Owl Worm Demon Animatronic Vomiting Candy
Table of contents
Abstract
Inspired by Hooty from the Owl House, this demon owl worm animatronic can move its eyes, talk, open and close a candy chute, and move up and down! It can vomit candy into a candy box!
Have you ever wanted to make a Halloween animatronic but lived in an apartment so only had a door to decorate? Fear not, this Instructables will show how to create an animatronic of perhaps one of the most famous door demons... Hooty from the The Owl House!
Hooty is a chaotic demon who resides inside of the Owl House. His owl face, worm body, and bizarre character combines for epic eldrich horror. In this Instructables, we will create a similar owl worm demon which can talk, look around, and move! To add a Halloween twist, we'll also make our boy vomit candy to unsuspecting trick-or-treaters.
So let's get to it! We'll be creating a three-foot-long owl worm door demon animatronic inspired by Hooty!
Note that this is the first version! There are still some updates that are still a work-in-progress that'd I'd like to make and they are marked as V2.
Supplies
Most of the components are 3d printed! I did use some cardboard to cut on printing costs and time and bought some metal components to help with strength of the body. The majority of the costs will come from the body, the motors, and electronics. I separate the head + candy mechanism from the body in case makers wish to make just the head separate from the body (which is the notably cheaper route)!
Note: These links are just for reference and may not be exactly what I used! Definitely look around for cheaper options as you'd like! Also, when I specify a quantity for an item, I mean the individual item, not the pack (ex: 3x servos means three servos not three packs of servos)!
Head (head + candy mechanism):
  1. 3x 9g servos
  2. I used plastic geared servos but metal gears servos should be more consistent!
  3. 1x brown paint (to be more canon, two shades of brown)
  4. 1x black paint
  5. 1x white paint
  6. 1x orange paint
Body (neck + body):
  1. [V2] 2x mg996 servos
  2. 1x NEMA 7 stepper motor
  3. 1x stepper motor driver (A4988)
  4. [Optional] 1x Capacitor (100 µF)
  5. 1x lead screw (8mm)
  6. 1x 8mm-to-5mm coupler
  7. 2x 8mm ball bearing
  8. 4x 50mm M5 bolts
  9. 2x yard of brown fabric
  10. 1x roll of PETG
Both (to prevent double-listing):
  1. Bolts
  2. Various Self-tapping screws (M2, M3, M4)
  3. Various nuts + bolts (M2, M3, M5)
  4. 2x esp32 wroom (with WiFi) (1 for body, 1 for head)
  5. Wire / Jumper Wire
  6. 1x roll of PLA
  7. [Optional] Breadboard
  8. Can alternatively properly solder the electronics together!
Tools
  1. 3d Printer (0.4 mm nozzle)
  2. Screw drivers
  3. Sandpaper
  4. Paintbrushes
  5. Glue
Software
  1. Arduino IDE
  2. Python Installed
  3. Should already be installed in most systems!
  4. Text Editor for HTML
  5. Just need something to edit the code file! My editor of choice is Vim but pick your poison!
Step 1: Rough Planning + Design + CAD
There are a few components of the owl worm: eyes, mouth, and the body. In addition, we want to make this be able to throw up candy, so we need to include a candy chute mechanism.
Mechanisms:
  1. Head
  2. Eyes
  3. Mouth
  4. Candy Mechanism
  5. Body
  6. [V2] Neck [Omitted for V1]
  7. Body
The follow describes design decisions and mentions places that could be updated. It's accompanied by CAD created in Fusion 360.
Head
Eyes
After watching the show, turns out his eyes are only on the sides of the eyes and never reach the center. Specifically, they tend to be mainly at 45°, 135°, 225°, and 315° (a total of 270° coverage).
Since we want exact locations, I decided to use servos. Since this is largely non-functional, I decided to use 9g servos. A 270° servo should work, but since I only had 180° servos, I used spur gears with a 2:1 ratio to reach all the positions. This design also allowed me to just use one servo for both the eyes.
Mouth
Similar to the eyes, the mouth will leverage friction to get the desire motion. For now, we use a two-bar linkage and use friction to constrain the mouth. This part I'm most likely to redesign in a future iteration since it's not as steady as I hoped. Nonetheless, it's functional!
Candy Mechanism
I iterated through a few mechanisms for this. At the end, we went with a keep-it-simple: a one-shot candy chute that can open and close. This lets us give the candy and not limit it to smaller candies (we want to give people the good candies!). For kids, we can do a mini show of feeding the owl "bugs" (candy) and then let him give it back to the kids. Eventually, it would be awesome (but heavy) to have a whole tub of candy and a dispenser.
