later than Friday, November 1) and you're entered with a chance to win.
James will select the winner and announce her/him on this page no later than November 14, 2019.
Learn More about the Tenma Power SupplyLearn More about the Tenma Power Supply
Full Terms and Conditions
  • giveaways
  • ww_giveaway
    dougw over 6 years ago +10
    I would like to set this power supply up to be able to rapidly test USB cable performance. I have a large collection of USB cables that is still growing. It seems every device comes with yet another USB…
  • baldengineer
    baldengineer over 6 years ago +9
    Wow! You guys came up with some really creative ideas! There were over 100 individual ideas submitted and they were a blast to read through. The winner of the Tenma Supply is Andrew J ! His submission…
    Jan Cumps over 6 years ago +8
    That is a very good PSU! also: I encourage baldengineer to give away *all* the equipment that we can see in the video
  • jadew
    jadew over 6 years ago in reply to jimmyngai84
    You never know just how clean a lab power supply really is until you test it.
    Also, lab power supplies have different requirements to meet than a fixed power supply, so in most cases, a fixed power supply designed specifically for powering up a certain type of circuit, will perform much much better than a lab power supply.
  • jadew
    Those are very tricky requirements. These are the uses I came up with, that don't require it to power a circuit:
    - Door stop.
    - Movie prop.
    - A toddler could sit on it, as if it were a chair.
    A short circuit is still a circuit, but if it were allowed, you could use it to heat a small room.
  • mahmood.hassan
    mahmood.hassan over 6 years ago in reply to luislabmo
    You idea is related to remote monitoring while my idea is controlling everything through PC keyboard shortcuts.
  • musclecarz13
    musclecarz13 over 6 years ago
    Hello all.
    My husband is a self made amateur photographer, he does lots of high speed and and black light shoots as well as macro of science and nature and I help by building and creating for him. Lately, he has been getting into various ways of creating standing waves, like pvc with he's drilled into it pressuried with propane and a speaker at one end, producing fire as a standing wave, as well as with sand and glow in the dark powder, water and lots of other things. The problem we are having is that using audio to create the waves leaves us with a limit to output relative to the power of the magnet in the speaker. If we had a variable power supply, we could use my miriad motors and various materials to create a physically driven diaphragm system with different sizes and resonant frequency ranges, and switch between them to create more powerful displays of the standing wave on, a larger surface with more material, to make the 3 dimansional wave more clear for his photography. Power supplies like yours would make our universe wide open for possibilities to create and capture. Thank you for reading my run on description and giving it any consideration.
    Sincerely,
    Adam
  • jjdigital
    jjdigital over 6 years ago
    Would love to utilize this power supply to expand my ever-growing Christmas light display. I use many different types of displays, and this would greatly help make some of my ideas realistic, as everything is controlled via a Micrologix 1000 PLC. I could definitely get creative with that bad boy, and would even send you videos of the finished product!
  • meera_hussien
    meera_hussien over 6 years ago
    I want to use this bench PSU for a project which I am working on currently. This project is about using the Peltier to produce cool air. This air will be used to reduce the heat in a certain area.
    To get the desired cool temperature, a series of Peltier is needed. To power up these Peltier and to test the performance of these Peltier, a good PSU is required. Currently, I am powering one set of the Peltier using the normal power supply. And I am limited to test one Peltier at a time. I believe by using the this Tenma PSU; I will be able to test 3 sets of Peltier at one go.
  • luislabmo
    luislabmo over 6 years ago
    Expensive power supplies incorporate a data logger or can interface with one, so I'd like to see this power supply used as a data logger too. This could be a nice DIY project that mods the power supply to track and store Voltage, Current, Power consumption readings; I can see it implemented in different ways:
    • Adding a cheap microcontroller to the PSU that can log data into a Micro SD card or even USB flash drive, it can even incorporate a cheap LCD.
    • An all-in-one solution with touch screen (e.g. with an RPi Zero) that shows realtime information, graphs and allows for exporting data.
    • A wi-fi mod only solution with a web server that allows for the same options.
    • And my favorite take is a Bluetooth mod that can send the data to a cellphone app or to other systems like an RPi with a touch screen.
    • Or honestly any other possibility. E.g. the ESP32 could potentially be a good mod as a web server can be implemented over Wi-Fi and also the Bluetooth approach at the same time.
    Luis
  • squeakycheeks
    squeakycheeks over 6 years ago
    I would hook up one terminal of the power supply to a 555 timer (set up for oscillating). One of the resistors in the 555 timer schematic would be a voltage controlled resistor. One of the other channels of the power supply would be connected to this voltage controlled resistor to vary the duty cycle of the oscillator. The last channel on the supply, could use it as a DC offset.
    Hooked up to a strobe light and then you have an instant dance party at the office! Definitely not overkill image
  • raydem
    raydem over 6 years ago
    Good power supply !! You can use the power supply for a powerful laser cutter like a CNC laser. If you don't like it, you can always make a fried egg using the power supply to heat the pan. XD
  • piotrva
    piotrva over 6 years ago
    In our laboratory we have a setup, where we can rotate a sample with attached probe inside huge electromagnet. The sample is turned using stepper motors (connected with non-magnetic turning table using system of belts), that are controlled by dedicated control device (that provide also absolute positioning and PC interface). Unfortunately steper drivers involved in the device are PWM controllers, and the noise generated by this switching caused interference with precise measurement setup (involving lock-in amplifiers). In order to continue measurements we decided to build an improvised non-switching stepper driver.
    This involves:
    1. Two variable high-end power supplies (acting as voltage controlled voltage sources)
    2. NI-USB measurement card, which together with PC software provides an interface between original controller and analog control inputs of power supplies
    3. Original stepper motor controller with switching-mode stepper drivers disconnected
    For test purposes we used an MSO as a signal generator to drive power supplies.
    Is it over-engineered and over-complicated? YES
    Is it over-rated? YES
    Does it work? YES
    So everything is OK. But we are pretending to get a title for making the most overrated and most over-sized stepper motor controller image
    Here is a video presenting the proof-of-concept using the MSO.
    And... this was done... a month ago... And... we still use the setup as we are waiting for someone to design a new stepper motor controller - without PWM that was ruining our measurements image