Body
Most of the horror come from the body horror. Since imitating everything he can do can get complex and expensive, so I want to get two main functionalities out of the body: (1) the body can move in various directions and (2) the body can expand out of the door.
When prototyping the body, I initially took inspiration from snake robots to get the omnidirectional movement BUT we also want it to expand out of the door. To get the expansion, I chose to use a scissor lift to get a large compression to expansion ratio. For movement, I use two servos to get two degrees of freedom. Ideally this is at both at the head like a neck and the base of the body. However, due to time constraints, the 2 DoF at the base was omitted. The 2 DoF at the neck was also ultimately omitted but fully design and printed. It was a pan-tilt connection and remixed from this. I keep the design and instructions since it should be ready for a V2 of this animatronic (the core issue upon assembly is that it needs more support so requires a few design updates).
CAD Files:
Step 2: Owl Head
First, let's assemble the head with the candy chute mechanism! Before we start, a few tips:
  1. Use the CAD as a reference for assembly!
  2. Sand areas with friction to get smoother movements! (Will prevent 3d printed parts from "locking")
  3. When adding the servos, use either a servo tester or just run some code (this is what I do!) to make sure you're mounting the arm with the correct range of motion!
Part 1: Print + Paint
To start, print and paint the files attached for the head. These are purely aesthetic parts so it can be printed in PLA with infill 15%. For the headplate, I went as low as 5% but this can be replaced with laser-cut wood or a different material to cut costs and print time.
Here's a quick guide on the paint job needed:
  1. Paint the headplate brown (can include a pattern as well!)
  2. Paint the beak (top and bottom) orange
  3. Paint the eyes black with a white circle on the corner (see image attached for reference)
Part 2: Eye Mechanism
The eye mechanism consists of the following parts:
  1. 2x eyes
  2. 2x eye spur gears (back of the eyes)
  3. 1x control spur gear (the big gear)
  4. 1x large servo mount
  5. 1x 9g servo + horn + bolts
  6. Self-Tapping Screws (4x M3, 6x M4)
  7. 1x headplate
Each eye has two parts: the eye itself and the backing spur gear. We'll first install the eye then install the servo and control gear to the face.
Do the following:
  1. Install the eyes!
  2. Slide the eyes into the headplate
  3. I'd recommend sanding the locations which will be sliding against each other to reduce friction!
  4. Use an M4 screw to attach the gear to the back of the eye
  5. Since 9g servos aren't the strongest, I'd recommend sanding the locations which will be sliding against each other!
  6. Assemble the servo mount
  7. Attach the servo into the servo mount (M3 screws or bolts)
  8. Attach the servo horn onto the servo
  9. Make sure you have a good range! Doesn't matter a ton but can be helpful when programming!
  10. Attach the servo arm into the large spur gear (M3 screws)
  11. Finally, attach the mount to the head itself (M4 screws)!
  12. At this point, you should be able to manually move the eyes without too much effort!
  13. Also, make sure that the eyes are facing the same way else you'll get wild expressions!
Part 3: Candy Chute Mechanism
The candy chute mechanism should be pretty straightforward! It requires:
  1. 1x candy chute compartment
  2. 1x candy chute door
  3. 1x 9g servo + horn + bolts
  4. Self-Tapping Screws (1x M3, 4x M4)
  5. Bolts (2x M3)
To assemble, do the following:
  1. Attach the servo horn + door to the servo, ensuring you get the full sweep of motion (attach the door with an M3 screw)
  2. For this, we need to make sure that the door can move to the right bottom of the headplate (from the back)! This will ensure it doesn't get caught in anything!
  3. Attach the servo to the candy chute mechanism (2x M3 bolts)
  4. Attach the candy chute mechanism to the holes in the faceplate (4x M4 bolts)
Note that in this picture, I had to use a shim of some cardboard to get the candy chute high enough to not clash with the mouth. It's now modified in the CAD so little to no extra cardboard should be needed but can be added if the mouth doesn't have enough space.
Part 4: Mouth Mechanism
Similar to the eyes, all parts sliding against each other should sanded! This part requires:
  1. 1x bottom beak
  2. 2x arms / bars
  3. 1x servo mount (small)
  4. Screws (3x M4, 1x M3)
  5. Bolts (1x M5, 2x M3)
To assemble:
  1. Attach the two arms together with an M5 bolt and nut
  2. Connect the servo to the servo mount (2x M3 bolts)
  3. Attach the top arm to the servo horn and attach the servo horn to the servo
  4. Make sure once again you have good motion! You want the servo and arm to be able to reach as high to the right as possible (and be able to point downwards to the middle)
  5. Slide the servo mount in between the candy chute mount
  6. Slide the bottom beak into the hole for the mouth
  7. Make sure everything is sanded!
  8. Use an M4 screw to connect the bottom linkage bar to the bottom beak
Once assembled, ensure both the mouth can move and the candy chute's door can open and close. If there are issues, you may want to use some cardboard as a shim so parts don't clash.
Part 5: Top Beak
Lastly, to add the top beak, use glue (I use gorilla glue) to connect the top beak at the top of the mouth hole in the front of the headplate (use image as reference)
Step 3: [V2] Pan-Tilt Connection Neck
As mentioned, this was created and assembled but ultimately not added to the final build! Nonetheless, feel free to read and assemble!
Part 1: Print
Print the 3mf pan tilt connection. You can additionally print out extra support head plates, but I decided to use cardboard to cut on costs and print time.
Part 2: Support bars
Connect the support bars to the sides of the headplate and to the support headplate. This is a bit tricky to assemble, so I'd suggest connecting to the support headplate first and then the main headplate.
Part 3: Pan-Tilt
The pan-tilt assembly is essentially the same as the reference and requires M3 screws. Connect the bottom to another support headplate.
Step 4: Scissor Lift Body
imageView 3 more
The body is effectively just a scissor lift controlled by a lead screw! Lead screws are pretty neat since they effectively can somewhat lock / have some resistance so it will stay in place. They're often used in 3d printer to get exact linear movement!
This assembly is a bid arduous since there are many components, so I'll detail the steps with some suggestions below!
Part 1: Print
The scissor lift body is printed with PETG. This allows for some sagged without it completely snapping like PLA. These I also used a higher infill of 30%. (Unclear if it did much help but nothing snapped or deformed so I call that a win!)
Part 2: Assemble the Scissor Lift
Parts Required:
  1. 1x lead screw
  2. 1x lead screw nut
  3. 1x lead screw nut chassis
  4. 2x trolley box (each contains 2x side walls, 1x motor mount wall, and 1x motor mount support wall)
  5. 12x scissor lift bars
  6. 4x lift-to-lead-screw bars
  7. 4x 50mm M5 bolts
  8. Self-Tapping Screws
  9. Bolts
Assembly Instructions:
  1. Assemble the Scissors: Use M4 screws to the connect the actually scissor parts. I'd recommend keeping all of the screw heads to the opposite side of the wall so it doesn't get caught when moving up and down.
  2. Assemble the Lead Screw Nut Chassis (Pt 1)
  3. Connect the chassis to the nut with M2 screws
  4. Force the bearing into the side of the box (it should just slide in but a mallet might come in handy)
  5. Slide the lead screw within the bearings and make sure the nut and the chassis is within the walls
  6. Create the box (M4 screws)
  7. Finish the Chassis (Pt 2): Use the big 50 mm M5 bolts to slide to the bottom of the scissor lift and screw into the chassis
  8. Finish Scissor Assemble (Bottom Trolley): Screw the scissor lift to the wall using M4 screw
  9. Attach the Top Trolley:
  10. Assemble the top trolley box
  11. Attach the top trolley to the scissor lift using a longer M4 screw and a few M5 nuts as spacer (M5 so it doesn't catch). Also attach the M5 bolt and nut to secure it to the sliding area.
Part 3: Connect the Motor
Parts Required:
  1. 1x Coupler
  2. 1x Stepper Motor
  3. 1x Motor Mount
  5. Bolts
  1. Slide the stepper motor into the motor mount and add M3 bolts into the slot. The motor mount admittedly isn't the cleanest design so it takes some fidgeting to get the bolts in.
  2. Slide the coupler into the shaft of the stepper motor so it's against the wall of the scissor lift.
  3. Slide the lead screw into the coupler as deep as it can go and fasten the coupler
Step 5: Electronics
The electronics consist of two ESP32s: one for the base and another for the head.
I used a breadboard but you can just as easily use a protoboard + solder the electronics on! To power these, I used a USB-C power bank.
Head
Connect the three servos and the ESP32 to the same power and ground. My pin mapping was:
  1. 21 for the candy chute
  2. 22 for the mouth
  3. 23 for the eyes
Body
Connect the USB-C power bank to the ESP32 and a separate 12 V for the stepper. Connect the stepper motor and ESP32 to the motor driver as detailed below.
Step 6: Programming
We're using ESP32's Wifi Module to control the animatronic wirelessly!
Each ESP32 creates its own server. We create a simple HTML file as an interface. (The attach image of the dashboard is far from pretty but functional to interact with the owl! Design is something I'll add later!) This will send the GET requests to the ESP32 servers causing it to move accordingly.
For audio, since I don’t have a speaker, we use a device which can wirelessly connect to the server (for example, a phone). This doubles as a speaker and a remote control! This also allows us to have many more voice lines since we don’t need to save the mp3 files directly on the esp32.
Overall, the setup is nice since we can leverage nice existing speakers in existing electronics and allows for infinite voice lines but it has the restriction that (1) it’s slow and (2) it’s not the most consistent (messages can be dropped or missed). Good enough for now nonetheless!
The controls created includes:
  1. Four quadrants for the eyes to move (as previously mentioned, he only really looks at four quadrants)
  2. Open/Close for the candy chute
  3. Pre-recorded lines
  4. Note that these lines are taken from the show so all credit to them for that! I did voice over these… but I’ll save you the pain of listening to my impression of this voice which the voice actor describes as mickey mouse with way too much sugar thrown into a washing machine…
  5. Stepper motor up and down
  6. [V2] Pan-tilt Neck Control
To use the files, you need to edit the Arduino file with your Wifi name and password. Then flash the two files onto your ESP32s accordingly (face for the face ESP32 and body for the body ESP32). Each ESP32 will print an IP address which will allow you to access the server on a device connected to same network. This you should add to the html file. The code is in code.txt. It should be renamed to index.html (can be in any folder) and all relevant mp3 files should be added in that same folder. To execute, spin up a Python server by typing the command in the folder with the HTML file:
python3 -m http.server
Step 7: Final Setup + Closing Thoughts
Finally, use a piece of cloth to cover the rest of the body and behold the monstrosity created! I used some cardboard to create supports and binder clips to connect the cloth to the body. This allows for compression when the scissor lift is closed. Also, print out the support bars which can be connected to the face and support face plates to make the head stay in place!
back_head_support - head support.3mf
Reflections
And that's the animatronic! It can be a standalone decor for retrieving candy in an odd way or as a candy-canon type prop to give out candy (what I ended up doing for Halloween!)
This was my first larger build by myself! Ended up spending nearly 60 hours printing (this includes reprints) and about 1-2 months on this project! I'm happy I got achieve mostly everything I wanted to. I wanted to dedicate some space to share some lessons learned, next plans, and general reflections!
Lesson Learned (the hard way)
  1. Always tolerance things! Even though everything looked pretty and perfect in the CAD, I had to print out a ton of different iterations to get things toleranced right
  2. Always double-check your servo is getting the desired range of motion before assembling! This lead to a lot of re-assembly
  3. Screws and bolts have a non-zero head size! If everything is super precise, the heads will get stuck!
  4. Don't flip the polarity of a capacitor unless you want it to explode! (Unfortunate rookie mistake)
  5. Print in parts to lower the filament waste from supports + to easily change/fix parts if something is wrong!
Things I Would Change + Next Steps
As I started listing these out... there was a ton! Projects truly never end! Here's a handful of them:
  1. Body Adjustments
    1. Would have loved to make more of this out of metal (specifically the body) but at the moment, don't have all the tools needed (though in retrospect, could have bought cheap manual tools with my budget at the time)
    2. Of course, would like to get the neck working which requires a light redesign
    3. The scissor lift could also use a small update to make it more stable since right now, it tends to lean around a bit
    4. Add a gearbox to the motor to increase torque. Right now, it will go up but it's definitely shaky, so as we add more weight to the body, it'll need either a better motor or a gearbox / some way to increase the torque
  2. Face Adjustments
    1. Definitely want to redesign the mouth to be more stable than the two-bar linkage (thinking a rack-and-pinion)
    2. Also would like to do light redesigns on the candy chute so it requires less supports to print. Also make it properly dispense multiple times instead of once. And a final idea I had to make it a proper candy canon
  3. New Features!
    1. My initial goal was to make it be able to hang from a door! It can be held horizontally and still work alright but will start to sag and definitely needs support as it goes out. One way I've played with is using bungee cord to support it. This is still something I'd like to explore further later!
    2. My moonshot goal was to make it have multiple scissor lift parts and connections in between! This will definitely need a redesign and less hand-wave-y calculations to get there!
Final Thoughts
And that's all for the animatronic for this season! Had a ton of fun working on this project and giving out candy this year!
If you're interested in also building a sassy owl worm demon, definitely let me know! I'm more than happy to help with any aspect and talk about design changes and updates! Definitely stick around for when I get v2 up and working!
I asked my owl demon for some closing remarks:
Hoot hoot!
References
Inspired by the Owl House!
Pan-Tilt Reference: https://makerworld.com/en/models/973248-pan-tilt-servo-antenna-tracker-mg996r
Category : project
